RL207
RL207
    MDD(辰达半导体)
    DO-15(DO-204AC)
    1KV 2A
RL207 数据手册
RL201 THRU RL207 Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere GENERAL PURPOSE SILICON RECTIFIER Features DO-15  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 1.0 (25.4) MIN.  Construction utilizes void-free molded plastic technique Low reverse leakage 0.140 (3.6) 0.104(2.6) DIA.  High forward surge current capability  High temperature soldering guaranteed:  250°C/10 seconds,0.375”(9.5mm) lead length, 5 lbs. (2.3kg) tension 0.300(7.6) 0.230(5.8) Mechanical Data 1.0 (25.4) MIN. Case : JEDEC DO-15 Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.014 ounce, 0.40 grams 0.034 (0.86) 0.028 (0.70) DIA. Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25°C ambient temperature unlss otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. RL201 RL202 RL203 RL204 RL205 RL206 RL207 Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current 0.375”(9.5mm) lead length at TA=75°C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 2.0A Maximum DC reverse current TA=25°C at rated DC blocking voltage TA=100°C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction and storage temperature range UNITS VRRM VRMS VDC MDD MDD MDD MDD MDD MDD MDD RL201 RL202 RL203 RL204 RL205 RL206 RL207 50 100 200 400 600 800 1000 35 70 140 280 420 560 700 50 100 200 400 600 800 1000 I(AV) 2.0 A IFSM 70.0 A VF V IR 1.1 5.0 50.0 CJ RθJA TJ,TSTG 20.0 50.0 -50 to +150 V V V μA pF °C/W °C Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted DN:T20525A0 http://www.microdiode.com Rev:2020A0 Page :1 RL201 THRU RL207 Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Ampere FIG. 1- FORWARD CURRENT DERATING CURVE 2.0 1.6 1.2 Single Phase Half Wave 60Hz Resistive or inductive Load 0.8 0.4 0 0 25 50 75 100 125 150 PEAK FORWARD SURGE CURRENT, AMPERES AVERAGE FORWARD RECTIFIED CURRENT, AMPERES Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT 70 60 50 40 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 30 175 20 1 10 AMBIENT TEMPERATURE, C NUMBER OF CYCLES AT 60 Hz 20 10 1 TJ=25 C PULSE WIDTH=300 µs 1%DUTY CYCLE 0.01 0.6 0.8 1.0 1.2 1.4 1.5 FIG. 4-TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 0.1 1,000 100 TJ=100 C 1 0.1 TJ=25 C 0.01 0 20 40 60 80 100 200 TJ=25 C 10 TRANSIENT THERMAL IMPEDANCE, C/W PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 5-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE, pF TJ=150 C 10 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 100 100 FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE 100 10 1 0.1 0.01 0.1 1 10 100 1 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 t,PULSE DURATION,sec. The curve above is for reference only. http://www.microdiode.com Rev:2020A0 Page :2
RL207 价格&库存
很抱歉,暂时无法提供与“RL207”相匹配的价格&库存,您可以联系我们找货
