Crimp
2.54mm
RE CONNECTOR
Disconnectable Crimp style connectors
pitch
Features ––––––––––––––––––––––––
• Reliable, yet low in cost
Our unique, double-leaf spring contact withstands the stresses
caused by repeated mating and unmating and ensures a stable
high-pressure connection. The contacts and headers are
selectively gold-plated to reduce costs. Depending on the
application, fully tin-plated contacts and headers are available to
further reduce costs.
• Space-saving, high-density design
Measuring only 16.54mm in height and 2.54mm thick when
mounted on a printed circuit board, the RE connector and
header require less mounting space and facilitate high-density
circuit design.
• Easy contact insertion
A slight force is all that is needed to insert the contacts into the
housing, because the housing has lances. The position of the
The RE connector was developed as a
highly reliable, low-cost, crimp style
connector for connecting wires to printed
circuit boards. Well suited for completing
the internal connections of office
automation equipment, such as personal
computers, office computers, and their
peripheral devices.
contacts in the housing can be visually checked. This facilitates
insertion of the contacts in the housing.
• It can be cut to any length to provide a header
with any number of circuits
Notches are provided on the insulator that allow it to be cut to
any length without using special tools.
Specifications –––––––––––––––––––
• Current rating: 2 A AC, DC (5 circuits/AWG #24)
• Voltage rating: 250 V AC, DC
• Temperature range: (including temperature rise in applying
electrical current)
-55˚C to +105 ˚C (gold plated)
-55˚C to +85˚C (tin-plated)
• Contact resistance: Initial value/ 15 mΩ max.
After environmental tests/ 30 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: AWG #30 to #24
• Applicable PC board thickness: 1.2 to 1.6 mm
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Standards ––––––––––––––––––––––
Recognized E60389
1
Certified LR20812
1
RE
CONNECTOR
Contact –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Applicable wire
Model No.
RF-SC2210
mm2
AWG #
Insulation O.D.
(mm)
0.05 to 0.22
30 to 24
0.9 to 1.5
RF-SC2290
Finish
Q'ty/
reel
Nickel-undercoated,
Mating part; gold-plated
Crimping part; tin-plated (reflow treatment) 10,000
Tin-plated (reflow treatment)
Material
Phosphor bronze
RoHS compliance RF-SC2210 displays (LF)(SN) on a label.
Housing –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
B
A
2.54
2.54
1.27
Circuits
Model No.
2
RE-02
RE-04
RE-05
RE-08
RE-09
4
5
8
9
Dimensions (mm)
A
B
Q'ty/
box
2.54
5.08
1,000
7.62
10.16
1,000
10.16
12.70
1,000
17.78
20.32
500
20.32
22.86
500
14
Material
PBT, UL94V-0, black
RoHS compliance
JST 2
8
9
Header ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Top entry type
Side entry type
RoHS compliance Tin-plated product displays (LF)(SN) on a label.
Note: 1. A two-digit number (02 to 09) representing the number of circuits should be inserted in (* ).
Determine the number depending on the number of circuits of the housing or header.
2. Contact JST for special products.
2
RE
CONNECTOR
Polarizing key ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Model No.
Q'ty/bag
PK-RF-1
10,000
Material
PBT, UL94V-0, natural (white)
RoHS compliance
Polarizing key: The polarizing key in the housing prevents misinsertion of the
connector to the header.
PC board layout (viewed from soldering side) and Assembly layout –––––––––––––––––––
Side entry type
Top entry type
φ
φ
Note:
1. Tolerances are non-cumulative: ±0.05 mm for all centers.
2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
Crimping machine, Applicator–––––––––––––––––––––––––––––––––––––––––––––––
3
Contact
Crimping
machine
RF-SC2210
RF-SC2290
AP-K2N
Crimp applicator
Dies
Crimp applicator with dies
MKS-L
MK/RF-SC22
APLMK RF-SC22
很抱歉,暂时无法提供与“RF-SC2290”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+0.1873210000+0.02331
- 20000+0.1846520000+0.02298
- 30000+0.1828630000+0.02276
- 40000+0.1819740000+0.02265
- 50000+0.1775150000+0.02209
