BD CONNECTOR(13mm)
13.0mm pitch/Disconnectable Crimp style connectors
Specifications –––––––––––––––––––
Board-to-wire crimping type connector
with high withstanding voltage, used for
power supply of large LCD (Liquid Crystal
Display or Liquid Crystal Television) back
light.
Secure locking mechanism prevents from
coming off housing when handling the wire
harness.
• Secure locking mechanism
• Space saving
• High withstand voltage design
• Crimping special wire
• Current rating: 1.0A AC, DC (AWG #24)
• Voltage rating: 3,000V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance:
1,000M Ω min.
• Withstanding voltage: 5,000V AC/minute
• Applicable wire: AWG #28 to #24
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
PC board layout (viewed from component side) and Assembly layout
17.2 ±0.05
1.0 ±0.05
(15.4)
Connector outline
0.2 +0.1
4.5
9.5 −0.1
7.4 −0.1
1.7 +0.1
0.85 +0.1
16.6 ±0.05
Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. The dimensions above should serve as a guideline. Contact JST for details.
1
BD CONNECTOR(13mm)
Contact
Applicable wire
AWG#
mm2
Model No.
SBHS-002T-P0.5A
0.08∼0.22
Insulation O.D. (mm) Q'ty / reel
28∼24
0.9∼1.7
10,000
8.05
0.9
Material and Finish
4.75
2.85
1.3
4.65
Phosphor bronze, tin-plated (reflow treatment)
0.7
1.5
1.5
(0.35)
4.3
0.9
RoHS compliance
Note: Contact JST for SBHS-002T-P0.5.
Contact
Crimping
machine Crimp applicator
SBHS-002T-P0.5A AP-K2N
MKS-L
Applicator
Dies
Crimp applicator with dies
MK/SBHS-002-05-BDA APLMK SBHS002-05-BDA
Note: When using this housing, standard applicator and dies for SBHS contact
can not be applied.
Housing
Circuits
Model No.
Q’ty / bag
2
BDAMR-02VAS-3
1,000
12.1
Material
PBT・UL94V-0, natural (white)
RoHS compliance
2.55
13.0
18.9
5.6
Shrouded header
Circuits
2
10.0
4.5
18.5
Model No.
SM02-BDAS-3-TB
Material and Finish
Press post: Copper alloy, nickel-undercoated, tin/copper alloy-plated
Wafer: PPA, UL94V-0, natural (ivory)
Solder tab: Copper alloy, nickel-undercoated, tin/copper alloy-plated
RoHS compliance This product displays (LF) on a label.
Note: The product listed above is supplied on embossed tape.
2
Q’ty / reel
1,500
很抱歉,暂时无法提供与“SBHS-002T-P0.5A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16430
- 200+0.13270
- 600+0.11510
- 2000+0.10450
- 10000+0.08600
