MB6FB
MB6FB
    JINGDAO(晶导微电子)
    MBF
    0.5A表面安装玻璃钝化桥式整流器 VR=600V IR=5μA MBF
MB6FB 数据手册
山东晶导微电子有限公司 MB6FB Jingdao Microelectronics 0.5A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: PINNING Glass Passivated Chip Junction Reverse Voltage - 600V Forward Current - 0.5 A PIN DESCRIPTION 1 Input Pin(~) 2 Input Pin(~) High Surge Current Capability 3 Output Anode(+) Designed for Surface Mount Application 4 Output Cathode(-) MECHANICAL DATA • Case: MBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 75mg 0.0026oz 3 4 2 1 MBF Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols MB6FB Units Maximum Repetitive Peak Reverse Voltage V RRM 600 V Maximum RMS voltage V RMS 420 V Maximum DC Blocking Voltage V DC 600 V IO 0.5 A 25 A Parameter Average Rectified Output Current at T c = 125 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) I FSM Maximum Forward Voltage at 0.5 A VF 1.0 V IR 5 40 μA Cj 9 pF RθJA 110 °C/W T j , T stg -55 ~ +150 °C Maximum DC Reverse Current at Rated DC Blocking Voltage @ T A =25 °C @ T A =125 °C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Operating and Storage Temperature Range (TYPE) Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. 2016.01 MBF-A-MB6FB-0.5A600V Page 1 of 3 山东晶导微电子有限公司 MB6FB Jingdao Microelectronics Fig.2 Typical Reverse Characteristics 0.6 0.5 0.4 0.3 0.2 Resistive or Inductive Load 0.1 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Rectified Output Current (A) Fig.1 Average Rectified Output Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) T J =25°C 1.0 0.1 100 T J =25°C 10 pulse with 300μs 1% duty cycle 0.01 0.0 1 0.5 1.0 1.5 2.0 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 30 25 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2016.01 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 MB6FB Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 4 leads MBF ∠ALL ROUND C A a L1 L d HE e D e E MBF mechanical data A C D E HE d e L L1 a max 1.6 0.22 5.0 4.1 7.0 2.7 0.8 1.7 1.1 0.2 min 1.2 0.15 4.5 3.6 6.4 2.3 0.5 1.3 0.5 max 63 8.7 197 161 276 106 31 67 43 min 47 5.9 177 142 252 91 20 51 20 UNIT ∠ mm 7° 8 mil Marking Type number 6.0 236 Marking code MB6FB M6FB 2.5 100 0.9 35 M6FB 2.4 94 2016.01 mm Unit : (mil) JD512283B8 Page 3 of 3
MB6FB 价格&库存
很抱歉,暂时无法提供与“MB6FB”相匹配的价格&库存,您可以联系我们找货
MB6FB
    • 20+0.19450
    • 100+0.14560
    • 500+0.11280
    • 5000+0.08180
    • 10000+0.07770
    • 50000+0.07200
    库存:22525
    MB6FB
    • 20+0.06516
    • 500+0.06418
    • 2000+0.06225
    • 5000+0.05945
    库存:4812
