1N4727...1N4761
Silicon Planar Power Zener Diodes
for use in stabilizing and clipping circuits with high
power rating. Standard zener voltage tolerance is
±10%. Add suffix "A" for ±5% tolerance and suffix "B"
for ±2% tolerance. Other tolerances are available upon
request.
Max. 0.7
Min. 25.4
Max. 2.8
Black
Cathode Band
Black
Part No.
Black
"ST" Brand
XXX
Max. 4.2
ST
Min. 25.4
Glass Case DO-41
Dimensions in mm
Absolute Maximum Ratings (Ta = 25 OC)
Parameter
Power Dissipation
Value
Ptot
Junction Temperature
Storage Temperature Range
1)
Symbol
1
Unit
1)
W
Tj
200
O
C
Tstg
- 65 to + 200
O
C
Valid provided that leads at a distance of 8 mm from case are kept at ambient temperature.
Characteristics at Ta = 25 OC
Parameter
Thermal Resistance Junction to Ambient Air
Forward Voltage
at IF = 200 mA
1)
Symbol
RthA
Max.
Unit
1)
K/W
170
VF
1.2
V
Dated : 10/09/2009
1N4727...1N4761
VZnom
at lZT
ZZT
ZZK
at IZK
IR
at VR
Maximum Surge
Current 4)
at Ta = 25 OC
(V)
3
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
(mA)
83
76
69
64
58
53
49
45
41
37
34
31
28
25
23
21
19
17
15.5
14
12.5
11.5
10.5
9.5
8.5
7.5
7
6.5
6
5.5
5
4.5
4
3.7
3.3
Max. (Ω)
10
10
10
9
9
8
7
5
2
3.5
4
4.5
5
7
8
9
10
14
16
23
25
35
40
45
50
60
70
80
95
110
125
150
175
Max. (Ω)
400
400
400
400
400
500
550
600
700
700
700
700
700
700
700
700
700
700
700
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
(mA)
1
1
1
1
1
1
1
1
1
1
0.5
0.5
0.5
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
Max. (µA)
150
150
100
100
50
10
10
10
10
10
10
10
10
10
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
5
(V)
1
1
1
1
1
1
1
2
3
4
5
6
7
7.6
8.4
9.1
9.9
11.4
12.2
13.7
15.2
16.7
18.2
20.6
22.8
25.1
27.4
29.7
32.7
35.8
38.8
42.6
47.1
51.7
56
IZSM (mA)
1375
1375
1260
1190
1070
970
890
810
730
660
605
550
500
454
414
380
344
304
285
250
225
205
190
170
150
135
125
115
110
95
90
80
70
65
60
Zener Voltage
Type
1N4727
1N4728
1N4729
1N4730
1N4731
1N4732
1N4733
1N4734
1N4735
1N4736
1N4737
1N4738
1N4739
1N4740
1N4741
1N4742
1N4743
1N4744
1N4745
1N4746
1N4747
1N4748
1N4749
1N4750
1N4751
1N4752
1N4753
1N4754
1N4755
1N4756
1N4757
1N4758
1N4759
1N4760
1N4761
3)
Dynamic Resistance 1)
Reverse Current
Maximum
Regulator
Current 2)
IZM (mA)
275
275
252
234
217
193
178
162
146
133
121
110
100
91
83
76
69
61
57
50
45
41
38
34
30
27
25
23
22
19
18
16
14
13
12
1)
The dynamic resistance is derived from the 60 Hz AC voltage which results when an AC current having an RMS value equal to 10% of
the Zener Current (IZT or IZK) is superimposed on IZT or IZK. Dynamic resistance is measured at two points to insure a sharp knee on the
breakdown curve and to eliminate unstable units.
2)
3)
Tested with pulses tp = 20 ms.
4)
The rating listed in the electrical characteristics table is maximum peak, non-repetitive, reverse surge current of 1/2 square wave or
equivalent sine wave pulse of 1/120 second duration superimposed on the test current IZT.
Dated : 10/09/2009
40
50
60
70
8
10
80
9
90
IN4764
7
IN4763
6
IN4762
5
IN4761
40
30
IN4741
IN4740
IN4739
IN4738
IN4737
IN4736
50
IN4760
30
4
IN4758
50
3
IN4755
2
IN4757
40
1
IN4759
Iz
IN4735
IN4734
IN4733
IN4731
IN4732
IN4730 IN47
29
60
IN4756
70
IN4727
IN4728
90
IN4750
IN4751
IN4752
IN4746
IN4747
IN4748
IN4749
80
IN4753
IN4754
mA
IN4743
IN4744
IN4745
Iz
IN4742
1N4727...1N4761
Tj =constant(pulsed)
Breakdowm characteristics
mA
100
IN...
Tj =25 oC
10
100
11
12
Vz
IN...
Tj =25 oC
Dated : 10/09/2009
120
Vz
1N4727...1N4761
1.0
250
200
to Ambient (°C/W)
Pd. Total Power Dissipation (W)
0.8
0.6
0.4
100
50
R
JA
0.2
150
200
1000
10
15
30
Differential Zener Impedance (Ω)
1000
f=1MHz
TA=25°C
Cj , Diode Capacitance (pF)
5
I, Lead Length (mm)
Fig. 2 Typical Thermal Resistance vs. Lead Length
TA, Ambient Temperature
Fig. 1 Power Dissipation vs Ambient Temperature
100
VR=0V
VR=2V
VR=5V
VR=20V
VR=30V
10
1
40
50
60
Vz, Zener Voltage (V)
Fig. 3 Junction Capacitance vs Zener Voltage
Iz=1mA
2mA
100
5mA
10mA
20mA
10
1
1
10
100
Fig. 4 Typical Zener Impedance vs. Zener Voltage
Dated : 10/09/2009
很抱歉,暂时无法提供与“1N4728A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.15001
- 100+0.14001
- 300+0.13001
- 500+0.12001
- 2000+0.11501
- 5000+0.11201
