SLG59M1658V
SLG59M1658V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFDFN8
    A 1.6 MM 125C-RATED, 2.5 A INT
SLG59M1658V 数据手册
SLG59M1658V An Ultra-small 1.6 mm2, 17 mΩ, 2.5 A, 125°C-Rated Internally-protected Integrated Power Switch with Discharge General Description Pin Configuration VDD 1 ON 2 D 3 D 4 Using a proprietary MOSFET design, the SLG59M1658V achieves a stable 17 mΩ RDSON across a wide input voltage range. In addition, the SLG59M1658V’s package also exhibits low thermal resistance for high-current operation using Silego’s proprietary CuFET technology. Fully specified over the -40 °C to 125 °C temperature range, the SLG59M1658V is packaged in a space-efficient, low thermal resistance, RoHS-compliant 1.0 mm x 1.6 mm STDFN package. Features • 1.0 x 1.6 x 0.55 mm STDFN 8L package (2 fused pins for drain and 2 fused pins for source) • Logic level ON pin capable of supporting 0.85 V CMOS Logic • User selectable ramp rate with external capacitor • 17 mΩ RDSON while supporting 2.5 A • Discharges load when off • Two Over Current Protection Modes • Short Circuit Current Limit • Active Current Limit • Over Temperature Protection • Pb-Free / Halogen-Free / RoHS compliant • Operating Temperature: -40 °C to 125°C • Operating Voltage: 2.5 V to 5.5 V SLG59M1658V The SLG59M1658V is a high performance 17 mΩ, 2.5 A single-channel nFET integrated power switch which can operate with a 2.5 V to 5.5 V VDD supply to switch power rails from as low as 0.9 V up to the supply voltage. The SLG59M1658V incorporates two-level overload current protection, thermal shutdown protection, fast output voltage discharge, and in-rush current control which can easily be adjusted by a small external capacitor. 8 GND 7 CAP 6 S 5 S 8-pin STDFN (Top View) Applications • Notebook Power Rail Switching • Tablet Power Rail Switching • Smartphone Power Rail Switching Block Diagram 2.5 A @ 17 mΩ D CIN VDD +2.5 to 5.5 V CAP CSLEW 4 nF S CLOAD Charge Pump Linear Ramp Control Over Current and Over Temperature Protection ON CMOS Input GND Silego Technology, Inc. 000-0059M1658-100 Rev 1.00 Revised February 23, 2017 SLG59M1658V Pin Description Pin # Pin Name Type Pin Description 1 VDD PWR With an internal 1.8 V UVLO threshold, VDD supplies the power for the operation of the power switch and internal control circuitry. Bypass the VDD pin to GND with a 0.1 µF (or larger) capacitor. 2 ON Input A low-to-high transition on this pin initiates the operation of the SLG59M1658V’s state machine. ON is a CMOS input with VIL < 0.25 V and VIH > 0.85 V thresholds. While there is an internal pull-down circuit to GND (~4 MΩ), connect this pin directly to a general-purpose output (GPO) of a microcontroller, an application processor, or a system controller. Do not allow this pin to be open-circuited. 3, 4 D MOSFET Drain terminal connection of the n-channel MOSFET (2 pins fused for VD). Connect at least a low-ESR 0.1 µF capacitor from this pin to ground. Capacitors used at VD should be rated at 10 V or higher. 5, 6 S MOSFET Source terminal connection of the n-channel MOSFET (2 pins fused for VS). Connect a low-ESR capacitor from this pin to ground and consult the Electrical Characteristics table for recommended CLOAD range. Capacitors used at VS should be rated at 10 V or higher. 7 CAP Input A low-ESR, stable dielectric, ceramic surface-mount capacitor connected from CAP pin to GND sets the VS slew rate and overall turn-on time of the SLG59M1658V. For best performance CSLEW value should be ≥ 1.5 nF and voltage level should be rated at 10 V or higher. 8 GND GND Ground connection. Connect this pin to system analog or power ground plane. Ordering Information Part Number Type Production Flow SLG59M1658V STDFN 8L Extended Industrial, -40 °C to 125 °C SLG59M1658VTR STDFN 8L (Tape and Reel) Extended Industrial, -40 °C to 125 °C 000-0059M1658-100 Page 2 of 14 SLG59M1658V Absolute Maximum Ratings Parameter VDD Description Conditions Power Supply Min. Typ. Max. Unit -- -- 7 V VD to GND Power Switch Input Voltage to GND -0.3 -- 7 V VS to GND Power Switch Output Voltage to GND -0.3 -- VD V -0.3 -- 7 V ON and CAP to ON and CAP Pin Voltages to GND GND -65 -- 150 °C ESDHBM TS ESD Protection Human Body Model 2000 -- -- V ESDCDM ESD Protection Charged Device Model 1000 -- -- V MSL θJA WDIS Storage Temperature Moisture Sensitivity Level Thermal Resistance 1 1.0 x 1.6 mm, 8L STDFN; Determined using 1 in2, 1 oz. copper pads under each VD and VS terminals and FR4 pcb material Package Power Dissipation MOSFET IDS Max Continuous Switch Current MOSFET IDSPK Peak Current from Drain to Source For no more than 1 ms with 1% duty cycle -- 74 -- °C/W -- -- 0.4 W -- -- 2.5 A -- -- 3.5 A Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = -40 to 125 °C (unless otherwise stated) Parameter VDD VDD_UVLO IDD RDSON VD IFET_OFF Description Conditions Min. Typ. Max. Unit Power Supply Voltage -40 to 125°C 2.5 -- 5.5 V VDD Undervoltage Lockout Threshold VDD ↑ -- 1.8 -- V when OFF; TA = 70 °C; VS = 0 V; VD = VDD = 5.5 V -- -- 1 μA when OFF; TA = 85 °C; VS = 0 V; VD = VDD = 5.5 V -- -- 1 μA when OFF; TA = 125 °C; VS = 0 V; VD = VDD = 5.5 V -- -- 1 μA when ON, no Load -- 75 100 μA Power Supply Current (PIN 1) Static Drain to Source ON Resistance TA 25°C @ 100 mA -- 17 20.4 mΩ TA 85°C @ 100 mA -- 20.5 24 mΩ TA 125°C @ 100 mA -- 24 28.8 mΩ 0.9 -- VDD V VD = VDD = 5.5 V; VS = 0 V; ON = 0 V; TA = 70°C -- -- 1 μA VD = VDD = 5.5 V; VS = 0 V; ON = 0 V; TA = 85°C -- -- 1 μA VD = VDD = 5.5 V; VS = 0 V; ON = 0 V; TA = 125°C -- -- 5 μA Drain Voltage MOSFET OFF Leakage Current 000-0059M1658-100 Page 3 of 14 SLG59M1658V Electrical Characteristics (continued) TA = -40 to 125 °C (unless otherwise stated) Parameter TON_Delay Description Conditions ON pin Delay Time 50% ON to Ramp Begin Min. -- Slew Rate Example: CSLEW (PIN 7) = 4 nF, VDD = VD = 5 V, CLOAD = 10 μF, RLOAD = 20 Ω Max. 200 -- -- 3.3 V/ms -- V/ms Configurable 1 50% ON to 90% VS Unit μs Configurable 1 10% VS to 90% VS VS(SR) Typ. ms Example: CSLEW (PIN 7) = 4 nF, VDD = VD = 5 V, CLOAD = 10 μF, RLOAD = 20 Ω -- 1.50 -- ms OFF Delay Time 50% ON to VS Fall Start, VDD = VD = 5 V, no CLOAD, RLOAD = 20 Ω -- 8 -- μs TFALL VS Fall Time 90% VS to 10% VS, VDD = VD = 5 V, no CLOAD, RLOAD = 20 Ω -- 3.3 -- μs CLOAD Output Load Capacitance CLOAD connected from VS to GND -- -- 500 μF Discharge Resistance 100 200 300 Ω ON_VIH High Input Voltage on ON pin 0.85 -- VDD V ON_VIL Low Input Voltage on ON pin TTotal_ON TOFF_Delay RDIS Total Turn On Time -0.3 0 0.25 V Active Current Limit (IACL) MOSFET will automatically limit current when VS > 250 mV -- 4.5 -- A Short Circuit Current Limit (ISCL) MOSFET will automatically limit current when VS < 250 mV -- 0.5 -- A Thermal shutoff turn-on temperature -- 150 -- °C THERMOFF Thermal shutoff turn-off temperature -- 130 -- °C THERMTIME Thermal shutoff time -- -- 1 ms ILIMIT THERMON Notes: 1. Refer to table for configuration details. 000-0059M1658-100 Page 4 of 14 SLG59M1658V TTotal_ON, TON_Delay and Slew Rate Measurement ON 50% ON 50% ON TOFF_Delay 90% VS VS 90% VS TON_Delay 10% VS 10% VS VS(SR) (V/ms) TFALL TTotal_ON Note: Rise and Fall times of the ON signal are 100 ns 000-0059M1658-100 Page 5 of 14 SLG59M1658V Typical Performance Characteristics RDSON vs. VDD, and Temperature RDSON vs. VD and VDD 000-0059M1658-100 Page 6 of 14 SLG59M1658V VS(SR) VS(SR) vs. Temperature, VD, VDD, and CSLEW TTotal_ON vs. CSLEW, VD, VDD, and Temperature 000-0059M1658-100 Page 7 of 14 SLG59M1658V Typical Operation Waveforms ON VS Figure 1. Typical Turn ON operation waveform for VDD = VD = 5 V, CSLEW = 4 nF, CLOAD = 10 µF, RLOAD = 20 Ω ON VS Figure 2. Typical Turn ON operation waveform for VDD = VD = 5 V, CSLEW = 12 nF, CLOAD = 10 µF, RLOAD = 20 Ω 000-0059M1658-100 Page 8 of 14 SLG59M1658V ON VS Figure 3. Typical Turn OFF operation waveform for VDD = VD = 5 V, CSLEW = 4 nF, no CLOAD, RLOAD = 20 Ω ON VS Figure 4. Typical Turn OFF operation waveform for VDD = VD = 5 V, CSLEW = 4 nF, CLOAD = 10 µF, RLOAD = 20 Ω 000-0059M1658-100 Page 9 of 14 SLG59M1658V SLG59M1658V Power-Up/Power-Down Sequence Considerations To ensure glitch-free power-up under all conditions, apply VDD first, followed by VD after VDD exceeds 1 V. Then allow VD to reach 90% of its max value before toggling the ON pin from Low-to-High. Likewise, power-down in reverse order. If VDD and VD need to be powered up simultaneously, glitching can be minimized by having a suitable load capacitor. A 10 μF CLOAD will prevent glitches for rise times of VDD and VD less than 2 ms. If the ON pin is toggled HIGH before VDD and VD have reached their steady-state values, the IPS timing parameters may differ from datasheet specifications. The slew rate of output VS follows a linear ramp set by a capacitor connected to the CAP pin. A larger capacitor value at the CAP pin produces a slower ramp, reducing inrush current from capacitive loads. SLG59M1658V Current Limiting The SLG59M1658V has two modes of current limiting, differentiated by the output (Source pin) voltage. 1. Standard Current Limiting Mode (with Thermal Protection) When V(S) > 250 mV, the output current is initially limited to the Active Current Limit specification given in the Electrical Characteristics table. The current limiting circuit is very fast and responds within a few micro-seconds to sudden loads. When overload is sensed, the current limiting circuit increases the FET resistance to keep the current from exceedng the Active Current Limit. However, if an overload condition persists, the die temperature rise due to the increased FET resistance while at maximum current can activate Thermal Protection. If the die temperature exceeds the THERMON specification, the FET is shut completely OFF, allowing the die to cool. When the die cools to the THERMOFF temperature, the FET is allowed to turn back on. This process may repeat as long as the overload condition is present. 2. Short Circuit Current Limiting Mode (with Thermal Protection) When V(S) < 250 mV (which is the case with a hard short, such as a solder bridge on the power rail), the current is limited to approximately 500 mA. Thermal Protection is also present, but since the Short Circuit Current Limit is much lower than Standard Current Limit, activation may only occur at higher ambient temperatures. For more information on Silego GreenFET3 integrated power switch features, please visit our Application Notes page at our website and see App Note “AN-1068 GreenFET3 Integrated Power Switch Basics”. 000-0059M1658-100 Page 10 of 14 SLG59M1658V Package Top Marking System Definition ABC Serial Number Pin 1 Identifier ABC - Part Serial Number Field each A, B, and C character can be A-Z and 0-9 000-0059M1658-100 Page 11 of 14 SLG59M1658V Package Drawing and Dimensions 8 Lead STDFN Package 1.0 x 1.6 mm (Fused Lead) 000-0059M1658-100 Page 12 of 14 SLG59M1658V Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] STDFN 8L 1x1.6mm 0.4P FC Green 8 1.0 x 1.6 x 0.55 3,000 3,000 178 / 60 100 400 Trailer (min) Pockets Length [mm] Tape Width [mm] 100 400 8 Part Pitch [mm] 4 Carrier Tape Drawing and Dimensions Pocket BTM Pocket BTM Package Length Width Type STDFN 8L 1x1.6mm 0.4P FC Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 1.12 1.72 0.7 4 4 1.55 1.75 3.5 8 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 0.88 mm3 (nominal). More information can be found at www.jedec.org. 000-0059M1658-100 Page 13 of 14 SLG59M1658V Revision History Date Version 2/23/2017 1.00 000-0059M1658-100 Change Production Release Page 14 of 14
SLG59M1658V 价格&库存
很抱歉,暂时无法提供与“SLG59M1658V”相匹配的价格&库存,您可以联系我们找货
