SLG88104V
SLG88104V
    DIALOGSEMICONDUCTOR(戴乐格)
    UFQFN20
    IC CMOS 4 CIRCUIT 20STQFN
SLG88104V 数据手册
SLG88103/4 Rail to Rail I/O 375 nA/Amp Dual/Quad CMOS Op Amps with Power Down General Description Pin Configurations The SLG88103/4 is a wide voltage range, 375 nA Dual/Quad Channel CMOS Input Operational Amplifier capable of rail-to-rail input and output operation. Each Amplifier can be individually powered down. Features • • • • • • • • • • • • Low Quiescent Current: 375 nA per Amplifier (typ) Low Offset Voltage: ±200 µV (typ) Zero-Crossover Low Offset Drift: 1 µV/˚C (typ) DC Precision: • PSRR: 115 dB • CMRR: 100 dB • AOL: 120 dB Gain-Bandwidth Product: 10 kHz (typ) Rail to Rail Input/Output Supply Voltage: 1.71 V to 5.5 V Tiny Package: 10-pin 2 x 2 mm STDFN 20-pin 2 x 3.5 mm STQFN Industrial Temperature Range: -40 ˚C to 85 ˚C Typical Applications • • • • • • • • • Battery-Powered Devices Portable Devices Wearable Products Gas Sensors Pressure Sensors Medical Monitors Smoke Detectors Active RFID Reader Energy Harvester SLG88103 PD1 1 10 OUT1 2 9 OUT2 IN-1 3 8 IN-2 IN+1 4 7 IN+2 VSS 5 6 PD2 VDD 10-pin STDFN (Top View) SLG88104 PD1 VDD OUT1 1 18 OUT4 IN-1 2 17 IN-4 IN+1 3 16 IN+4 20 19 VSS 4 15 PD4 PD2 5 14 VDD OUT2 IN-2 IN+2 6 7 9 8 OUT3 13 10 12 IN-3 IN+3 11 VSS PD3 20-pin STQFN (Top View) Example Application Circuit: Non-Inverting Amplifier + GreenPAK with Wake-Sleep Controller SLG88103/4 Silego Technology, Inc. 000-0088103/4-101 Rev 1.01 Revised March 13, 2017 SLG88103/4 Pin Description Pin # 20L 10L STQFN STDFN Pin Name Type Pin Description 1 2 OUT1 O Analog Output (Op Amp 1) 2 3 IN-1 I Inverting Input (Op Amp 1) 3 4 IN+1 I Non-inverting Input (Op Amp 1) 4 5 VSS GND 5 6 PD2 I Power Down Input (Op Amp 2) When PD pin is high, the respective amplifier is powered down. 6 9 OUT2 O Analog Output (Op Amp 2) 7 8 IN-2 I Inverting Input (Op Amp 2) 8 7 IN+2 I Non-inverting Input (Op Amp 2) 9 -- VSS GND 10 -- PD3 I Power Down Input (Op Amp 3) When PD pin is high, the respective amplifier is powered down. Negative Power Supply Negative Power Supply 11 -- IN+3 I Non-inverting Input (Op Amp 3) 12 -- IN-3 I Inverting Input (Op Amp 3) 13 -- OUT3 O Analog Output (Op Amp 3) 14 10 VDD PWR 15 -- PD4 I Power Down Input (Op Amp 4) When PD pin is high, the respective amplifier is powered down. 16 -- IN+4 I Non-inverting Input (Op Amp 4) 17 -- IN-4 I Inverting Input (Op Amp 4) 18 -- OUT4 O Analog Output (Op Amp 4) 19 -- VDD PWR 20 1 PD1 I Power Supply Power Supply Power Down Input (Op Amp 1) When PD pin is high, the respective amplifier is powered down. Ordering Information Part Number Type Production Flow SLG88103V 10-pin STDFN Industrial, -40 °C to 85 °C SLG88103VTR 10-pin STDFN (Tape and Reel) Industrial, -40 °C to 85 °C SLG88104V 20-pin STQFN Industrial, -40 °C to 85 °C SLG88104VTR 20-pin STQFN (Tape and Reel) Industrial, -40 °C to 85 °C 000-0088103/4-101 Page 2 of 22 SLG88103/4 Absolute Maximum Ratings Parameter Description Min. Typ. Max. Unit Voltage on VDD pin relative to GND -0.3 -- 6.0 V TA Operating Range -40 -- 85 ˚C θJA Thermal Resistance -- 80 -- ˚C/W TS Storage Temperature -65 -- 150 ˚C TJ Junction Temperature -- -- 150 ˚C ESD Protection (Human Body Model) 2000 -- -- V ESD Protection (Charged Device Model) 500 -- -- V VDD ESDHBM ESDCDM MSL Moisture Sensitivity Level 1 Note: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect reliability. Electrical Characteristics TA = 25 °C, VDD = 1.71 V to 5.5 V, VSS = GND, VCM = VDD/2, VOUT = VDD/2, VL = VDD/2, RL = 1 MΩ to VL, unless otherwise stated. Symbol Description Conditions Min Typ Max Unit VCM = VDD/2 -1000 ±200 1000 μV Input Offset Voltage VCM = VDD/2; TA = -40 ˚C to 85 ˚C -1100 ±250 1100 μV VCM = VSS; TA = -40 ˚C to 85 ˚C -2400 ±350 2400 μV VCM = VDD/2; TA = -40 ˚C to 85 ˚C -4 ±1 4 μV/˚C VCM = VSS; TA = -40 ˚C to 85 ˚C -10 ±2 10 μV/˚C Input Offset VOS dVOS/dT dVOS/Time PSRR CS Offset Drift with Temperature 10 Year Offset Drift Power Supply Rejection Ratio Channel Separation TA = 85˚C; VDD = 3.3 V -30 -- +30 μV TA = 85˚C; VDD = 5.0 V -40 -- +40 μV VCM = VDD/2 TA = -40 ˚C to 85 ˚C 95 115 -- dB VCM = VSS TA = -40 ˚C to 85 ˚C 85 100 -- dB VDD = 5 V, f = 10 Hz -- 120 -- dB VDD = 5 V, f = 1 kHz -- 95 -- dB Input Voltage Range VCMR CMRR Input Common-Mode Voltage Range TA = -40 ˚C to 85 ˚C Common-Mode Rejection Ratio VSS -- VDD V VSS + 0.8 V < VCM < VDD - 0.8 V, TA = -40 ˚C to 85 ˚C 65 100 -- dB VSS < VCM < VSS + 0.8 V, VDD - 0.8 V < VCM < VDD, TA = -40 ˚C to 85 ˚C 50 75 -- dB -- 2 -- pA -- 320 500 pA Input Bias Current and Impedance IB Input Bias Current1 000-0088103/4-101 TA = 85 ˚C Page 3 of 22 SLG88103/4 Electrical Characteristics (continued) TA = 25 °C, VDD = 1.71 V to 5.5 V, VSS = GND, VCM = VDD/2, VOUT = VDD/2, VL = VDD/2, RL = 1 MΩ to VL, unless otherwise stated. Symbol Description IOS Input Offset Current2 RCM Common Mode Input Resistance Conditions Min Typ -- ±0.3 -- pA TA = 85 ˚C -- ±20 -- pA -- 1013 -- Ω -- 13 -- Ω 10 Max Unit RDIFF Differential Input Resistance CCM Input Capacitance Common-Mode -- 4.3 -- pF CDIFF Input Capacitance Differential -- 6 -- pF RL = 1 MΩ; VSS + 0.1 V ≤ VOUT ≤ VDD - 0.1 V 100 120 -- dB RL = 50 kΩ; VSS + 0.5 V ≤ VOUT ≤ VDD - 0.5 V 100 120 -- dB RL = 50 kΩ; TA = 85 ˚C; VSS + 0.1 V ≤ VOUT ≤ VDD - 0.1 V 80 100 -- dB VSS + 5 -- VDD - 5 mV VSS + 100 -- VDD - 100 mV 3.8 4.5 -- mA 8.5 10 -- mA Open-Loop Gain AOL DC Open Loop Voltage Gain Output VOH, VOL VOSR ISC CLOAD Maximum Voltage Swing RL= 50 kΩ Linear Output Swing Range VOVR from Rail Short-circuit Current VDD = 1.71 V VDD = 3.0 V to 5.5 V Capacitive Load Drive See Typical Performance Charts Power Supply VDD IQ Supply Voltage Quiescent Current (Per Amplifier) Guaranteed by PSRR Test 1.71 -- 5.5 V -- 0.38 0.55 μA TA = -40 ˚C to 85 ˚C -- 0.4 0.8 μA PDx = VDD -- 1 -- nA Frequency Response GBW Gain Bandwidth Product G = +1 V/V -- 10 -- kHz PM Phase Margin G = +1 V/V -- 54 -- ˚ SR Slew Rate RL= 50 kΩ 2.4 5.0 -- V/ms tOR Overload Recovery Time TA = -40 ˚C to 85 ˚C; RL= 50 kΩ -- 350 -- μs en Input Voltage Noise f = 0.1 to 10 Hz -- 6.5 -- μVP-P Vn Input Voltage Noise Density f =1 kHz -- 195 -- nV/√Hz In Input Current Noise Density f =1 kHz -- < 10 -- fA/√Hz Noise Note: 1. Part is measured to be less than 1 μA during production test. 2. Guaranteed by design, not tested in production. 000-0088103/4-101 Page 4 of 22 SLG88103/4 Typical Performance Charts TA = 25 °C, VDD = 5.0 V, VSS = GND, VCM = VDD/2, VOUT = VDD/2, VL = VDD/2, RL = 1 MΩ to VL , CL = 80 pF, unless otherwise stated. 18% 24% 164 Samples VDD = 1.71 and 5.5V VCM = VSS 22% Percentage of Occurrences Percentage of Occurrences 16% 14% 12% 10% 8% 6% 4% 2% 124 Samples TA = (-40;+25)°C and (+25;+85)°C VDD = 3.3V ; VCM = VSS 20% 18% 16% 14% 12% 10% 8% 6% 4% 0% 800 700 600 500 400 300 200 0 100 -100 -200 -300 -400 -500 -600 -800 -700 2% 0% -3 Input Offset Voltage (V) 250 250 Input offset voltage (V) Input Ofset voltage (V) 300 TA = -40°C TA = +25°C TA = +85°C 100 50 1 2 3 4 5 6 7 TA = -40°C TA = +25°C 200 TA = +85°C 150 100 50 0 1 2 3 4 Common Mode Input Voltage (V) 5 0.0 6 Fig 2. Input Offset Voltage vs. Common Mode Input Voltage VDD = 5.5 V. 0.8 130 0.7 120 TA = +85°C 0.6 0.5 TA = +25°C 0.4 0.3 TA = -40°C 0.2 0.1 0.5 1.0 Common mode input voltage (V) 1.5 Fig 5. Input Offset Voltage vs. Common Mode Input Voltage VDD = 1.71 V. TA = +25°C TA = -40°C 110 DC Open Loop Gain (dB) Quiescent Current (A/Amplifier) 0 Fig 4. Input Offset Voltage Temperature Drift Distribution VCM = VSS; VDD = 3.3 V; TA = -40˚C to 85˚C. 300 150 -1 Input Offset Voltage Temperature Drift (V/°C) Fig 1. Input Offset Voltage Drift Distribution VCM = VSS; VDD = 1.71 V and 5.5 V; TA = 25˚C. 200 -2 TA = +85°C 100 90 80 70 60 50 0 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 Power Supply Voltage (V) Fig 3. Quiescent Current vs. Power Supply Voltage 000-0088103/4-101 -0.5 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 Common mode input voltage (V) Fig 6. DC Open Loop Gain vs. Common Mode Input Voltage VDD = 3.3 V. Page 5 of 22 SLG88103/4 TA = 25 °C, VDD = 5.0 V, VSS = GND, VCM = VDD/2, VOUT = VDD/2, VL = VDD/2, RL = 1 MΩ to VL , CL = 80 pF, unless otherwise stated. 50 1200 40 80 Gain (dB) 30 70 20 60 GAIN 10 50 0 40 -10 Phase (°) PHASE Input Voltage Noise Density (nV/Hz) 90 1000 Frequency (Hz) 800 600 400 200 0 30 100 1000 0 10000 Fig 7. Open Loop Gain and Phase vs. Frequency VDD = 3.3 V. 1 10 Frequency (Hz) 100 1,000 Fig 10. Input Noise Voltage Density vs. Frequency 100 90 PSRR+ 70 60 PSRR- 1V/div CMRR, PSRR (dB) 80 50 CMRR 40 30 20 10 0 10 100 1,000 Frequency (Hz) 10,000 Time (1s/div) Fig 8. CMRR, PSRR vs. Frequency VDD = 3.3 V. Fig 11. 0.1 Hz to 10 Hz Noise 140 14 Output Short Circuit Current (mA) Channel Separation (dB) 120 100 80 60 40 20 0 Source 12 10 Sink 8 6 4 2 0 10 100 1000 10000 Frequency (Hz) 100000 Fig 9. Channel Separation vs. Frequency 000-0088103/4-101 1000000 1.0 1.5 2.0 2.5 3.0 3.5 4.0 Power supply voltage (V) 4.5 5.0 5.5 Fig 12. Output Short Circuit Current vs. VDD Page 6 of 22 SLG88103/4 TA = 25 °C, VDD = 5.0 V, VSS = GND, VCM = VDD/2, VOUT = VDD/2, VL = VDD/2, RL = 1 MΩ to VL , CL = 80 pF, unless otherwise stated. 15 14 100 10 Gain Bandwidth Product (kHz) Input Bias and Offset Currents (pA) 1000 Ib |Ios| 1 0.1 0.01 -20 0 20 40 60 Ambient Temperature (°C) 80 TA = +25°C 10 9 TA = -40°C 8 7 6 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Power supply voltage (V) 5.0 5.5 Fig 16. Gain Bandwidth Product vs. Power Supply Voltage 15 VDD = 5.5 V 14 100 TA = +85°C Gain Bandwidth Product (kHz) Input Bias and Offset Currents (pA) TA = +85°C 11 100 Fig 13. Input Bias, Offset Currents vs. TA VDD = 3.3 V. 10 1 TA = +25°C 0.1 Ib |Ios| 13 Vdd=5.5V 12 11 VDD = 1.71V 10 9 8 7 6 5 0.01 0.0 1.0 2.0 3.0 4.0 Input Common Mode Voltage (V) -40 5.0 -20 0 20 40 60 80 100 Ambient temperature (°C) Fig 14. Input Bias, Offset Currents vs. VCM VDD = 5.5 V. Fig 17. Gain Bandwidth Product vs. Ambient Temperature 10 700 TA = +55°C 600 9 TA = +85°C 8 TA = +25°C 500 Low-to-High 7 Slew Rate (V/ms) Input Current (pA) 12 5 -40 1000 13 400 300 200 6 5 High-to-Low 4 3 2 100 1 TA = -40°C 0 0 -0.3 -0.2 -0.2 -0.1 -0.1 Input Common Mode Voltage (V) Fig 15. Input Current vs. VCM (below VSS) VDD = 5.5 V. 000-0088103/4-101 0.0 -40 -20 0 20 40 60 80 100 Ambient temperature (°C) Fig 18. Slew Rate vs. Ambient Temperature G = 1 V/V; RL = 50 kΩ Page 7 of 22 SLG88103/4 10mV/div 10mV/div TA = 25 °C, VDD = 5.0 V, VSS = GND, VCM = VDD/2, VOUT = VDD/2, VL = VDD/2, RL = 1 MΩ to VL , CL = 80 pF, unless otherwise stated. Time (250s/div) Time (250s/div) Fig 22. Small Signal Non-inverting Step Response G = 1 V/V; RL = 50 kΩ; CL = 60 pF. 500mV/div 500mV/div Fig 19. Small Signal Inverting Step Response G = -1 V/V; RL = 50 kΩ; CL = 60 pF. Time (1ms/div) Time (1ms/div) Fig 23. Large Signal Non-inverting Step Response G = 1 V/V; RL = 50 kΩ; CL = 60 pF. 1V/div 1V/div Fig 20. Large Signal Inverting Step Response G = -1 V/V; RL = 50 kΩ; CL = 80 pF. Time (1ms/div) Fig 21. Inverting Overload Recovery G = -1 V/V; RL = 50 kΩ; CL = 60 pF. 000-0088103/4-101 Time (1ms/div) Fig 24. Non-Inverting Overload Recovery G = 1 V/V; RL = 50 kΩ; CL = 60 pF. Page 8 of 22 SLG88103/4 TA = 25 °C, VDD = 5.0 V, VSS = GND, VCM = VDD/2, VOUT = VDD/2, VL = VDD/2, RL = 1 MΩ to VL , CL = 80 pF, unless otherwise stated. 150 10mV/div DC Open Loop Gain (dB) 140 130 TA = +25°C 120 110 100 TA = +85°C 90 80 70 1.0 Time (250s/div) Fig 25. Small Signal Non-inverting Step Response G = 1 V/V; RL = 50 kΩ; CL = 10 nF. 1.5 2.0 2.5 3.0 3.5 4.0 Power supply voltage (V) 4.5 5.0 5.5 Fig 28. DC Open Loop Gain vs. Power Supply Voltage RL = 50 kΩ 60 1,000 Overshoot Undershoot Output Voltage Swing from Rail (mV) Overshoot (%) 50 40 VIN = 100 mVp-p 30 VIN = 40 mVp-p 20 10 VIN = 100 mVp-p 0 100 1,000 Capacitive load (pF) VDD = 5.5V 10 — VDD - VOH - - VOL - VSS 1 10,000 0.1 Fig 26. Small Signal Overshoot vs. Capacitive Load VDD = 3.3 V; VIN = 40 and 100 mV p-p; G = 1 V/V. 1 Output Load Current (mA) 10 Fig 29. Output Voltage Swing from Rail vs. IOUT VDD = 1.71 V and 5.5 V. 600 6 500 5 — VPDx — VOUT 4 400 Voltage(V) Overload Recovery Time (s) VDD = 1.71V 100 High-to-Low 300 Low-to-High 3 200 2 100 1 0 0 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 Power Supply Voltage (V) 5.0 5.5 6.0 Fig 27. Overload Recovery Time vs. Power Supply Voltage RL= 50 kΩ; G = 1 V/V. 000-0088103/4-101 0 5 10 15 20 25 Time (s) 30 35 40 Fig 30. Output Response to Power Down Signal G = 1 V/V; RL = 50 kΩ; CL = 20 pF; VIN = VS/2. Page 9 of 22 SLG88103/4 Applications Information The SLG88103/4 operates on a 1.71 V to 5.5 V power supply over a wide industrial temperature range from -40 °C to 85 °C. This dual/quad op amp chip has two/four active low enable pins used to individually power-up / power-down each op amp. Its common-mode range extends from 0 to VDD and its output swings from rail-to-rail. Input Protection Voltage spikes need to be controlled at the inputs of each operational amplifier in order to avoid damaging the device. Electrical events like electrostatic discharge can produce large voltages at these nodes. The SLG88103/4 has internal circuitry to protect the device from these events. If VIN exceeds VDD or drops below VSS, additional currents will flow through the internal ESD diodes and can damage the device even if the supplies are turned off. In this case we recommend placing a resistor in series to the input to limit current through the internal ESD diodes to 5 mA (or preferably less). Fig 31. ESD Protection . Driving Capacitive Loads Capacitive loads degrade circuit stability by decreasing the phase margin and bandwidth of the operational amplifier circuit. The SLG88103/4 can drive capacitive loads up to 10 nF at low loads. The amplifier’s output impedance and the capacitive load add phase lag to the system. This phase lag creates gain peaking in the frequency response and peaking/ringing in the output’s transient response. When large capacitive loads need to be driven, isolation resistors need to be used to increase the phase margin. This is done by increasing the output load impedance at higher frequencies. After selecting an isolation resistor value, verify that the frequency peaking and transient overshoot and ringing have been reduced. Fig 32. Capacitive Load Test Circuit. 000-0088103/4-101 Page 10 of 22 SLG88103/4 Low Power Considerations The SLG88103/4 features low quiescent current at 375 nA per amplifier, as well as extremely high-impedance CMOS inputs. To take most advantage of such low power features, high impedance external components should be used. We recommend using low-leakage capacitors (such as ceramic). Other types of capacitors (such as aluminum dielectric) can leak at uA levels and consume more quiescent power than the op-amp itself! High value resistors are needed to keep power consumption low, as well as to avoid gain loss and non-linearities due to loading effects on the ultra-low power-stage of the op amp. On the other hand, higher resistances increase thermal noise and sensitivity to external interference. We recommend impedances between 100 kΩ and 500 kΩ in gain/feedback networks to achieve balanced performance given the ultra-low power characteristics of SLG88103/4. PCB Layout For proper PCB layout, place a 100 nF decoupling capacitor close to the VDD pin of the SLG88103/4. To improve sensitive system performance, keep trace lengths similar on the positive and negative inputs of the op amp. Keep feedback resistors as close to the op amp and as short as possible. In addition, remove the PCB ground plane from under the inputs and outputs of the op amp. For low current applications, board leakage currents on sensitive, high impedance inputs can degrade signal integrity. To maximize system performance, use guard rings / shields around these high impedance op amp inputs. For non-inverting op amps, IN+ should have a guard ring driven to the voltage of IN- by a low impedance source. Similarly, the guard ring around IN- should be driven to IN+ for an inverting amplifier. The IN- and IN+ nodes for non-inverting and inverting amplifiers respectively can be used as low impedance voltage sources. This is because these nodes are effectively low impedance nodes due to op amp feedback properties. For a non-inverting amplifier, leakage current on IN+ will produce a voltage on the input that will be amplified to the op amp’s output. On the other hand, the op amp will fight changes in voltage on IN- to match the voltage potential at IN+. These guard rings should be used on both sides of the PCB to help sink stray currents on the PCB before the currents can reach the input pins of the op amp and to minimize stray capacitance. Proper Setup for Unused Op Amps For an unused op amp on the SLG88103/4, connect the op amp as a voltage follower with the input tied to ground and it’s enable pin tied to VDD. An example circuit using one of the op amps is shown below. Fig 33. Unused Op Amp Setup. Application Examples The SLG88103/4 excels in low-power applications that operate at low frequencies. Please see the “Application Notes” section of this datasheet for application examples which use the SLG88103/4. 000-0088103/4-101 Page 11 of 22 SLG88103/4 Design Resources 1. Spice Macro Model The most recent SPICE model is available on Silego’s website at www.silego.com. This model is intended for simulation purposes only and shouldn’t be used in place of hardware testing to verify proper functionality in a full system. 2. Application Notes For more information on the topics discussed in this datasheet and applications of this device, please see the following applications notes available online at our Application Notes Page. New Application Notes are added regularly. AN-1106 Custom Instrumentation Amplifier Design 3. Design Support Please contact a Silego Representative at our Contact Page for more information on the SLG88103/4. They will be happy to assist you by answering additional questions and by offering design support for projects relating to the SLG88103/4 and Silego’s GreenPAK devices. 4. Op Amp + GreenPAK EVB The OP AMP+GreenPAK EVB provides convenient breakout access for various IC’s in Silego’s Op Amp and GreenPAK product families. Please see the OP AMP+EVB Layout Guide for more information on which GreenPAK devices and op amps can be placed on this PCB. Fig 34. Op Amp + GreenPAK EVB. 000-0088103/4-101 Page 12 of 22 SLG88103/4 Package Top Marking System Definition - SLG88103 Pin 1 Identifier PPA WWN R Part Code + Assembly Code Date Code + S/N Code Revision Code PP - Part ID Field WW - Date Code Field1 N - Lot Traceability Code Field1 A - Assembly Site Code Field 2 R - Part Revision Code Field2 Note 1: Each character in code field can be alphanumeric A-Z and 0-9 Note 2: Character in code field can be alphabetic A-Z 000-0088103/4-101 Page 13 of 22 SLG88103/4 Package Top Marking System Definition - SLG88104 Pin 1 Identifier PPPPP WWNNN ARR Part Code Date Code + LOT Code Assembly + Rev. Code PPPPP - Part ID Field WW - Date Code Field1 NNN - Lot Traceability Code Field1 A - Assembly Site Code Field2 RR - Part Revision Code Field2 Note 1: Each character in code field can be alphanumeric A-Z and 0-9 Note 2: Character in code field can be alphabetic A-Z 000-0088103/4-101 Page 14 of 22 SLG88103/4 Package Drawing and Dimensions - SLG88103 10 Lead STDFN Package JEDEC MO-252 000-0088103/4-101 Page 15 of 22 SLG88103/4 Package Drawing and Dimensions - SLG88104 20 Lead STQFN Package 000-0088103/4-101 Page 16 of 22 SLG88103/4 Recommended Land Pattern - SLG88103 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 2.2 mm3 (nominal). More information can be found at www.jedec.org. 000-0088103/4-101 Page 17 of 22 SLG88103/4 Recommended Land Pattern - SLG88104 Recommended Reflow Soldering Profile Please see IPC/JEDEC J-STD-020: latest revision for reflow profile based on package volume of 3.85 mm3 (nominal). More information can be found at www.jedec.org. 000-0088103/4-101 Page 18 of 22 SLG88103/4 Tape and Reel Specifications Max Units Leader (min) Nominal Reel & Package # of Package Size Hub Size Length Type Pins per Reel per Box Pockets [mm] [mm] [mm] Trailer (min) Pockets Length [mm] Tape Width [mm] Part Pitch [mm] STDFN 10L 2x2mm 0.4P COL Green 10 2 x 2 x 0.55 3000 3000 178 / 60 100 400 100 400 8 4 STQFN 20L 2x3.5mm 0.4P Green 20 2 x 3.5 x 0.55 5000 10000 330 /100 42 336 42 336 12 8 Carrier Tape Drawing and Dimensions - SLG88103 Package Type STDFN 10L 2x2mm 0.4P COL Green Pocket BTM Pocket BTM Length Width Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 2.2 2.2 0.83 4 4 1.55 1.75 3.5 8 Refer to EIA-481 specification 000-0088103/4-101 Page 19 of 22 SLG88103/4 Carrier Tape Drawing and Dimensions Dimensions - SLG88104 Pocket BTM Pocket BTM Package Length Width Type STQFN 20L 2x3.5mm 0.4P Green Pocket Depth Index Hole Pitch Pocket Pitch Index Hole Diameter Index Hole Index Hole to Tape to Pocket Tape Width Edge Center A0 B0 K0 P0 P1 D0 E F W 2.2 3.8 0.8 4 8 1.5 1.75 5.5 12 Refer to EIA-481 specification 000-0088103/4-101 Page 20 of 22 SLG88103/4 Revision History Date Version 3/13/2017 1.01 Replaced Slew Rate vs. Ambient Temperature Chart Fixed Chart formatting for some charts. Fixed typos 3/1/2017 1.00 Production Release 000-0088103/4-101 Change Page 21 of 22 SLG88103/4 Silego Website & Support Silego Technology Website Silego Technology provides online support via our website at http://www.silego.com/.This website is used as a means to make files and information easily available to customers. For more information regarding Silego Green products, please visit: GreenPAK GreenFET GreenCLK http://greenpak.silego.com/ http://greenfet.silego.com/ http://greenclk.silego.com/ http://greenpak2.silego.com/ http://greenfet2.silego.com/ http://greenclk2.silego.com/ http://greenpak3.silego.com/ http://greenfet3.silego.com/ http://greenclk3.silego.com/ Products are also available for purchase directly from Silego at the Silego Online Store at http://store.silego.com/. Silego Technical Support Datasheets and errata, application notes and example designs, user guides, and hardware support documents and the latest software releases are available at the Silego website or can be requested directly at info@silego.com. For specific GreenPAK design or applications questions and support please send e-mail requests to GreenPAK@silego.com Users of Silego products can receive assistance through several channels: Online Live Support Silego Technology has live video technical assistance and sales support available at http://www.silego.com/. Please ask our live web receptionist to schedule a 1 on 1 training session with one of our application engineers. Contact Your Local Sales Representative Customers can contact their local sales representative or field application engineer (FAE) for support. Local sales offices are also available to help customers. More information regarding your local representative is available at the Silego website or send a request to info@silego.com Contact Silego Directly Silego can be contacted directly via e-mail at info@silego.com or user submission form, located at the following URL: http://support.silego.com/ Other Information The latest Silego Technology press releases, listing of seminars and events, listings of world wide Silego Technology offices and representatives are all available at http://www.silego.com/ THIS PRODUCT HAS BEEN DESIGNED AND QUALIFIED FOR THE CONSUMER MARKET. APPLICATIONS OR USES AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS ARE NOT AUTHORIZED. SILEGO TECHNOLOGY DOES NOT ASSUME ANY LIABILITY ARISING OUT OF SUCH APPLICATIONS OR USES OF ITS PRODUCTS. SILEGO TECHNOLOGY RESERVES THE RIGHT TO IMPROVE PRODUCT DESIGN, FUNCTIONS AND RELIABILITY WITHOUT NOTICE. 000-0088103/4-101 Page 22 of 22
SLG88104V 价格&库存
很抱歉,暂时无法提供与“SLG88104V”相匹配的价格&库存,您可以联系我们找货
SLG88104V
