TF2103M-TAH
TF2103M-TAH
    TFSS(德律风根)
    SOICN8_150MIL
    半桥栅极驱动器
TF2103M-TAH 数据手册
Advance Info TF2103M Half-Bridge Gate Driver Features Description  F  loating high-side driver in bootstrap operation to 600V  Drives two N-channel MOSFETs or IGBTs in a half bridge configuration  Designed for enhanced performance in noisy motor applications  290mA source/600mA sink output current capability  Outputs tolerant to negative transients  Internal dead time of 420ns to protect MOSFETs  Wide low side gate driver supply voltage: 10V to 20V  Logic input (HIN and LIN*) 3.3V capability  Schmitt triggered logic inputs  Undervoltage lockout for VCC (logic and low side supply)  Extended temperature range: -40°C to +125°C The TF2103M is a high voltage, high speed gate driver capable of driving N-channel MOSFETs and IGBTs in a half bridge configuration. TF Semiconductors’s high voltage process enables the TF2103M high side to switch to 600V in a bootstrap operation. The TF2103M logic inputs are compatible with standard TTL and CMOS levels (down to 3.3V) to interface easily with controlling devices. The driver outputs feature high pulse current buffers designed for minimum driver cross conduction. TF2103M has a fixed internal deadtime of 420ns (typical). The TF2103M is offered in a SOIC-8(N) and PDIP-8 package and operates over an extended -40 °C to +125 °C temperature range. Applications  Motor Controls  DC-DC Converters  AC-DC Inverters  Motor Drives SOIC-8(N) PDIP-8 Ordering Information Typical Application Up to 600V VCC VCC HIN HIN LIN* LIN* R4 COM www.tfsemi.com Jul 2019 VB HO TF2103M TO LOAD PART NUMBER PACKAGE PACK / Qty TF2103M-3AS PDIP-8 Tube / 50 TF2103M-TAU SOIC-8(N) Tube / 100 TF2103M-TAH SOIC-8(N) T&R / 2500 Year Year Week Week MARK YYWW TF2103M Lot ID YYWW TF2103M Lot ID VS LO Rev 1.3 1 Advance Info TF2103M Half-Bridge Gate Driver Pin Diagrams VCC 1 8 VB HIN 2 7 HO LIN* 3 6 VS COM 4 5 LO Top View: SOIC-8 TF2103M Pin Descriptions PIN NAME PIN NUMBER PIN DESCRIPTION VCC 1 Logic and low side supply HIN 2 Logic input for high-side gate driver output in phase with HO LIN* 3 Logic input for low-side gate driver output out of phase with LO COM 4 Low-side and logic return LO 5 Low-side gate drive output VS 6 High-side floating supply return HO 7 High-side gate drive output VB 8 High-side floating supply Functional Block Diagram VCC Vcc TF2103M UV Detect HIN Pulse Gen HV Level Shift Dead time R Q HO R S High Voltage Well Vs VCC +5V LIN* VB UV UV Detect Detect Delay LO COM Jul 2019 2 Advance Info TF2103M Half-Bridge Gate Driver Absolute Maximum Ratings (NOTE1) A VB - High side floating supply voltage......................-0.3V to +624V VS - High side floating supply offset voltage....VB -24V to VB+0.3V VHO - High side floating output voltage...................VS-0.3V to VB+0.3V dVS / dt - Offset supply voltage transient...................................50 V/ns PD - Package power dissipation at TA ≤ 25 °C SOIC-8.............................................................................................0.625W VCC - Low-side fixed supply voltage...............................-0.3V to +24V VLO - Low-side output voltage....................................-0.3V to VCC +0.3V VIN - Logic input voltage (HIN and LIN*)..................-0.3V to VCC +0.3V NOTE1 Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. SOIC-8(N) Thermal Resistance (NOTE2) qJA ...............................................................................................200 °C/W TJ - Junction operating temperature........................................+150 °C TL - Lead Temperature (soldering, 10 seconds).......................+300 °C Tstg - Storage temerature ......................................................-55 to 150 °C NOTE2 When mounted on a standard JEDEC 2-layer FR-4 board. Recommended Operating Conditions Symbol Parameter MIN MAX Unit VB High side floating supply absolute voltage VS + 10 VS + 20 V VS High side floating supply offset voltage NOTE3 600 V VHO High side floating output voltage VS VB V VCC Low side fixed supply voltage 10 20 V VLO Low side output voltage 0 VCC V VIN Logic input voltage (HIN and LIN*) 0 5 V TA Ambient temperature -40 125 °C NOTE3 Logic operational for VS of -5V to +600V. Logic state held for VS of -5V to -VBS Jul 2019 3 Advance Info TF2103M Half-Bridge Gate Driver DC Electrical Characteristics (NOTE4) VBIAS (VCC, VBS ) = 15V, TA = 25 °C , unless otherwise specified. Symbol Parameter VIH Logic “1” (HIN) & Logic “0” (LIN*) input voltage VIL Logic “0” (HIN) & Logic “1” (LIN*) input voltage VCC = 10V to 20V NOTE5 VOH High level output voltage, VBIAS - VO IO = 2mA 0.05 0.2 VOL Low level output voltage, VO IO = 2mA 0.02 0.1 ILK Offset supply leakage current VB = VS = 600V IBSQ Quiescent VBS supply current VIN = 0V or 5V 60 100 ICCQ Quiescent VCC supply current VIN = 0V or 5V 350 500 IIN+ Logic “1” input bias current HIN = 5V, LIN* = 0V 3 10 IIN- Logic “0” input bias current HIN = 0V, LIN* = 5V VCCUV+ VCC supply under-voltage positive going threshold 8.0 8.9 9.8 VCCUV- VCC supply under-voltage negative going threshold 7.4 8.2 9.0 VBSUV+ VBS supply under-voltage positive going threshold 4.5 5.5 6.5 V VBSUV- VBS supply under-voltage negative going threshold 4.2 5.2 6.2 V IO+ Output high short circuit pulsed current VO = 0V, PW ≤ 10 ms 130 290 IO- Output low short circuit pulsed current VO = 15V, PW ≤ 10 ms 270 600 Conditions MIN TYP MAX Unit 0.8 V 2.5 50 mA 5 V mA NOTE4 The VIN, VTH, and IIN parameters are applicable to the two logic input pins: HIN and LIN*. The VO and IO parameters are applicable to the respective output pins: HO and LO NOTE5 For optimal operation, it is recommended that the input pulse (to HIN and LIN*) should have an amplitude of 2.5V minimum with a pulse width of 840ns minimum. Jul 2019 4 Advance Info TF2103M Half-Bridge Gate Driver AC Electrical Characteristics VBIAS (VCC, VBS ) = 15V, CL = 1000pF, and TA = 25 °C , unless otherwise specified. Symbol Parameter Conditions ton Turn-on propagation delay toff Turn-off propagation delay tDM Delay matching, HS & LS turn-on/turn-off tr Turn-on rise time tf Turn-off fall time tDT Deadtime: tDT LO-HO & tDT HO-LO Jul 2019 MIN TYP MAX VS = 0V 680 820 VS = 600V 150 220 60 VS = 0V 300 70 170 35 90 420 650 Unit ns 5 Advance Info TF2103M Half-Bridge Gate Driver Timing Waveforms 50% 50% LIN* tON LO HIN tr tOFF 90% 90% tf 10% 10% LIN* 50% 50% HIN HO tON LO HO Figure 1. Input / Output Timing Diagram HIN LIN* 50% tr tOFF 90% 90% 10% tf 10% Figure 2. Switching Time Waveform Definitions 50% 90% HO 10% LO 90% tDT LO-HO tDT HO-LO 10% Figure 3. Deadtime Waveform Definitions Jul 2019 6 Advance Info TF2103M Package Dimensions (SOIC-8 N) Half-Bridge Gate Driver Please contact support@telefunkensemi.com for package availability. Jul 2019 7 Advance Info TF2103M Half-Bridge Gate Driver Package Dimensions (PDIP-8) Please contact support@tfsemi.com for package availability. Jul 2019 8 Advance Info TF2103M Half-Bridge Gate Driver Revision History Rev. Change Owner Date 1.0 First release, AI datasheet Keith Spaulding 7/15/2016 1.1 UVLO specifications edited to match repeatability data Keith Spaulding 10/19/2016 1.2 Edit text Keith Spaulding 10/20/2017 1.3 Add Note 5 Duke Walton 7/25/2019 Important Notice TF Semiconductor Solutions (TFSS) PRODUCTS ARE NEITHER DESIGNED NOR INTENDED FOR USE IN MILITARY AND/OR AEROSPACE, AUTOMOTIVE OR MEDICAL DEVICES OR SYSTEMS UNLESS THE SPECIFIC TFSS PRODUCTS ARE SPECIFICALLY DESIGNATED BY TFSS FOR SUCH USE. BUYERS ACKNOWLEDGE AND AGREE THAT ANY SUCH USE OF TFSS PRODUCTS WHICH TFSS HAS NOT DESIGNATED FOR USE IN MILITARY AND/OR AEROSPACE, AUTOMOTIVE OR MEDICAL DEVICES OR SYSTEMS IS SOLELY AT THE BUYER’S RISK. TFSS assumes no liability for application assistance or customer product design. Customers are responsible for their products and applications using TFSS products. Resale of TFSS products or services with statements different from or beyond the parameters stated by TFSS for that product or service voids all express and any implied warranties for the associated TFSS product or service. TFSS is not responsible or liable for any such statements. ©2016 TFSS. All Rights Reserved. Information and data in this document are owned by TFSS wholly and may not be edited, reproduced, or redistributed in any way without the express written consent from TFSS. For additional information please contact support@tfsemi.com or visit www.tfsemi.com Jul 2019 9
TF2103M-TAH
物料型号:TF2103M
器件简介:TF2103M是一款高电压、高速门驱动器,适用于驱动N沟道MOSFET和IGBT,特别适用于半桥配置。它采用TF Semiconductors的高电压工艺,能够在自举操作中将高侧切换至600V。
引脚分配: - Vcc:逻辑和低侧电源 - HIN:高侧门驱动器输出的逻辑输入,与HO同相 - LIN:低侧门驱动器输出的逻辑输入,与LO反相 - COM:低侧和逻辑返回 - LO:低侧门驱动输出 - VS:高侧浮动电源返回 - HO:高侧门驱动输出
参数特性: - 内部死区时间:420ns(典型值) - 低侧门驱动电源电压:10V至20V - 逻辑输入电压(HIN和LIN):3.3V能力,施密特触发逻辑输入 - 欠压锁定:VCC(逻辑和低侧电源)
功能详解: - TF2103M设计用于在嘈杂的电机应用中提高性能,具有290mA源/600mA汇输出电流能力。 - 输出能够容忍负瞬变。 - 固定内部死区时间保护MOSFET。
应用信息: - 电机控制 - DC-DC转换器 - AC-DC逆变器
封装信息: - SOIC-8(N) - PDIP-8
TF2103M-TAH 价格&库存
很抱歉,暂时无法提供与“TF2103M-TAH”相匹配的价格&库存,您可以联系我们找货
TF2103M-TAH
    • 1+2.10000
    • 30+2.02500
    • 100+1.87500
    • 500+1.72500
    • 1000+1.65000
