TF0227-TAH
TF0227-TAH
    TFSS(德律风根)
    SOIC-8
    双低边 灌:4.0A 拉:4.0A 电源电压:4.5V~18V
TF0227-TAH 数据手册
Advance Info TF0227(1/2/3/5) Dual High Speed Low-Side Gate Driver Description Features  E  fficient, low-cost solution for driving MOSFETs and IGBTs  Wide supply voltage operating range: 4.5V to 18V  A wide range (1.5A-4A) of source/sink output current capability offerings  Fast propagation delays (35ns typical)  Fast rise and fall times  Logic input (IN) 3.3V capability  Extended temperature range: -40°C to +125°C The TF0227(x), dual, high speed, low side MOSFET and IGBT drivers are capable of driving a range of source/ sink peak capabilities. The TF0227(x) logic inputs are compatible with standard TTL and CMOS levels (down to 3.3V) to interface easily with MCUs. Fast and well matched propagation delays allow high speed operation, enabling a smaller, more compact power switching design using smaller associated components. The TF0227(x) is offered in an SOIC-8(N) package and it operates over an extended -40 °C to +125 °C temperature range. Applications SOIC-8(N)  Switch mode power supplies  Motor Drive  Line Drivers  DC-DC Converters Ordering Information Typical Application NC INA INB www.tfsemi.com Apr. 2018 R4 R4 PART NUMBER PACKAGE TF0227-TAU SOIC-8(N) PACK / Qty Tube / 100 TF0227-TAH T&R / 2500 SOIC-8(N) TO LOAD NC INA TF0227 MARK YYWW TF0227 Lot ID OUTA GND VCC INB OUTB VCC Rev. 1.2 1 Advance Info TF0227(1/2/3/5) Dual High Speed Low-Side Gate Driver Pin Diagrams NC 1 8 NC INA 2 7 OUTA COM 3 6 VCC INB 4 5 OUTB Top View: SOIC8 Pin Descriptions PIN NAME PIN NUMBER PIN DESCRIPTION NC 1, 8 No Connect INA 2 Logic input for A phase, in phase with OUTA. COM 3 Supply return INB 4 Logic input for B phase, in phase with OUTB. OUTB 5 Gate driver output B phase VCC 6 Supply input OUTA 7 Gate driver output A phase Functional Block Diagram TF0227 OUTA INA Vcc INB OUTB COM Apr. 2018 2 Advance Info TF0227(1/2/3/5) Dual High Speed Low-Side Gate Driver Absolute Maximum Ratings (NOTE1) VCC - Low-side fixed supply voltage...............................-0.3V to +22V VOUT - Output voltage (OUTA/OUTB)....................-0.3V to VCC +0.3V VIN - Logic input voltage (INA, INB).......................-0.3V to VCC +0.3V ESD Protection on all pins....................................................2kV (HBM) A PD - Package power dissipation at TA ≤ 25 °C SOIC8 .....................................................................................0.625W SOIC8 Thermal Resistance (NOTE2) qJA ................................................................................................200 °C/W TJ - Junction operating temperature........................................+150 °C TL - Lead Temperature (soldering, 10 seconds).......................+300 °C Tstg - Storage temerature ......................................................-55 to 150 °C NOTE1 Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. NOTE2 When mounted on a standard JEDEC 2-layer FR-4 board. Recommended Operating Conditions Symbol Parameter MIN MAX Unit VCC Supply voltage 4.5 18 V VOUT Output voltage (OUTA/OUTB) 0 VCC V VIN Logic input voltage (INA, INB) 0 5 V TA Ambient temperature -40 125 °C Apr. 2018 3 Advance Info TF0227(1/2/3/5) Dual High Speed Low-Side Gate Driver Electrical Characteristics (NOTE3) VBIAS (4.5V
TF0227-TAH
物料型号为TF0227,是TF Semiconductor Solutions公司生产的双高速低压侧栅极驱动器。
以下是对PDF文档内容的中文分析:
器件简介: TF0227(x)是一款高效的低成本解决方案,用于驱动MOSFETs和IGBTs。
它能够提供源/汇峰值能力范围,与标准TTL和CMOS电平兼容,便于与微控制器接口。
快速且匹配良好的传播延迟允许高速操作,使用更小的相关组件实现更紧凑的功率开关设计。
引脚分配: - NC:1,8号引脚,无连接。
- INA:2号引脚,A相位的逻辑输入,与OUTA同相。
- COM:3号引脚,供电返回。
- INB:4号引脚,B相位的逻辑输入,与OUTB同相。
- OUTB:5号引脚,B相位的栅极驱动输出。
- Vcc:6号引脚,供电输入。
- OUTA:7号引脚,A相位的栅极驱动输出。
参数特性: - 工作电压范围宽:4.5V至18V。
- 源/汇输出电流能力范围宽:1.5A至4A。
- 传播延迟快(典型值35ns)。
- 上升和下降时间快。
- 逻辑输入(IN)3.3V能力。
- 扩展温度范围:-40°C至+125°C。
功能详解: TF0227(x)在SOIC-8(N)封装中提供,并在-40°C至+125°C的扩展温度范围内运行。
适用于开关电源、电机驱动、线路驱动器和DC-DC转换器等应用。
应用信息: 适用于开关电源、电机驱动、线路驱动器和DC-DC转换器。
封装信息: TF0227提供SOIC-8(N)封装,可通过电子邮件support@tfsemi.com查询封装可用性。
订购信息: - 型号:TF0227-TAU - 封装:SOIC-8(N) - 包装/数量:Tube/100 - 标记:YYWW TF0227
绝对最大额定值和推荐工作条件表格提供了详细的电气特性和操作条件。
此外,还包括了开关特性和封装尺寸信息。
最后,文档包含了修订历史和TF Semiconductor Solutions的免责声明。
TF0227-TAH 价格&库存
很抱歉,暂时无法提供与“TF0227-TAH”相匹配的价格&库存,您可以联系我们找货
TF0227-TAH
  • 1+3.62500
  • 30+3.50000
  • 100+3.25000
  • 500+3.00000
  • 1000+2.87500
TF0227-TAH
  • 1+6.19920
  • 10+5.03280
  • 30+4.44960
  • 100+3.87720
  • 500+3.31560
  • 1000+3.13200
库存:3209
