ES2JW
ES2JW
    SK(時科)
    SMF(SOD-123FL)
    "表面贴装超快速恢复整流器 反向电压–50至600V 正向电流-2A"
ES2JW 数据手册
ES2AW THRU ES2JW Surface Mount Superfast Recovery Rectifier Reverse Voltage – 50 to 600 600V Forward Current – 2A FEATURES • Easy pick and place • For surface mounted applications • Low profile package • Built-in strain relief • Superfast recovery times for high efficiency MECHANICAL DATA • Case: SOD-123FL • Terminals: Solderable per MIL-STD-750, 750, Method 2026 • Approx. Weight: 15mg / 0.00053oz Absolute Maximum Ratings and Characteristics Ratings at 25℃ ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.For capacitive load, derate current by 20%. 1)P.C.B. P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas REV.08 1 of 3 ES2AW THRU ES2JW REV.08 2 of 3 ES2AW THRU ES2JW PACKAGE OUTLINE Plastic surface mounted package; 2 leads REV.08 SOD-123FL 123FL 3 of 3
ES2JW 价格&库存
很抱歉,暂时无法提供与“ES2JW”相匹配的价格&库存,您可以联系我们找货
ES2JW
  • 20+0.18339
  • 200+0.15185
  • 600+0.13436
  • 3000+0.12312
  • 9000+0.11405
  • 21000+0.10908
库存:1878
ES2JW
    • 3000+0.06817
    库存:3600
    ES2JW
    • 1+0.48510
    • 200+0.16170
    • 1500+0.10109
    • 3000+0.08019
    库存:3000
    ES2JW
    • 1+0.10875
    • 100+0.10150
    • 300+0.09425
    • 500+0.08700
    • 2000+0.08338
    • 5000+0.08120
