ES3ABG THRU ES3JBG
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 50 to 600 V Forward Current –3 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
• Case : SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight : 0.055g / 0.002oz
Top View
Marking Code: ES3A~ES3J
Simplified outline SMB and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES3AB
G
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
Maximum RMS voltage
V RMS
35
Maximum DC Blocking Voltage
V DC
50
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Forward Voltage at 3 A
VF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
ES3EB
G
ES3GB
G
ES3JB
G
Units
150
200
300
400
600
V
70
105
140
210
280
420
V
100
150
200
300
400
600
V
1.25
1
1.68
V
IR
5
100
μA
Cj
45
pF
t rr
35
ns
RθJA
RθJC
50
16
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
ES3DB
G
ES3BB ES3CB
G
G
1 of 3
ES3ABG THRU ES3JBG
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.5
300
3.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
Case Temperature (°C)
Junction Capacitance ( pF)
Instaneous Forward Current (A)
10
T J =25°C
1.0
ES3ABG~ES3DBG
ES3EBG/ES3GBG
ES3JBG
0.01
0.5
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
150
140
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
REV.08
80
100
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1.0
10
Reverse Voltage (V)
Fig.6 Maximum Non-Repetitive Peak
T J =25°C
1
0.1
0.001
% of PIV.VOLTS
Fig.5 Typical Junction Capacitance
Fig.4 Typical Forward Characteristics
0.1
2 of 3
100
ES3ABG THRU ES3JBG
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
Marking
2.2
(86)
2.4
(94)
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
REV.08
3 of 3
Type number
Marking code
ES3ABG
ES3A
ES3BBG
ES3B
ES3CBG
ES3C
ES3DBG
ES3D
ES3EBG
ES3E
ES3GBG
ES3G
ES3JBG
ES3J
很抱歉,暂时无法提供与“ES3BBG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.19599
- 30+0.18899
- 100+0.18199
- 500+0.16800
- 1000+0.16100
- 2000+0.15680
- 国内价格
- 10+0.26851
- 100+0.21403
- 300+0.18674
- 3000+0.15124
- 6000+0.13492
- 9000+0.12671
