UMW
R
UMW AO3442A
100V N-Channel MOSFET
General Description
SOT–23
The AO3442 combines advanced trench MOSFET
technology with a low resistance package to provide
extremely low RDS(ON). This device is ideal for boost
converters and synchronous rectifiers for consumer,
telecom, industrial power supplies and LED backlighting.
Product Summary
VDS
ID (at VGS=10V)
100V
1A
1. GATE
RDS(ON) (at VGS=10V)
< 630mΩ
2. SOURCE
RDS(ON) (at VGS=4.5V)
< 720mΩ
3. DRAIN
D
G
S
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
TA=25°C
Continuous Drain
Current
Pulsed Drain Current
Power Dissipation
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
Maximum Junction-to-Ambient A D
Maximum Junction-to-Lead
www.umw-ic.com
Steady-State
Steady-State
A
1.4
W
0.9
TJ, TSTG
°C
-55 to 150
Symbol
t ≤ 10s
V
4
PD
TA=70°C
±20
0.8
IDM
TA=25°C
B
Units
V
1
ID
TA=70°C
C
Maximum
100
Typ
70
100
63
RθJA
RθJL
1
Max
90
125
80
Units
°C/W
°C/W
°C/W
友台半导体有限公司
UMW
R
UMW AO3442A
Electrical Characteristics (TJ=25°C unless otherwise noted)
Symbol
Parameter
STATIC PARAMETERS
Drain-Source Breakdown Voltage
BVDSS
Conditions
Min
ID=250µA, VGS=0V
100
Zero Gate Voltage Drain Current
IGSS
Gate-Body leakage current
VDS=0V, VGS=±20V
VGS(th)
Gate Threshold Voltage
VDS=VGS,ID=250µA
ID(ON)
On state drain current
VGS=10V, VDS=5V
1
TJ=55°C
5
nA
2.9
V
514
630
983
1200
VGS=4.5V, ID=0.8A
554
720
4
TJ=125°C
A
gFS
Forward Transconductance
VDS=5V, ID=1A
2.8
VSD
Diode Forward Voltage
IS=1A,VGS=0V
0.9
IS
Maximum Body-Diode Continuous CurrentG
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Crss
Reverse Transfer Capacitance
Rg
Gate resistance
µA
±100
Static Drain-Source On-Resistance
Output Capacitance
Units
2.3
1.7
VGS=10V, ID=1A
Coss
Max
V
VDS=100V, VGS=0V
IDSS
RDS(ON)
Typ
VGS=0V, VDS=50V, f=1MHz
mΩ
mΩ
S
1.2
V
1
A
100
pF
13
pF
5
pF
5
7.5
Ω
SWITCHING PARAMETERS
Qg(10V) Total Gate Charge
2.8
6
nC
Qg(4.5V) Total Gate Charge
1.5
3
nC
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
VGS=0V, VDS=0V, f=1MHz
VGS=10V, VDS=50V, ID=1A
2.5
0.4
nC
0.8
nC
5
ns
VGS=10V, VDS=50V, RL=50
=50Ω,
Ω,
RGEN=3Ω
4
ns
12
ns
5
ns
IF=5.6A, dI/dt=100A/µs
52
Body Diode Reverse Recovery Charge IF=5.6A, dI/dt=100A/µs
60
ns
nC
tD(on)
Turn-On DelayTime
tr
Turn-On Rise Time
tD(off)
Turn-Off DelayTime
tf
Turn-Off Fall Time
trr
Body Diode Reverse Recovery Time
Qrr
A. The value of RθJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The
value in any given application depends on the user's specific board design.
B. The power dissipation PD is based on TJ(MAX)=150°C, using ≤ 10s junction-to-ambient thermal resistance.
C. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150°C. Ratings are based on low frequency and duty cycles to keep
initialTJ=25°C.
D. The RθJA is the sum of the thermal impedance from junction to lead RθJL and lead to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AO3442A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.29398
- 200+0.22626
- 600+0.18868
- 3000+0.16611
- 9000+0.14645
- 21000+0.13598
- 国内价格
- 10+0.18445
- 100+0.17255
- 500+0.16065
- 2000+0.14280
- 5000+0.13685
- 10000+0.13328
- 国内价格
- 1+0.28050
- 200+0.18150
- 1500+0.15840
- 3000+0.13970
