ELECTRONICS
Transient
Voltage
Suppressors
1.5KE Series
Circuit Protection
System
Specifications are subject to change without notice.
Transient Voltage Suppressors - 1.5KE Series
Features
UNI
1. Halogen-free
2. Rohs compliant
3. Typical maximum temperature coefficient
4. ΔVBR =0.1%xVBR@25°C x ΔT
BI
5. Glass passivated Chip junction in DO-201 package
6. 1500W peak pulse capadility at 10x1000μs waveform,repetition rate (duty
cycles):0.01%
7. Fast response time:typically less than 1.0ps from 0 Volts to BV min
8. Excellent clamping capability
9. Low incremental surge resistance
10. Typical IR less than 5μA above 11V
11. High temperature soldering guaranteed: 260°C/40 seconds / 0.375”,
BI
Cathode
Anode
(9.5mm) lead length, 5lbs., (2.3kg)tension
12. Plastic package has underwriters laboratory flammability classification
94v-0
UNI
13. Matte Tin Lead–free plated
Applications
TVS devices are ideal for the protection of I/O interfaces,VCC bus and other vulnerable circuits used in telecom, computer,
industrial and consumer electronic applications.
Mechanical Characteristics
Rating
Symbol
Value
Units
PPPM
1500
Watts
PD
6.5
Watts
IFSM
200
Amps
VF
3.5/5.0
V
Operating junction and Storage Temperature Range.
TJ,TSTG
-55°C to 175°C
°C
Typical Thermal Resistance Junction to Lead
RuJL
15
°C/W
to Ambient
RuJA
75
°C/W
Reverse current
IF
100
A
Peak Pulse Power Dissipation by 10x1000μs test waveform
(Fig.1)(Note 1)
Steady State Power Dissipation on
inifinite heat sink at TL=75°C (Fig. 5)
Peak Forward Surge Current, 8.3ms Single Half Sine Wave
Unidirectional only (Note 2)
Maximum Instantaneous Forward Voltage at 25A for
Unidirectional only (Note 3)
Notes:
1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 perminute maximum.
3. VF
很抱歉,暂时无法提供与“1.5KE30CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.41076
- 50+1.12665
- 150+1.00486
- 1000+0.85293
- 2000+0.78528
- 5000+0.74465
- 国内价格
- 1+0.78312
- 50+0.60320
- 1000+0.55432
- 国内价格
- 5+1.28013
- 50+1.02233
- 150+0.91181
