ESD5451L
ESD5451L
    SLKOR(萨科微)
    DFN1006-2
    ESD抑制器/TVS二极管 DFN1006-2L VRWM=5V VBR(min)=5.6V Vc=12V
ESD5451L 数据手册
ESD5451L Transient Voltage Suppressors ESD Protection Diode Absolute Maximum Ratings Symbol PD TL TA = 25°C unless otherwise noted Parameter Total Power Dissipation on FR-5 Broad Max Lead Solder Temperature range (10 Second Duration) Value Units 150 mW 260 °C Tstg Storage Temperature Range -55 to +150 °C TOPR Max operation Temperature Range +125 °C IEC61000-4-2 ±20 ±25 KV ESD Air Discharge Contact Discharge These ratings are limiting values above which the serviceability of the diode may be impaired. Specification Features: § § § § § § § Capacitance Typ. 15pF Small Body Outline Dimensions Low Leakage Current ESD Rating of Class 3 (>16kV) per Human Body Model RoHS Compliant Green EMC Matte Tin(Sn) Lead Finish www.slkormicro.com 1 DFN1006-2L Package ESD5451L Electrical Characteristics (TA = 25°C unless otherwise noted) Device Type ESD5451L VBR @ IT VRWM IR @ VRWM (Volts) (µA) Max Max Min Max 5.0 0.5 5.6 --- (Note 1) IT (mA) (Volts) IPP+ VC @ Max IPP+ (A) (Volts) VR = 0V, f = 1MHz Max Max Max Typ. 5 12 60 15 1.0 + Surge current waveform per Figure 1. Note 1: VBR is measured with a pulse test current IT at an ambient temperature of 25°C. SURGE CURRENT WAVEFORM: CAPACITANCE CURVE: www.slkormicro.com 2 C@ PPK+ (W) (pF) ESD5451L Package Outline MILLIMETERS INCHES DIM Typical Soldering Pattern(mm): MIN MAX MIN MAX A 0.46 0.50 0.018 0.020 A1 --- 0.03 --- 0.001 b 0.45 0.55 0.018 0.022 D 0.55 0.65 0.022 0.026 E 0.95 1.05 0.037 0.041 e1 L www.slkormicro.com 3 Typ. 0.65 0.20 0.30 Typ. 0.026 0.008 0.012
ESD5451L 价格&库存
很抱歉,暂时无法提供与“ESD5451L”相匹配的价格&库存,您可以联系我们找货
ESD5451L
  • 50+0.10652
  • 2000+0.07659
库存:1325
