DSK12-DSK120
SURFACE MOUNT SCHOTTKY BARRIER DIODES
VOLTAGE RANGE: 20 - 200V
CURRENT: 1.0 A
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
B
250 C/10 seconds,0.375
” (9.5mm) lead length,
5 lbs. (2.3kg) tension
C
E
SOD-123FL
Dim Min Max Typ
A 3.58 3.72 3.65
3
B 2.72 2.78 2.75
C 1.77 1.83 1.80
D
1
1.02
1.08 1.05
E 0.097 1.03 1.00
H 0.13 0.17 0.15
L
0.53 0.57 0.55
All Dimensions in mm
Mechanical Data
! Case: SOD-123FL
plastic body over passivated junction
! Terminals : Plated axial leads,
! solderable per MIL-STD-750, Method 2026
D
H
L
! Polarity : Color band denotes cathode end
! Mounting Position : Any
E
! Weight:0.0007 ounce, 0.02 grams
A
Maximum Ratings and Electrical Characteristics
TA = 25C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Symbol DSK12 DSK13 DSK14 DSK15 DSK16 DSK17 DSK18 DSK19 DSK110 DSK115 DSK120 Unit
Characteristic
Maximum repetitive peak reverse voltage
VRRM
40
50
60
70
80
90
100
150
200
V
Maximum RMS voltage
VRMS
14
21
28
35
42
49
56
63
70
105
140
V
Maximum DC blocking voltage
VDC
40
50
60
70
80
90
100
150
200
V
Maximum average forward rectified current
I(AV)
1.0
A
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
25.0
A
Maximum instantaneous forward voltage at 1.0A
VF
Maximum DC reverse current
at rated DC blocking voltage
IR
TA=25 C
TA=100 C
CJ
Operating junction temperature range
TJ
0.5
TSTG
1
mA
pF
-65 to +150
-65 to +150
V
2.0
80
-65 to +125
0.95
0.2
5.0
110
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
www.slkormicro.com
0.85
10.0
Typical junction capacitance (NOTE 1)
Storage temperature range
0.70
0.55
C
C
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
DSK12-DSK120
FIG. 1- FORWARD CURRENT DERATING CURVE
1
0.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.6
0.4
DSK12-DSK16
DSK17-DSK120
0.2
50
75
100
125
150
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
30
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
25
10
5.0
175
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
DSK12-DSK14
DSK15-DSK16
DSK17-DSK115
DSK120
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
100
10
TJ=100 C
1
TJ=75 C
0.1
JUNCTION CAPACITANCE, pF
FIG. 5-TYPICAL JUNCTION CAPACITANCE
1000
DSK12-DSK14
DSK15-DSK120
100
TJ=25 C
10
10
100
REVERSE VOLTAGE,VOLTS
www.slkormicro.com
TJ=25 C
0.01
60
80
PERCENT OF PEAK REVERSE VOLTAGE,%
2000
1.0
100
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
0.1
10
NUMBER OF CYCLES AT 60 Hz
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
CURRENT,AMPERES
AMBIENT TEMPERATURE, C
2
100
很抱歉,暂时无法提供与“DSK14”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07880
- 600+0.06326
- 1200+0.06231
- 3000+0.04891
- 国内价格
- 50+0.08597
- 500+0.06902
- 3000+0.05336
- 6000+0.04774
- 24000+0.04288
- 51000+0.04029
