350ARHA101M06X8
350ARHA101M06X8
    APAQ(钰邦)
    插件,D6.3xL8mm
    直插铝电解电容 AEC_D6.3X8MM_TM 100µF ±20% Ф6.30 x 8.00mm
350ARHA101M06X8 数据手册
AP-CON Aluminum Solid Electrolytic Capacitor ARHA Series High Voltage  Rated Voltage:25~100Vdc    Endurance 5000hrs at 105℃ Suitable for AC-DC、DC-DC converters, voltage regulators and decoupling applications RoHS Compliant Specification Rated Voltage Range Capacitance Tolerance Category Temperature Range -55 to 105℃ 25 to 100Vdc Rated Capacitance Range 22 to 1500 (μF) Surge Voltage Rated voltage x1.15(at 105°C) Dissipation Factor 0.12max.(at 20°C 120Hz) Shall not exceed values shown in standard ratings. Leakage Current ±20% (M) 105℃, 5000hrs, rated voltage applied Appearance No significant damage Endurance Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 60℃, 90 to 95% RH, 1000hrs, no voltage applied Appearance No significant damage Damp Heat (Steady State) Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a protective resistor (R=1kΩ) and discharge for 5.5min. Appearance No significant damage Surge Voltage Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value Dimensions and Marking Series Date code Polarity marking (-) Capacitance Voltage Product Specifications are subject to change without notice. SIZE Code øD±0.5 max L α ød±0.05 F±0.4 08X8 08A2 08A6 08B0 10A2 10A6 10B0 8.0 8.0 8.0 8.0 10.0 10.0 10.0 8.0 11.5 16.0 20.0 11.5 16.0 20.0 1.0 1.5 1.5 1.5 1.5 1.5 1.5 0.6 0.6 0.6 0.6 0.6 0.6 0.6 3.5 3.5 3.5 3.5 5.0 5.0 5.0 AP-CON Aluminum Solid Electrolytic Capacitor ARHA Series High Voltage 220 330 470 560 680 680 820 1000 1500 47 68 100 100 220 330 470 470 560 680 120 180 220 390 22 47 68 100 180 22 47 82 08A2 08A2 08A2 10A2 08A6 10A2 08B0 10A6 10B0 06X5 06X8 06X8 08X8 08A2 10A2 08B0 10A6 10A6 10B0 08A2 10A2 10A2 10B0 08X8 08A2 10A2 10A2 10A2 08X8 10A2 10A2 1,100 1,650 2,350 2,800 3,400 3,400 4,100 5,000 7,500 329 476 700 700 1,540 2,310 3,290 3,290 3,920 4,760 1,200 1,800 2,200 3,900 277 592 857 1,260 2,268 352 752 1,312 16 16 16 14 14 14 13 13 13 35 25 35 23 25 24 20 25 23 20 28 28 28 23 35 30 25 30 30 40 32 32 Rated Ripple Current (mArms/ 105℃ /100kHz) 4,650 4,650 4,650 5,100 5,000 5,100 5,100 5,200 5,300 2,300 2,600 2,350 2,800 2,890 3,400 4,400 4,000 4,200 4,800 2,620 3,100 3,100 3,800 2,100 2,500 2,500 2,700 2,700 1,700 2,100 2,200 22 47 10A2 10A2 440 940 45 35 1,600 2,100 WV/Vdc Cap Size (SV) (μF) Code 25 (28.8) 35 (40.3) 50 (57.5) 63 (72.5) 80 (92) 100 (115) Leakage ESR Current (mΩmax/20%, (μA) 100k to300kHz) Product Specifications are subject to change without notice. Part No. 250ARHA221M08A2 250ARHA331M08A2 250ARHA471M08A2 250ARHA561M10A2 250ARHA681M08A6 250ARHA681M10A2 250ARHA821M08B0 250ARHA102M10A6 250ARHA152M10B0 350ARHA470M06X5 350ARHA680M06X8 350ARHA101M06X8 350ARHA101M08X8 350ARHA221M08A2 350ARHA331M10A2 350ARHA471M08B0 350ARHA471M10A6 350ARHA561M10A6 350ARHA681M10B0 500ARHA121M08A2 500ARHA181M10A2 500ARHA221M10A2 500ARHA391M10B0 630ARHA220M08X8 630ARHA470M08A2 630ARHA680M10A2 630ARHA101M10A2 630ARHA181M10A2 800ARHA220M08X8 800ARHA470M10A2 800ARHA820M10A2 101ARHA220M10A2 101ARHA470M10A2 Rev.A
350ARHA101M06X8 价格&库存
很抱歉,暂时无法提供与“350ARHA101M06X8”相匹配的价格&库存,您可以联系我们找货
350ARHA101M06X8
库存:215
