KBP2005 THRU KBP210
Reverse Voltage - 50 to 1000 Volts Forward Current - 2.0 Amperes
SINGLE BRIDGE RECTIFIERS
Features
KBP
Glass passivated die construction
Low forward voltage drop
0.559(14.20)
0.543(13.80)
High current capability
0.043(1.1)
0.031(0.8)
High surge current capability
Plastic material-UL flammability 94V-0
0.126(3.20)
0.118(3.00)
0.417(10.6)
0.402(10.2)
0.087(2.2)
0.071(1.8)
0.056(1.42)
0.048(1.22)
0.539(13.7)
0.500(12.7)
0.022(0.55)
0.012(0.3)
Mechanical Data
Case : JEDEC KBP Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0693 ounce,1.35 grams
0.16(4.06)
0.14(3.56)
0.034(0.86)
0.030(0.76)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward output rectified current
at TC=50 °C(Note 1)
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
SYMBOLS
VRRM
VRMS
VDC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
KBP2005
KBP201
KBP202
KBP204
KBP206
KBP208
KBP210
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
I(AV)
2.0
A
IFSM
35
A
VF
1.1
V
IR
10
1
μA
mA
Typical Thermal Resistance (Note 2)
RθJA
25
°C/W
Operating junction temperature range
storage temperature range
TJ
TSTG
-55 to +150
-55 to +150
°C
°C
Maximum instantaneous forward voltage drop
per birdge element at 2.0A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=125°C
Note:1. Mounted on glass epoxy PC board with 1.3mm 2 solder pad.
2. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C..
http://www.microdiode.com
Rev:2024A3
Page :1
KBP2005 THRU KBP210
Ratings And Characteristic Curves
Fig. 2 Maximum Non-repetitive Peak
Forward Surge Current
Fig. 1 Derating Curve for
Output Rectified Current
40
Peak Forward Surge
Current, Amperes
Average Forward Outp
ut Current, Amperes
3.0
2.0
60Hz Resistive of
Inductive Load
1.0
100
8.3ms
Single half-sine-Wave
[JEDEC Method]
30
1
100
Number of Cycles at 60HZ
150
o
Fig. 4 Typical Reverse
Characteristics
Case Temperature, C
10
Instantaneous Reverse
Current ,Amperes
Fig. 3 Typical Instantaneous
Forward Characteristics
100
40
10
4.0
1.0
0.1
TA=25 C
.01
Tj=25 C
Pulse Width=300us
2% duty cycle
.01
0.6
40
60
80
100
120
140
Percent of Rated Peak
Reverse Voltage, %
0.7
0.8
0.9
1.0
1.1
Fig. 5 Typical Junction Capacitance
1.2
Instantaneous Forward Voltage, Volts
400
1.3
Capacitance, pF
Current, Amperes
Tc=100 C
1.0
100
10
Tj=25 C
f=1.0MHz
Ving =50mV p.p.
1
1.5
10
2
100
Reverse Voltage, Volts
Rev:2024A3
Page :2
很抱歉,暂时无法提供与“KBP206”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.74045
- 50+0.61829
- 150+0.55722
- 500+0.37578
- 2500+0.33911
- 5000+0.32077
- 国内价格
- 10+0.71520
- 100+0.52160
- 300+0.45520
- 3000+0.35510
- 国内价格
- 10+0.53760
- 100+0.43010
- 300+0.37540
- 3000+0.32860
- 9000+0.30720
- 21000+0.29190
- 国内价格
- 10+0.69973
- 100+0.58430
- 200+0.52658
- 500+0.35511
