SM712
Asymmetrical TVS Diode for
Extended Common-Mode RS-485
SOT-23 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The SM712 transient voltage suppressor (TVS) diode is designed for asymmetrical (12V to -7V)
protection in multi-point data transmission standard RS-485 applications. The SM712 may be used to
protect devices from transient voltages resulting from electrostatic discharge (ESD), electrical fast
transients (FET), and lightning.
The SM712 features 400 Watts (tp=8/20μs) of power handling capability to accommodate the higher
transient voltage levels which may be expected in extended common mode applications. This provides
higher equipment reliability and eliminates the “ guess work” required when using zener diodes that are
not rated to handle such transient conditions.
The integrated design aids in reducing voltage over-shoot associated with trace inductance. The low
clamping voltage of the SM712 minimizes the stress on the protected transceiver. The SOT-23 package
allows flexibility in the design of “crowed” circuit boards.
Features
400 Watts Peak Pulse Power per (8/20μs)
Transient protection for asymmetrical data lines to
IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
IEC61000-4-5 (Lightning) 12A (8/20μs)
Protects two +12V to -7V lines
Low capacitance
Low leakage current
Low clamping voltage
Solid-state silicon avalanche technology
Meets MSL 1 Requirements
Schematic & Pin Configuration
3
1
2
SOT23 (Top View)
Circuit Diagram
I/O 1
I/O 2
1
2
12V
12V
7V
7V
SM712
GND
Applications
Protection of RS-485 transceivers with extended
common-mode range
Security systems
Automatic Teller Machines
HFC systems
Networks
http://www.microdiode.com
3
Mechanical Characteristics
Package: SOT-23
Flammability Rating: UL 94V-0
Terminal: Matte tin plated.
High temperature soldering guaranted:
260℃/10s
Marking: 712 or C72
Packaging: Tape and Reel
Rev:2024A2
Page :1
SM712
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power(8/20us )
PPP
400
W
Peak Pulse Current(8/20us)
IPP
17
A
VESD
± 15
±8
KV
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Lead Solder Temperature – Maximum (10 Second
Duration)
Electrical Characteristics (TA=25°C unless otherwise specified)
mbol
Symbol
Parame
Test Condition
Pin 1 to 3 and
Pin 2 to 3
(12V) TVS
Min
VRWM
VBR
IR
Reverse Working
Voltage
Reverse
Breakdown Voltage
Reverse Leakage
Current
Typ
Pin 3 to 1 or
Pin 2 to 1
IT = 1mA
Pin 3 to 1 and
Pin 3 to 2
(7V TVS)
Max
Min
i
Typ
12
13.3
Units
Max
7
7.5
V
V
VR = VRWM
1
μA
VC1
Clamping Voltage 1
IPP = 5A,
tp = 8/20μs
V
VC2
Clamping Voltage 2
IPP = 17A,
tp = 8/20μs
26
16
V
Junction
Capacitance 1
Junction
Capacitance 2
VR = 0V,
f = 1MHz
VR = VRWM,
f = 1MHz
75
75
pF
CJ1
CJ2
45
45
pF
The above data are for reference only.
Rev:2024A2
Page :2
SM712
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A2
Page :3
SM712
Outlitne Drawing
SOT-23 Package Outline Dimensions
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
L
L1
E
E1
Symbol
A
A1
b
c
D
E
E1
e
L
L1
θ
Dimensions In Millimeters
Min
Typ
Max
1.40
0.89
1.00
0.10
0.06
0.01
0.50
0.37
0.44
0.20
0.09
0.13
2.80
2.90
3.10
1.60
1.20
1.30
2.40
2.10
2.80
1.78
2.04
1.90
0.10
0.30
0.69
0.35
0.54
0°
10°
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
Rev:2024A2
Page :4
SM712
SOT-23 Tape and Reel
Packaging Description:
SOT-23 parts are shipped in tape. The carrier
tape is made from a dissipative (carbon filled)
polycarbonate resin. The cover tape is a multilayer
film (Heat Activated Adhesive in nature) primarily
composed of polyester film,adhesive laye,sealant,
and anti-static sprayed agent.These reeled parts In
standard option are shipped with 3,000 units per 7"
or 17.8cm diameter reel. The reels are clear in color
and is made of polystyrene plastic (anti-static
coated).
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A2
Page :5
很抱歉,暂时无法提供与“SM712”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.46613
- 200+0.38913
- 600+0.34949
- 3000+0.23350
- 9000+0.22205
- 21000+0.21438
- 国内价格
- 1+0.49678
- 200+0.31978
- 1500+0.27848
- 3000+0.24662
