LESD3Z5.0C
LESD3Z5.0C
    MDD(辰达半导体)
    SOD-323
    Bi PD=100W VRWM=5V VBR=5.6V VC=16V IPP=8A IR=1uA CJ=10PF 个人消费电子、智能家居、监控门禁、车载电子
LESD3Z5.0C 数据手册
LESD3Z5.0C Transient Voltage Suppressors for ESD protection DESCRIPTION SOD-323 Plastic-Encapsulate ESD Protection Diodes The LESD3Z5.0C is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. This device has been specifically designed to protect sensitive components which are connected to data and transmission lines from overvoltage caused by ESD (electrostatic discharge), CDE (Cable Discharge Events),and EFT (electrical fast transients). Features         Peak power dissipation: 60W (8/20μs) IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC61000-4-4 (EFT) 40A (5/50ns) Protects one I/O line) Low clamping voltage Working voltages : 5V Low leakage current Meets MSL 1 Requirements Pin Configuration Circuit Diagram   Applications        High Speed Line :USB1.0/2.0, VGA, DVI, SDI, Serial and Parallel Ports Notebooks, Desktops, Servers Projection TV Cellular handsets and accessories Portable instrumentation Peripherals Mechanical Characteristics  Package: SOD-323  Flammability Rating: UL 94V-0  Terminal: Tin plated, solderable per MIL-STD-750, method 2026  High temperature soldering guaranteed: 260℃/ 10s  Packaging: Tape and Reel  Marking: 3M or AC Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter ESD per IEC 61000−4−2 (Air) ESD per IEC 61000−4−2 (Contact) Symbol VESD Value ± 30 ± 30 Unit KV Peak Pulse Power(8/20us ) PPP 60 W Operating Temperature TOPT −55 to +150 °C Storage Temperature TSTG −55 to +150 °C TL 260(10 sec.) °C Lead Solder Temperature – Maximum (10 Second Duration) The above data are for reference only. http://www.microdiode.com Rev:2024A2 Page :1 LESD3Z5.0C Transient Voltage Suppressors for ESD protection Electrical Characteristics (TA=25°C unless otherwise specified) Symbol Parameter VRWM Reverse Working Voltage VBR Reverse Breakdown Voltage IR Reverse Leakage Current VC Clamping Voltage CJ Junction Capacitance Max Units 5.0 V 7.8 V 1.0 uA IPP = 5A, tp = 8/20μs 12 V VR = 0V, f = 1MHz 18 pF Test Condition IT = 1mA Min Typ 5.6 VRWM = 5.0V The above data are for reference only. http://www.microdiode.com Rev:2024A2 Page :2 LESD3Z5.0C Transient Voltage Suppressors for ESD protection ELECTRICAL CHARACTERISTICS CURVE The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :3 LESD3Z5.0C Transient Voltage Suppressors for ESD protection Outlitne Drawing SOD-323 Package Outline Dimensions Suggested Pad Layout Note: 1.Controlling dimension:in/millimeters. 2.General tolerance: ±0.05mm. 3.The pad layout is for reference purposes only. PACKAGE SPECIFICATIONS Package Reel Size SOD-323 Reel DIA. (mm) Q'TY/Reel (pcs) Box Size (mm) QTY/Box (pcs) Carton Size (mm) Q'TY/Carton (pcs) 178 3000 183×188×80 45,000 386×265×215 180,000 7' http://www.microdiode.com Rev:2024A2 Page :4
LESD3Z5.0C 价格&库存
很抱歉,暂时无法提供与“LESD3Z5.0C”相匹配的价格&库存,您可以联系我们找货
LESD3Z5.0C
  • 20+0.15117
  • 300+0.11860
  • 1200+0.10049
  • 3000+0.08959
库存:2500
LESD3Z5.0C
  • 20+0.28140
  • 100+0.16790
  • 800+0.11750
  • 3000+0.08400
  • 6000+0.07980
  • 30000+0.07390
LESD3Z5.0C
  • 20+0.16492
  • 200+0.12939
  • 600+0.10962
  • 3000+0.09774
  • 9000+0.08748
  • 21000+0.08198
库存:2783
