S5MC
S5MC
    MDD(辰达半导体)
    SMC(DO-214AB)
    VR=1000V IF=5A VF=1.1V IR=5uA
S5MC 数据手册
S5AC THRU S5MC Reverse Voltage - 50 to 1000 Volts Forward Current - 5.0 Ampere SURFACE MOUNT GENERAL RECTIFIER Features DO-214AB/SMC  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90)  Low reverse leakage  Built-in strain relief,ideal for automated placement  High forward surge current capability 0.280(7.11) 0.260(6.60)  High temperature soldering guaranteed: 250 °C/10 seconds at terminals 0.012(0.305) 0.006(0.152) 0.103(2.62) 0.079(2.06) Mechanical Data 0.060(1.52) 0.030(0.76) 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Case: JEDEC DO-214AB/SMC molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.0077 ounce, 0.22 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 5.0A Maximum DC reverse current at rated DCblocking voltage VRRM VRMS VDC Typical thermal resistance (NOTE 2) MDD S5BC MDD S5DC MDD S5GC MDD S5JC MDD S5KC MDD S5MC UNITS 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V I(AV) 5.0 A IFSM 120 A VF 1.0 V IR 5 100 μA 50 pF 35 13 ℃/W -55 to +150 ℃ TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) MDD S5AC CJ RJA RθJC Operating junction and storage temperature range TJ,TSTG *Pulse test: Pulse width 200 sec, Duty cycle 2% Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C. 2.P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. http://www.microdiode.com Rev:2024A2 Page :1 S5AC THRU S5MC Reverse Voltage - 50 to 1000 Volts Forward Current - 5.0 Ampere Typical Characterisitics Fig.1 Forward Current Derating Curve Fig.2 Typical Reverse Characteristics 7.0 Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) 100 TJ=125°C 10 1.0 TJ=25°C 0.1 00 Case Temperature (°C) 20 40 60 80 100 Fig.4 Typical Junction Capacitance 10 TJ=25°C Junction Capacitance (pF) Instaneous Forward Current (A) 140 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Forward Characteristic 1.0 0.1 120 TJ=25°C 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 100 10 1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 120 100 80 60 40 20 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 S5AC THRU S5MC Reverse Voltage - 50 to 1000 Volts Forward Current - 5.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SMC Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 6.15 8.41 2.42 1.50 330.00 50.00 13.00 1.75 7.50 8.00 4.00 2.00 0.25 16.00 16.50 E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) SMC 13" 3,000 4.0 INNER BOX (mm) REEL DIA, (mm) 190*190*41 330 BOX (pcs) 6000 CARTON SIZE (mm) 365*365*340 CARTON (pcs) 42000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 4.3 0.170 B 0.160 C 4.1 7.9 0.311 D 3.8 0.150 E 12 0.472 Unit (inch) Rev:2024A2 Page :3
S5MC
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发射极,4脚集电极,5脚GND,6脚VCC。
4. 参数特性:工作温度范围为-40℃至+85℃,隔离电压为5000Vrms,响应时间为1us。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,适用于需要电气隔离的场合。
6. 应用信息:常用于电源、通信、工业控制等领域。
7. 封装信息:EL817采用DIP-6封装。
很抱歉,暂时无法提供与“S5MC”相匹配的价格&库存,您可以联系我们找货
S5MC
  • 1000+0.24860
库存:515
S5MC
    • 10+0.44045
    • 100+0.36333
    • 600+0.32472
    • 1200+0.31985
    • 3000+0.24364
    库存:3225
