2A07G R0G
2A07G R0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AC
    特性:玻璃钝化芯片结。 高效率,低正向压降。 高电流能力。 高浪涌电流能力。 低功耗。 符合RoHS指令2011/65/EU,并符合WEEE 2002/96/EC。 根据IEC 61249-2-21定...
2A07G R0G 数据手册
2A01G thru 2A07G CREAT BY ART Glass Passivated Rectifiers FEATURES - Glass passivated chip junction - High efficiency, Low VF - High current capability - High surge current capability - Low power loss - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 definition MECHANICAL DATA Case: DO-204AC (DO-15) DO-204AC (DO-15) Molding compound, UL flammability classification rating 94V-0 Base P/N with suffix "G" on packing code - green compound (halogen-free) Base P/N with prefix "H" on packing code - AEC-Q101 qualified Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 1A whisker test with prefix "H" on packing code meet JESD 201 class 2 whisker test Weight: 0.4g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted) PARAMETER SYMBOL 2A 2A 2A 2A 2A 2A 2A 01G 02G 03G 04G 05G 06G 07G UNIT Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current IF(AV) 2 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 70 A Maximum instantaneous forward voltage (Note 1) @2A Maximum reverse current @ rated VR TJ=25 ℃ TJ=125 ℃ Typical junction capacitance (Note 2) Typical thermal resistance Operating junction temperature range Storage temperature range VF IR 1.1 1.0 V 5 μA 100 Cj 15 RθJC RθJL RθJA 22 25 60 TJ - 55 to +150 O C TSTG - 55 to +150 O C pF O C/W Note 1: Pulse test with PW=300 μs, 1% duty cycle Note 2: Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C. Document Number: DS_D1405014 Version: H14 2A01G thru 2A07G Taiwan Semiconductor CREAT BY ART ORDERING INFORMATION PART NO. AEC-Q101 PACKING CODE GREEN COMPOUND QUALIFIED PACKING DO-15 1,500 / Ammo box DO-15 3,500 / 13" Paper reel DO-15 1,000 / Bulk packing CODE A0 2A0xG (Note 1) PACKAGE Prefix "H" R0 Suffix "G" B0 Note 1: "x" defines voltage from 50V (2A01G) to 1000V (2A07G) EXAMPLE AEC-Q101 PREFERRED P/N PART NO. PACKING CODE 2A01G A0 2A01G A0 2A01G A0G 2A01G A0 2A01GHA0 2A01G QUALIFIED H GREEN COMPOUND DESCRIPTION CODE G Green compound A0 AEC-Q101 qualified RATINGS AND CHARACTERISTICS CURVES (TA=25℃ unless otherwise noted) FIG.1 MAXMUM FORWARD CURRENT DERATING CURVE FIG. 2 MAXIMUM FORWARD SURGE CURRENT 2 1.5 1 0.5 0 0 50 100 150 PEAK FORWARD SURGE CURRENT(A) AVERAGE FORWARD CURRENT(A) 2.5 70 60 50 40 30 20 10 0 1 10 NUMBER OF CYCLES AT 60 Hz AMBIENT TEMPERATURE(oC) Fig. 3 TYPICAL FORWARD CHARACTERISTICS FIG. 4 MAXIMUM REVERSE LEAKAGE CHARACTERISTICS 10 100 2A01G 2A02G 1 REVERSE LREAKAGE CURRENT (μA) INSTANTANEOUS FORWARD CURRENT (A) 100 2A03G 2A07G TJ=125℃ 10 1 TJ=75℃ 0.1 TJ=25℃ 0.01 0.1 0.6 0.8 1 FORWARD VOLTAGE (V) Document Number: DS_D1405014 1.2 1.4 0 20 40 60 80 100 120 PERCENTAGE OF VR (%) Version: H14 2A01G thru 2A07G Taiwan Semiconductor CREAT BY ART FIG. 5 TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE (pF) 100 10 f=1.0MHz Vsig=50mVp-p 1 0.1 1 10 100 REVERSE VOLTAGE (V) PACKAGE OUTLINE DIMENSIONS DIM. Unit (mm) Unit (inch) Min Max Min Max A 2.60 3.60 0.102 0.142 B 0.70 0.90 0.028 0.035 C 25.40 - 1.000 - D 5.80 7.60 0.228 0.299 E 25.40 - 1.000 - MARKING DIAGRAM P/N = Specific Device Code G= Green Compound YWW = Date Code F= Document Number: DS_D1405014 Factory Code Version: H14 2A01G thru 2A07G Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied,to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or seling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_D1405014 Version: H14
2A07G R0G 价格&库存
很抱歉,暂时无法提供与“2A07G R0G”相匹配的价格&库存,您可以联系我们找货
