SS34 V7G
SS34 V7G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AB
SS34 V7G 数据手册
SS32 - SS320 Taiwan Semiconductor 3A, 20V - 200V Surface Mount Schottky Barrier Rectifier FEATURES KEY PARAMETERS ● ● ● ● ● Low power loss, high efficiency Ideal for automated placement Guard ring for over-voltage protection High surge current capability Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF(AV) 3 A VRRM 20 - 200 V Package DO-214AB (SMC) Configuration Single die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application Converter MECHANICAL DATA ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) DO-214AB (SMC) ● Moisture sensitivity level: level 1, per J-STD-020 ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 2 whisker test ● Polarity: As marked ● Weight: 0.21 g (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) Repetitive peak reverse voltage VRRM SS 32 SS 32 20 Reverse voltage, total rms value VR(RMS) 14 21 28 35 42 63 70 105 140 V Maximum DC blocking voltage VDC 20 30 40 50 60 90 100 150 200 V Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode Critical rate of rise of off-state voltage Junction temperature IF(AV) PARAMETER SYMBOL Marking code on the device Storage temperature IFSM SS 33 SS 33 30 SS 34 SS 34 40 SS 35 SS 35 50 SS 36 SS 36 60 SS 39 SS 39 90 SS 310 SS 310 100 SS 315 SS 315 150 SS 320 SS 320 200 V 3 A 100 dV/dt TJ UNIT 75 10,000 - 55 to +125 TSTG A V/µs - 55 to +150 °C - 55 to +150 1 °C Version:N1903 SS32 - SS320 Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance per diode RӨJL 17 °C/W Junction-to-ambient thermal resistance per diode RӨJA 55 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage per diode Forward voltage per diode CONDITIONS (1) (1) Reverse current @ rated VR per (2) diode Reverse current @ rated VR per (2) diode Reverse current @ rated VR per (2) diode SS32 SS33 SS34 SS35 SS36 SS39 SS310 SS315 SS320 SS32 SS33 SS34 SS35 SS36 SS39 SS310 SS315 SS320 SS32 SS33 SS34 SS35 SS36 SS39 SS310 SS315 SS320 SS32 SS33 SS34 SS35 SS36 SS39 SS310 SS315 SS320 SS32 SS33 SS34 SS35 SS36 SS39 SS310 SS315 SS320 IF = 3A, TJ = 25°C IF = 3A, TJ = 100°C TJ = 25°C SYMBOL VF VF TYP. MAX. UNIT - 0.50 V - 0.75 V - 0.85 V - 0.95 V - 0.40 V - 0.65 V - 0.70 V - 0.80 V - 0.5 mA - 0.1 mA - 10 mA - 5 mA - - mA - - mA - - mA - 0.5 mA IR TJ = 100°C IR TJ = 125°C IR Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms 2 Version:N1903 SS32 - SS320 Taiwan Semiconductor ORDERING INFORMATION PART NO. PART NO. SUFFIX SS3xx (Note 1,2) PACKING CODE SUFFIX PACKING CODE PACKAGE PACKING R7 SMC 850 / 7" Plastic reel R6 SMC 3,000 / 13" Paper reel SMC 3,000 / 13" Plastic reel V7 Matrix SMC 850 / 7" Plastic reel V6 Matrix SMC 3,000 / 13" Plastic reel M6 H G Note : 1. "xx" defines voltage from 20V (SS32) to 200V (SS320) 2. Only V6 and V7 are all green compound (halogen free) EXAMPLE EXAMPLE P/N PART NO. PART NO. SUFFIX PACKING CODE PACKING CODE SUFFIX DESCRIPTION SS32HR7G SS32 H R7 G AEC-Q101 qualified Green compound 3 Version:N1903 SS32 - SS320 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SS35 - SS320 SS32 - SS34 3 SS35 - SS36 2.5 CAPACITANCE (pF) 2 SS32 - SS34 1.5 1 0.5 100 SS39 - SS320 RESISTIVE OR INDUCTIVE LOAD f=1.0MHz Vsig=50mVp-p 10 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) 100 TJ=125°C 10 TJ=75°C 0.1 TJ=25°C 0.01 SS32 - SS34 SS35 - SS320 0 20 40 60 80 100 120 INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 0.001 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 1 10 10 SS35 - SS36 UF1DLW 1 SS32 - SS34 10 TJ=125°C 10.01 SS39 - SS310 0.001 Pulse width Pules width=300μs 1% duty 0.8 0.9 cycle1 1.1 0.3 0.1 0 140 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) T =25°C SS315 J- SS320 0.1 (A) AVERAGE FORWARD CURRENT (A) 3.5 0.4 0.2 0.5 0.4 0.6 0.6 0.7 0.8 1 1.2 1.4 1.6 FORWARD VOLTAGE (V) 4 Version:N1903 1.2 SS32 - SS320 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Maximum Non-repetitive Forward Surge Current Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE(℃/ W) PEAK FORWARD SURGE CURRENT (A) 100 8.3ms Single Half Sine Wave 80 60 40 SS32-SS34 20 SS35-SS320 0 1 10 100 10 1 0.1 0.01 100 NUMBER OF CYCLES AT 60 Hz 0.1 1 10 100 T-PULSE DURATION (s) 5 Version:N1903 SS32 - SS320 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) Unit (mm) DIM. Unit (inch) Min. Max. Min. Max. A 2.90 3.20 0.114 0.126 B 6.60 7.11 0.260 0.280 C 5.59 6.22 0.220 0.245 D 2.00 2.62 0.079 0.103 E 1.00 1.60 0.039 0.063 F 7.75 8.13 0.305 0.320 G 0.10 0.20 0.004 0.008 H 0.15 0.31 0.006 0.012 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 3.30 0.130 B 2.50 0.098 C 6.80 0.268 D 4.40 0.173 E 9.40 0.370 MARKING DIAGRAM Matrix SMC SMC P/N =Marking Code G =Green Compound YW =Date Code F =Factory Code 6 Version:N1903 SS32 - SS320 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version:N1903
SS34 V7G 价格&库存
很抱歉,暂时无法提供与“SS34 V7G”相匹配的价格&库存,您可以联系我们找货
