S1MLW RVG
S1MLW RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123W(CFP3)
S1MLW RVG 数据手册
S1DLW - S1MLW Taiwan Semiconductor CREAT BY ART 1A, 200V - 1000V Surface Mount Rectifiers FEATURES - Ideal for automated placement - Compact package size - High surge current capability - Low power loss, high efficiency - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 SOD-123W MECHANICAL DATA Case: SOD-123W Molding compound: UL flammability classification rating 94V-0 Moisture sensitivity level (MSL): level 1, per J-STD-020 Part No. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 19 mg (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL Marking code S1DLW S1GLW S1JLW S1KLW S1MLW 1DLW 1GLW 1JLW 1KLW 1MLW UNIT Maximum repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Maximum RMS voltage VRMS 140 280 420 560 700 V Maximum DC blocking voltage VDC 200 400 600 800 1000 V Maximum average forward rectified current IF(AV) 1 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 30 A Maximum instantaneous forward voltage (Note 1) @1A VF 1.1 V Maximum reverse current @ rated VR TJ=25°C TJ=125°C Typical thermal resistance Operating junction temperature range Storage temperature range IR 1 150 μA RθJL RθJA 25 80 °C/W TJ - 55 to +175 °C TSTG - 55 to +175 °C Note 1: Pulse test with PW=300μs, 1% duty cycle Version: B1812 S1DLW - S1MLW Taiwan Semiconductor ORDERING INFORMATION PART NO. PART NO. SUFFIX S1xLW (Note 1, 2) PACKING CODE PACKING CODE PACKING SUFFIX RV H PACKAGE G RQ 3,000 / 7" Plastic reel SOD-123W 10,000 / 13" Paper reel Note 1: "x" defines voltage from 200V (S1DLW) to 1000V (S1MLW) Note 2: Whole series with green compound (halogen-free) EXAMPLE EXAMPLE P/N PART NO. S1JLWHRVG S1JLW PART NO. SUFFIX PACKING CODE PACKING CODE H DESCRIPTION SUFFIX RV AEC-Q101 qualified Green compound G RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) FIG. 2 TYPICAL REVERSE CHARACTERISTICS FIG.1 MAXIMUM FORWARD CURRENT DERATING CURVE AVERAGE FORWARD CURRENT (A) 1 0.8 0.6 0.4 0.2 0 0 25 50 75 100 125 150 Fig 1 100 INSTANTANEOUS REVERSE CURRENT (μA) 1.2 175 10 TJ=125°C 1 Fig.2 0.1 TJ=25°C 0.01 0.001 0 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) LEAD TEMPERATURE (°C) FIG. 3 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT FIG. 4 TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 10 INSTANTANEOUS FORWARD CURRENT (A) 100 PEAK FORWARD SURGE CURRENT(A) 20 10 8.3ms single half sine wave 1 1 10 NUMBER OF CYCLES AT 60 Hz 100 TJ=125°C 1 TJ=25°C 0.1 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 FORWARD VOLTAGE (V) Version: B1812 S1DLW - S1MLW Taiwan Semiconductor FIG. 5 TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE (pF) 100 f=1.0MHz Vsig=50mVp-p 10 1 0.1 1 10 100 REVERSE VOLTAGE (V) PACKAGE OUTLINE DIMENSIONS SOD-123W Unit (mm) DIM. Unit (inch) Min Max Min Max B 1.70 1.90 0.067 0.075 C 2.60 2.90 0.102 0.114 D 0.10 0.22 0.004 0.009 E 0.90 1.02 0.035 0.040 F 0.90 1.05 0.035 0.041 G 3.60 3.80 0.142 0.150 H 0.50 0.85 0.020 0.033 I 0.00 0.10 0.000 0.004 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 1.4 0.055 B 1.2 0.047 C 3.1 0.122 D 1.9 0.075 E 4.3 0.169 MARKING DIAGRAM P/N = Marking Code YW = Date Code F = Factory Code Version: B1812 S1DLW - S1MLW Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: B1812
S1MLW RVG 价格&库存
很抱歉,暂时无法提供与“S1MLW RVG”相匹配的价格&库存,您可以联系我们找货
