SS16LW RVG
SS16LW RVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123W(CFP3)
    电压:60V 电流:1A
SS16LW RVG 数据手册
SS14LW - SS115LW Taiwan Semiconductor CREAT BY ART 1A, 40V - 150V Surface Mount Schottky Barrier Rectifiers FEATURES - Low power loss, high efficiency - Ideal for automated placement - Guard ring for over-voltage protection - High surge current capability - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 MECHANICAL DATA SOD-123W Case: SOD-123W Molding compound: UL flammability classification rating 94V-0 Moisture sensitivity level: level 1, per J-STD-020 Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 16 mg (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL Marking Code SS14LW SS16LW SS110LW SS115LW UNIT 14LW 16LW 10LW A5LW Maximum repetitive peak reverse voltage VRRM 40 60 100 150 V Maximum RMS voltage VRMS 28 42 70 105 V Maximum DC blocking voltage VDC 40 60 100 150 V Maximum average forward rectified current IF(AV) 1 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 30 A Maximum instantaneous forward voltage (Note 1) @1A VF Maximum reverse current @ rated VR IR TJ=25°C Typical thermal resistance Operating junction temperature range Storage temperature range 0.55 0.70 0.80 100 RθJL RθJA 0.95 10 25 80 V μA °C/W TJ - 55 to +125 - 55 to +150 °C TSTG - 55 to +125 - 55 to +150 °C Note 1: Pulse test with PW=300μs, 1% duty cycle Version: B1906 SS14LW - SS115LW Taiwan Semiconductor ORDERING INFORMATION PART NO. PART NO. SUFFIX SS1xLW (Note 1, 2) PACKING CODE PACKING CODE PACKING SOD-123W 3,000 / 7" Plastic reel 10,000 / 13" Paper reel SUFFIX RV RQ H PACKAGE G Note 1: "x" defines voltage from 40V (SS14LW) to 150V (SS115LW) Note 2: Whole series with green compound ( halogen-free) EXAMPLE EXAMPLE P/N PART NO. SS14LWHRVG SS14LW PART NO. SUFFIX PACKING CODE PACKING CODE H DESCRIPTION SUFFIX RV AEC-Q101 qualified Green compound G RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) 10 1.2 Pulse width=300μs 1% duty cycle 1 0.8 0.6 SS14LW 0.4 Resistive or inductive load 0.2 0 0 25 50 75 100 125 150 INSTANTANEOUS FORWARD CURRENT (A) AVERAGE FORWARD CURRENT (A) SS16LW~SS115LW Fig.2 1 SS110L W 0.1 0 0.2 0.4 LEAD TEMPERATURE (°C) INSTANTANEOUS REVERSE CURRENT (μA) 8.3ms single half sine wave 20 15 10 5 0 NUMBER OF CYCLES AT 60 Hz 1 1.2 1.4 1.6 1.8 2 110L 110L 1000 25 10 0.8 FIG. 4 TYPICAL REVERSE CHARACTERISTICS 30 1 0.6 FORWARD VOLTAGE (V) FIG. 3 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT PEAK FORWARD SURGE CURRENT (A) Fig 1 FIG. 2 TYPICAL FORWARD CHARACTERISTICS FIG.1 FORWARD CURRENT DERATING CURVE 100 SS110LW~SS115LW 100 TJ=125°C Fig.5 10 1 TJ=25°C 0.1 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) Version: B1906 SS14LW - SS115LW Taiwan Semiconductor FIG. 5 TYPICAL JUNCTION CAPACITANCE 100 CAPACITANCE (pF) 80 60 40 20 f=1.0MHz Vsig=50mVp-p 0 0.1 1 10 100 REVERSE VOLTAGE (V) PACKAGE OUTLINE DIMENSIONS SOD-123W Unit (mm) DIM. Unit (inch) Min Max Min Max B 1.70 1.90 0.067 0.075 C 2.60 2.90 0.102 0.114 D 0.10 0.22 0.004 0.009 E 0.90 1.02 0.035 0.040 F 0.90 1.05 0.035 0.041 G 3.60 3.80 0.142 0.150 H 0.50 0.85 0.020 0.033 I 0.00 0.10 0.000 0.004 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 1.4 0.055 B 1.2 0.047 C 3.1 0.122 D 1.9 0.075 E 4.3 0.169 MARKING DIAGRAM P/N = Marking Code YW = Date Code F = Factory Code Version: B1906 SS14LW - SS115LW Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Version: B1906
SS16LW RVG
1. 物料型号:文档描述了SS14LW至SS115LW系列的肖特基二极管,这些型号的二极管具有不同的最大重复峰值反向电压。
2. 器件简介:这些肖特基二极管具有低功耗、高效率、适合自动化放置、有过压保护的护环、高浪涌电流能力,并且符合RoHS指令和WEEE指令,无卤素。
3. 引脚分配:文档中提到了极性通过阴极带指示,但没有提供详细的引脚分配图。
4. 参数特性:包括最大重复峰值反向电压、最大RMS电压、最大直流阻断电压、最大平均正向整流电流、峰值正向浪涌电流、最大瞬态正向电压、最大反向电流和典型热阻。
5. 功能详解:文档提供了正向电流降额曲线、典型正向特性曲线、最大非重复性正向浪涌电流、典型反向特性曲线、典型结电容等图表。
6. 应用信息:文档中没有明确提供应用信息,但根据器件的特性,可以推断它们适用于需要高效率和高浪涌电流能力的场合。
7. 封装信息:提供了SOD-123W封装的详细尺寸和建议的焊盘布局。
SS16LW RVG 价格&库存
很抱歉,暂时无法提供与“SS16LW RVG”相匹配的价格&库存,您可以联系我们找货
