1N4758A A0G
1N4758A A0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-204AL
    1N4758A A0G
1N4758A A0G 数据手册
1N4740A - 1M200Z Taiwan Semiconductor 1W, 10V - 200V Glass Passivated Junction Silicon Zener Diode FEATURES KEY PARAMETERS ● ● ● ● ● ● Glass passivated chip junction Low profile package Built-in strain relief Low inductance Typical IR less than 5μA above 11V Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT VZ 10 - 200 V Test current IZT 1.2 - 25 mA Ptot 1 W TJ MAX 150 °C Package DO-204AL (DO-41) Configuration Single Die Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● Case: DO-204AL (DO-41) Molding compound meets UL 94 V-0 flammability rating Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) ● Terminal: Pure tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 2 whisker test ● Weight: 0.3g (approximately) DO-204AL (DO-41) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT 1.00 6.67 Watts mW/°C Power dissipation at TA=50°C Derate above 50°C (Note 1) Ptot Operating junction temperature range TJ -55 to +150 °C TSTG -55 to +150 °C Storage temperature range Note: 1. Mounted on Cu-Pad size 5mm x 5mm 1 Version:N1706 1N4740A - 1M200Z Taiwan Semiconductor ORDERING INFORMATION PART NO. PARTNO. SUFFIX PACKING CODE PACKING CODE SUFFIX A0 1N47xxA 1MxxxZ (Note 1) PACKAGE 3,000 / Ammo box (52mm taping) 5,000 / 13" Paper reel 5,000 / 13" Paper reel (Reverse) 1,000 / Bulk packing DO-41 R0 DO-41 H G R1 DO-41 B0 DO-41 PACKING Notes : 1. "xx" defines voltage from 10V (1N4740A) to 200V (1M200Z) EXAMPLE EXAMPLE P/N PART NO. PART NO. SUFFIX PACKING CODE PACKING CODE SUFFIX DESCRIPTION 1N4740AHA0G 1N4740A H A0 G AEC-Q101 qualified Green compound 2 Version:N1706 1N4740A - 1M200Z Taiwan Semiconductor MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) Test current Zener voltage Device (Note 1) Zener Impedance VZ @ IZT IZT ZZT@IZT V mA Ω Leakage current Surge current IR@VR IR ZZK@IZK Ω mA μA V mA Nom. Min. (Note 2) Max. Max. (Note 3) 1N4740A 9.50 10 10.50 25.0 7 700 0.25 10 7.6 454 1N4741A 10.45 11 11.55 23.0 8 700 0.25 5 8.4 414 1N4742A 11.40 12 12.60 21.0 9 700 0.25 5 9.1 380 1N4743A 12.35 13 13.65 19.0 10 700 0.25 5 9.9 344 1N4744A 14.25 15 15.75 17.0 14 700 0.25 5 11.4 304 1N4745A 15.20 16 16.80 15.5 16 700 0.25 5 12.2 285 1N4746A 17.10 18 18.90 14.0 20 750 0.25 5 13.7 250 1N4747A 19.00 20 21.00 12.5 22 750 0.25 5 15.2 225 1N4748A 20.90 22 23.10 11.5 23 750 0.25 5 16.7 205 1N4749A 22.80 24 25.20 10.5 25 750 0.25 5 18.2 190 1N4750A 25.65 27 28.35 9.5 35 750 0.25 5 20.6 170 1N4751A 28.50 30 31.50 8.5 40 1000 0.25 5 22.8 150 1N4752A 31.35 33 34.65 7.5 45 1000 0.25 5 25.1 135 1N4753A 34.20 36 37.80 7.0 50 1000 0.25 5 27.4 125 1N4754A 37.05 39 40.95 6.5 60 1000 0.25 5 29.7 115 1N4755A 40.85 43 45.15 6.0 70 1500 0.25 5 32.7 110 1N4756A 44.65 47 49.35 5.5 80 1500 0.25 5 35.8 95 1N4757A 48.45 51 53.55 5.0 95 1500 0.25 5 38.8 90 1N4758A 53.20 56 58.80 4.5 110 2000 0.25 5 42.6 80 1N4759A 58.90 62 65.10 4.0 125 2000 0.25 5 47.1 70 1N4760A 64.60 68 71.40 3.7 150 2000 0.25 5 51.7 65 1N4761A 71.25 75 78.75 3.3 175 2000 0.25 5 56.0 60 1N4762A 77.90 82 86.10 3.0 200 3000 0.25 5 62.2 55 1N4763A 86.45 91 95.55 2.8 250 3000 0.25 5 69.2 50 1N4764A 95.00 100 105.00 2.5 350 3000 0.25 5 76.0 45 1M110Z 104.50 110 115.50 2.3 450 4000 0.25 5 83.6 - 1M120Z 114.00 120 126.00 2.0 550 4500 0.25 5 91.2 - 1M130Z 123.50 130 136.50 1.9 700 5000 0.25 5 98.8 - 1M150Z 142.50 150 157.50 1.7 1000 6000 0.25 5 114.0 - 1M160Z 152.00 160 168.00 1.6 1100 6500 0.25 5 121.6 - 1M180Z 171.00 180 189.00 1.4 1200 7000 0.25 5 136.8 - 1M200Z 190.00 200 210.00 1.2 1500 8000 0.25 5 152.0 - 3 Version:N1706 1N4740A - 1M200Z Taiwan Semiconductor Notes : 1. Tolerance and Type Number Designation. The type numbers losted have a standard tolerance on the nominal zener voltage of ±5% 2. Specials Available Include: A. Nominal zener voltages between the voltages shown and tighter voltage tolerances B. Matched sets 3. Zener Voltage (Vz) Measurement. Guarantees the zener voltage when messured at 90 seconds while maintaining the lead temperature(TL) at 30°C±1°C, from the diode body 4. Zener Impedance (Zz) Derivation. The zener impedance is derives from the 60 cycle AC voltage, which results when an accurrent having and rms value equal to 10% of the DC zener current (IZT or IZK) is superimposed on IZT or IZK. 5. Surge Current (IR) Non-Repetitive. The rating listd in the electrical chatacteristics table is maximum peak, nonrepetitive, reverse surge current of 1/2 square wave or equivalent sine wave pulse of 1/120 second duration superimposed on the test current, IZT per JEDEC registration; however, actual device capability is as described in Figure 11. 4 Version:N1706 1N4740A - 1M200Z Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Forward Characteristics 1000 1.25 MINIMUM MAXIMUM 1 IF, FORWARD CURRENT (mA) PD, MAXIMUM POWER DISSIPATION (WATTS) Fig.1 Power Temperature Derating Curve 0.75 0.5 0.25 100 70°C 150°C 10 25°C 0°C 1 0 0 25 50 75 100 125 0.4 150 0.5 o AMBIENT TEMPERATURE ( C) 0.7 0.8 0.9 1 1.1 VF, FORWARD VOLTAGE (V) Fig.3 Effect Of Zener Current On Zener impedance Fig.4 Effect Of Zener Voltage On Zener Impedance 1000 1000 100 Zz, DYNAMIC IMPEDANCE (Ω) Iz(rms)=0.1 Iz(dc) f=1KHz Zz, DYNAMIC IMPEDANCE (Ω) 0.6 47V 27V 10 0.8V Iz = 1mA Iz(rms)=0.1 Iz(dc) f=1KHz 100 5 mA 20mA 10 1 1 0 1 10 1 100 10 100 Iz, ZENER CURRENT(mA) Iz, ZENER CURRENT (mA) 5 Version:N1706 1N4740A - 1M200Z Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig5. Typical Leakage Current Fig6. Typical Capacitance versus Vz 10000 1000 TYPICAL LEAKAGE CURRENT AT 80% OF NOMINAL BREAKDOWN VOLTAGE 1000 C, CAPACITANCE(pF) IR, LEAKAGE CURRENT(μA) 100 10 1 125°C 0.1 25°C 0.01 0.001 0V BIAS 100 1.0V BIAS 50% OF BREAKDOWN BIAS 10 3 4 5 6 7 8 9 1 10 11 12 13 14 15 100 Vz, FORWARD VOLTAGE (V) Vz, NOMINAL ZENER VOLTAGE(V) Fig7. Temperature Coefficients Fig8. Temperature Coefficients 100 θVz, TEMPERATURE COEFFICIENT (mV/oC) 12 o θVz, TEMPERATURE COEFFICIENT (mV/ C) 10 10 8 a-RANGE FOR UNITS TO 12 VOLTS 6 4 2 RANGE Vz@ IZT 0 -2 -4 2 3 4 5 6 7 8 9 10 11 12 b-RANGE FOR UNITS 12 TO 100 VOLTS 10 RANGE Vz@ IZT 1 10 100 Vz, ZENER VOLTAGE(V) Vz, ZENER VOLTAGE(V) 6 Version:N1706 1N4740A - 1M200Z Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig9. Effect Of Zener Curren Fig10. Typical Thermal Resistance versus Lead Length 175 4 ΘJL, JUNCTION TO LEAD THERMAL RESISTANCE(oC/W) Vz@ IZT 0.01mA 1 mA 2 20mA 0 -2 NOTE:BELOW 3 VOLTAGE ABOVE a VOLTS CHANGES IN ZENER CURRENT NOT AFFECT TEMPERATURE COEFFICIENTS -4 3 3.5 4 4.5 5 5.5 6 6.5 7 7.5 150 125 100 75 50 25 0 8 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 L, LEAD LENGTH TO HEAT SINK(INCHES) Vz, ZENER VOLTAGE(V) Fig11. Maximum Surge Power 11V-91V NON-REPETITIVE 5% DUTY 10 θVz, TEMPERATURE COEFFICIENT (mV/oC) 100 PPK, PEAK SURGE POWER WATTS θVz, TEMPERATURE COEFFICIENT (mV/℃) 6 10% DUTY 20% DUTY 1 0 0 1 10 RECTANGULAR WAVEFORM PRIOR TO INITIAL PULSE 0.8V-10V NON-REPETITIVE 100 1000 Vz, NOMINAL ZENER VOLTAGE(V) PW, PULSE WIDTH (ms) 7 Version:N1706 1 1N4740A - 1M200Z Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-204AL (DO-41) DIM. Unit (mm) Unit (inch) Min Max Min Max A 2.00 2.70 0.079 0.106 B 0.71 0.86 0.028 0.034 C 25.40 - 1.000 - D 4.20 5.20 0.165 0.205 E 25.40 - 1.000 - MARKING DIAGRAM P/N G YWW F 8 = Marking Code = Green Compound = Date Code = Factory Code Version:N1706 1N4740A - 1M200Z Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 9 Version:N1706
1N4758A A0G 价格&库存
很抱歉,暂时无法提供与“1N4758A A0G”相匹配的价格&库存,您可以联系我们找货
