SK36A R3G
SK36A R3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
SK36A R3G 数据手册
4 SK32A - SK320A Taiwan Semiconductor 3A, 20V - 200V Surface Mount Schottky Barrier Rectifier FEATURES KEY PARAMETERS ● ● ● ● ● Low power loss, high efficiency Ideal for automated placement Guard ring for over-voltage protection High surge current capability Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● ● ● ● PARAMETER VALUE UNIT IF(AV) 3 A VRRM 20 - 200 V IFSM 70 A TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● Case: DO-214AC (SMA) ● Molding compound meets UL 94V-0 flammability rating ● Packing code with suffix "G" means green compound (halogen-free) ● Part no. with suffix “H” means AEC-Q101 qualified ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 2 whisker test ● Polarity: As marked ● Weight: 0.07 g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device Repetitive peak reverse voltage Reverse voltage, total rms value Maximum DC blocking voltage Forward current Surge peak forward current, 8.3 ms single half sine-wave superimposed on rated load per diode Critical rate of rise of off-state voltage SK SK SK SK SK SK SK SK SK UNIT 32A 33A 34A 35A 36A 39A 310A 315A 320A SK SK SK SK SK SK SK SK SK 32A 33A 34A 35A 36A 39A 310A 315A 320A VRRM 20 30 40 50 60 90 100 150 200 V VR(RMS) 14 21 28 35 42 63 70 105 140 V VDC 20 30 40 50 60 90 100 150 200 V IF(AV) 3 A IFSM 70 A dV/dt 10,000 V/µs Junction temperature TJ - 55 to +150 °C Storage temperature TSTG - 55 to +150 °C 1 Version:U1809 4 SK32A - SK320A Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP. UNIT Junction-to- ambient thermal resistance RӨJA 66 °C/W Junction-to-lead thermal resistance RӨJL 25 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL TYP. MAX. UNIT - 0.55 V - 0.72 V - 0.85 V - 0.95 V - 0.5 mA - 0.2 mA - 0.1 mA - 10 mA - 5 mA - - mA - - mA - 10 mA - 0.5 mA SK32A SK33A SK34A SK35A Forward voltage per diode (1) SK36A IF = 3A,TJ = 25°C VF SK39A SK310A SK315A SK320A SK32A SK33A SK34A Reverse current @ rated VR per diode (2) SK35A SK36A TJ=25°C IR SK39A SK310A SK315A SK320A SK32A SK33A SK34A Reverse current @ rated VR per diode (2) SK35A SK36A TJ = 100°C IR SK39A SK310A SK315A SK320A SK32A SK33A SK34A Reverse current @ rated VR per diode (2) SK35A SK36A TJ = 125°C IR SK39A SK310A SK315A SK320A Notes: 1. Pulse test with PW=0.3 ms 2. Pulse test with PW=30 ms 2 Version:U1809 4 SK32A - SK320A Taiwan Semiconductor ORDERING INFORMATION PART NO. SK3xxA (Note 1) PART NO. SUFFIX PACKING PACKING CODE CODE SUFFIX(*) PACKAGE PACKING R3 SMA 1,800 / 7" Plastic reel R2 SMA 7,500 / 13" Paper reel M2 SMA 7,500 / 13" Plastic reel Folded SMA 1,800 / 7" Plastic reel Folded SMA 7,500 / 13" Paper reel F4 Folded SMA 7,500 / 13" Plastic reel E3 Clip SMA 1,800 / 7" Plastic reel E2 Clip SMA 7,500 / 13" Paper reel F3 H G F2 Note: 1."xx" defines voltage from 20V (SK32A) to 200V (SK320A) *: Optional available EXAMPLE P/N EXAMPLE P/N PART NO. SK36AHR3G SK36A PART NO. PACKING PACKING CODE SUFFIX CODE SUFFIX H R3 G 3 DESCRIPTION AEC-Q101 qualified Green compound Version:U1809 4 SK32A - SK320A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 1000 SK32A-SK34A 3 SK35A - SK36A 2.5 CAPACITANCE (pF) AVERAGE FORWARD CURRENT (A) 3.5 2 1.5 1 0.5 100 SK39A - SK320A f=1.0MHz Vslg=50mVp-p RESISTIVE OR INDUCTIVE LOAD 0 10 50 60 70 80 90 100 110 120 130 140 150 0.1 1 LEAD TEMPERATURE (°C) SK32A - SK36A, 100°C SK39A - SK320A, 25°C SK39A - SK320A, 125°C SK35A - SK36A, 125°C 1 0.1 0.01 SK32A - SK36A, 25°C 0.001 20 40 60 80 100 100 10 SK35A - SK36A UF1DLW 1 SK32A - SK34A TJ=125°C 10 TJ=25°C 0.1 (A) INSTANTANEOUS FORWARD CURRENT (A) INSTANTANEOUS REVERSE CURRENT (mA) Fig.4 Typical Forward Characteristics 100 0 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 1 0.01 SK39A - SK320A 0.001 0.3 0.1 0 0.4 0.2 0.5 0.4 0.6 0.6 0.7 0.8 Pulse width Pulse width=300μs 1% duty cycle 0.8 0.9 1 1.1 1 1.2 1.4 1.6 FORWARD VOLTAGE (V) PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 4 Version:U1809 1.2 4 SK32A - SK320A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) PEAK FORWARD SURGE CURRENT (A) 70 8.3ms Single Half Sine Wave 60 50 40 30 20 10 0 1 10 100 Fig.6 Typical Transient Thermal Characteristics TRANSIENT THERMAL IMPEDANCE A (℃/W) Fig.5 Maximum Non-repetitive Forward Surge Current NUMBER OF CYCLES AT 60 Hz 100 10 1 0.1 0.01 0.1 1 10 100 T-PULSE DURATION(s) 5 Version:U1809 4 SK32A - SK320A Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) Unit (mm) DIM. Unit (inch) Min Max Min Max A 1.27 1.58 0.050 0.062 B 4.06 4.60 0.160 0.181 C 2.29 2.83 0.090 0.111 D 1.99 2.50 0.078 0.098 E 0.90 1.41 0.035 0.056 F 4.95 5.33 0.195 0.210 G 0.10 0.20 0.004 0.008 H 0.15 0.31 0.006 0.012 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 1.68 0.066 B 1.52 0.060 C 3.93 0.155 D 2.41 0.095 E 5.45 0.215 MARKING DIAGRAM P/N G YW F 6 = Marking Code = Green Compound = Date Code = Factory Code Version:U1809 4 SK32A - SK320A Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version:U1809
SK36A R3G 价格&库存
很抱歉,暂时无法提供与“SK36A R3G”相匹配的价格&库存,您可以联系我们找货
