ABS8 RGG
ABS8 RGG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMD4
    耐压:800V 电流:1A
ABS8 RGG 数据手册
ABS2 - ABS10 Taiwan Semiconductor CREAT BY ART 1A, 200V - 1000V Glass Passivated Bridge Rectifiers FEATURES - Glass passivated junction - Ideal for automated placement - Reliable low cost construction utilizing molded plastic technique - High surge current capability - UL Recognized File # E-326854 - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 definition ABS MECHANICAL DATA Case: Molded plastic body Molding compound, UL flammability classification rating 94V-0 Moisture sensitivity level: level 1, per J-STD-020 Part no. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: Polarity as marked on the body Weight: 0.12 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL ABS2 ABS4 ABS6 ABS8 ABS10 Unit Maximum repetitive peak reverse voltage VRRM 200 400 600 800 1000 V Maximum RMS voltage VRMS 140 280 420 560 700 V Maximum DC blocking voltage VDC 200 400 600 800 1000 V Maximum average forward rectified current On glass-epoxy On aluminum substrate IF(AV) 0.8 1.0 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 30 A Rating for fusing (t
ABS8 RGG 价格&库存
很抱歉,暂时无法提供与“ABS8 RGG”相匹配的价格&库存,您可以联系我们找货
ABS8 RGG
  • 5+0.97751
  • 50+0.78020
  • 150+0.68148
库存:68
