1SMB5926 - 1SMB5956
Taiwan Semiconductor
3W, 11V - 200V Surface Mount Silicon Zener Diode
FEATURES
KEY PARAMETERS
Ideal for automated placement
Glass passivated junction
Low inductance
Moisture sensitivity level: level 1, per J-STD-020
AEC-Q101 qualified available:
ordering code with suffix “H”
● Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
PARAMETER
VALUE
UNIT
VZ
11 - 200
V
Test current IZT
1.9 – 34.1
mA
Ptot
3.0
W
TJ MAX
150
°C
Package
DO-214AA (SMB)
Configuration
Single die
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: DO-214AA (SMB)
Molding compound meets UL 94 V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.1 g (approximately)
DO-214AA (SMB)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
DC power dissipation at TL=75°C, measure at
zero lead length (Note 1) derate above 75°C
DC power dissipation at TA=25°C
Derate above 25°C
SYMBOL
TJ
VALUE
3.0
40
550
4.4
-55 to +150
UNIT
W
mW/°C
mW
mW/°C
°C
TSTG
-55 to +150
°C
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
25
°C/W
Junction-to-ambient thermal resistance
RӨJA
226
°C/W
Ptot
Ptot
Junction temperature
Storage temperature
Note:
1. Mounted on Cu-Pad size 5mm x 5mm on PCB
THERMAL PERFORMANCE
PARAMETER
1
Version: L1903
1SMB5926 - 1SMB5956
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Device
(Note 1)
Device
Marking
Code
Nominal Zener
Voltage
Min.
Vz@Iz
V
Nom
(Note 2)
Test Zener Impedance
(Note 3)
current
IZT
mA
ZZT @ IZT
Ω
ZZK@IZK
Ω
mA
Leakage
Current
Maximum DC
Zener
Current
IR@VR
μA
V
IZM
mA(DC)
Max.
1SMB5926
926B
10.45
11
11.55
34.1
5.5
550
0.25
1
8.4
136
1SMB5927
927B
11.40
12
12.60
31.2
6.5
550
0.25
1
9.1
125
1SMB5928
928B
12.35
13
13.65
28.8
7.0
550
0.25
1
9.9
115
1SMB5929
929B
14.25
15
15.75
25.0
9.0
600
0.25
1
11.4
100
1SMB5930
930B
15.20
16
16.80
23.4
10.0
600
0.25
1
12.2
94
1SMB5931
931B
17.10
18
18.90
20.8
12.0
650
0.25
1
13.7
83
1SMB5932
932B
19.00
18.7
14.0
650
0.25
1
15.2
75
1SMB5933
933B
20.90
22
23.10
17.0
17.5
650
0.25
1
16.7
68
1SMB5934
934B
22.80
24
25.20
15.6
19
700
0.25
1
18.2
63
1SMB5935
935B
25.65
27
28.35
13.9
23
700
0.25
1
20.6
56
1SMB5936
936B
28.50
30
31.50
12.5
26
750
0.25
1
22.8
50
1SMB5937
937B
31.35
33
34.65
11.4
33
800
0.25
1
25.1
45
1SMB5938
938B
34.20
36
37.80
10.4
38
850
0.25
1
27.4
42
1SMB5939
939B
37.05
39
40.95
9.6
45
900
0.25
1
29.7
38
1SMB5940
940B
40.85
43
45.15
8.7
53
950
0.25
1
32.7
35
1SMB5941
941B
44.65
47
49.35
8.0
67
1000 0.25
1
35.8
32
1SMB5942
942B
48.45
51
53.55
7.3
70
1100 0.25
1
38.8
29
1SMB5943
943B
53.20
56
58.80
6.7
86
1300 0.25
1
42.6
27
1SMB5944
944B
58.90
62
65.10
6.0
100
1500 0.25
1
47.1
24
1SMB5945
945B
64.60
68
71.40
5.5
120
1700 0.25
1
51.7
22
1SMB5946
946B
71.25
75
78.75
5.0
140
2000 0.25
1
56.0
1SMB5947
947B
77.90
82
86.10
4.6
160
2500 0.25
1
62.2
18
1SMB5948
948B
86.45
91
95.55
4.1
200
3000 0.25
1
69.2
16
1SMB5949
949B
95.00
100
105.00
3.7
250
3100 0.25
1
76.0
15
1SMB5950
950B
104.50
110
115.50
3.4
300
4000 0.25
1
83.6
13
1SMB5951
951B
114.00
120
126.00
3.1
360
4500 0.25
1
91.2
12
1SMB5952
952B
123.50
130
136.50
2.9
450
5000 0.25
1
98.8
11
1SMB5953
953B
142.50
150
157.50
2.5
600
6000 0.25
1
114.0
10
1SMB5954
954B
152.00
160
168.00
2.3
700
6500 0.25
1
121.6
9
1SMB5955
955B
171.00
180
189.00
2.1
900
7000 0.25
1
136.8
8
1SMB5956
956B
190.00
200
210.00
1.9
1200
8000 0.25
1
152.0
7
Notes:
1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5%
2. Zener voltage (Vz) measurement
Nominal Zener voltage is measured with the device junction in thermal equilibrium with ambient temperature 25°C
3. Zener impedance (Zz) derivation : ZZT and ZZK are measured by dividing the AC voltage
drop across the device by the AC current applied.
The specified limits are for Iz(AC) = 0.1 Iz(DC) with the AC frequency = 60 Hz
2
Version: L1903
1SMB5926 - 1SMB5956
ORDERING INFORMATION
ORDERING CODE
(Note 1,2)
PACKAGE
PACKING
STATUS
1SMBxxxxHR5G
SMB
850 / 7" Plastic reel
Active
1SMBxxxxHR4G
SMB
3,000 / 13" Paper reel
NRND
1SMBxxxxHM4G
SMB
3,000 / 13" Plastic reel
Active
1SMBxxxx R5G
SMB
Active
1SMBxxxx R4G
SMB
NRND
1SMBxxxx M4G
SMB
Active
Note 1:
"xxxx" defines voltage from 11V (1SMB5926) to 200V (1SMB5956)
Note 2:
"H" means AEC-Q101 qualified
3
Version: L1903
1SMB5926 - 1SMB5956
CHARACTERISTICS CURVES
PD, MAXIMUM POWER DISSIPATION (WATTS)
Fig1. Steady State Power Derating
Fig2. Maximum Surge Power
4
PPK, PEAK SURGE POWER (W)
1000
3
TL
2
1
TA
50
75
100
125
100
10
150
T, TEMPERATURE(℃)
3
4
5
OVZ, TEMPERATURE COEFFICIENT (mV/℃)
6
7
8
9
100
Fig4. Zener Voltage 14 To Voltages
Vz@IZT
2
10
PW, PULSE WIDTH(ms)
Fig3. Zener Voltage – To 12 Voltages
10
9
8
7
6
5
4
3
2
1
-2
-3
-4
1
10
11
100
Vz@IZT
10
10
12
100
Vz, ZENER VOLTAGE (V)
VZ, ZENER VOLTAGE(V)
4
Version: L1903
1SMB5926 - 1SMB5956
Fig5. Vz = 3.3 thru 10 V
Fig6. Vz = 12 thru 82 V
IZ, ZENER CURRENT (mA)
100
10
1
0.1
10
1
0.1
2
3
4
5
6
7
8
9
10
9
8
7
6
5
4
3
2
1
-2
-3
-4
Vz@IZT
2
3
4
5
6
7
8
9
10
10
30 40 50 60 70 80
90
100
Fig8. Effect Of Zener Current
Fig7. Effect Of Zener Voltage
100
11
12
100
Vz@IZT
10
10
100
5
Version: L1903
1SMB5926 - 1SMB5956
Fig9. Capacitance Curve
Fig10. Typical Pulse Rating Curve
10
1000
PPK, PEAK POWER (KW)
C, CAPACITANCE(pF)
MEASURED@
ZERO BIAS
MEASURED @ Vz/2
100
10
NONREPETITIVE,
EXPONENTIAL
PULSE WAVEFORM
1
0.1
0.01
1
10
100
0.01
0.1
BREAKDOWN VOLTAGE (V)
1
10
Tp. PULSE WIDTH (ms)
Fig11. Pulse Waveform
Fig12. Pulse Waveform
120
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
120
110
IPPM, PEAK PULSE CURRENT (%)
140
Rise time tr=10μs to 100%
100
Peak value
IPPM
80
Half value-IPPM/2
60
40
10/1000μs, waveform
td
8/20 μs WAVEFORM
AS DEFINED BY ANSI
C62.1 AND IEC 801.5
100
90
0.9 IPEAK
80
70
60
0.5 IPEAK
50
40
30
t = 8μs
0.1 IPEAK
1
1.5
2
2.5
3
t, TIME (ms)
0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.1
T, TIME(ms)
6
Version: L1903
1SMB5926 - 1SMB5956
PACKAGE OUTLINE DIMENSIONS
DO-214AA (SMB)
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
1.95
2.20
0.077
0.087
B
4.05
4.60
0.159
0.181
C
3.30
3.95
0.130
0.156
D
1.95
2.65
0.077
0.104
E
0.75
1.60
0.030
0.063
F
5.10
5.60
0.201
0.220
G
0.05
0.20
0.002
0.008
H
0.15
0.31
0.006
0.012
SUGGESTED PAD LAYOUT
Symbol
Unit (mm)
Unit (inch)
A
2.3
0.091
B
2.5
0.098
C
4.3
0.169
D
1.8
0.071
E
6.8
0.268
MARKING DIAGRAM
P/N
G
YW
F
7
= Marking Code
= Green Compound
= Date Code
= Factory Code
Version: L1903
1SMB5926 - 1SMB5956
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for
application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
8
Version: L1903
