1SMB5935HM4G
1SMB5935HM4G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO214AA
    独立式 耐压:27V 电流:1uA
1SMB5935HM4G 数据手册
1SMB5926 - 1SMB5956 Taiwan Semiconductor 3W, 11V - 200V Surface Mount Silicon Zener Diode FEATURES KEY PARAMETERS ● ● ● ● ● Ideal for automated placement Glass passivated junction Low inductance Moisture sensitivity level: level 1, per J-STD-020 AEC-Q101 qualified available: ordering code with suffix “H” ● Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC PARAMETER VALUE UNIT VZ 11 - 200 V Test current IZT 1.9 – 34.1 mA Ptot 3.0 W TJ MAX 150 °C Package DO-214AA (SMB) Configuration Single die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AA (SMB) Molding compound meets UL 94 V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.1 g (approximately) DO-214AA (SMB) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER DC power dissipation at TL=75°C, measure at zero lead length (Note 1) derate above 75°C DC power dissipation at TA=25°C Derate above 25°C SYMBOL TJ VALUE 3.0 40 550 4.4 -55 to +150 UNIT W mW/°C mW mW/°C °C TSTG -55 to +150 °C SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 25 °C/W Junction-to-ambient thermal resistance RӨJA 226 °C/W Ptot Ptot Junction temperature Storage temperature Note: 1. Mounted on Cu-Pad size 5mm x 5mm on PCB THERMAL PERFORMANCE PARAMETER 1 Version: L1903 1SMB5926 - 1SMB5956 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Device (Note 1) Device Marking Code Nominal Zener Voltage Min. Vz@Iz V Nom (Note 2) Test Zener Impedance (Note 3) current IZT mA ZZT @ IZT Ω ZZK@IZK Ω mA Leakage Current Maximum DC Zener Current IR@VR μA V IZM mA(DC) Max. 1SMB5926 926B 10.45 11 11.55 34.1 5.5 550 0.25 1 8.4 136 1SMB5927 927B 11.40 12 12.60 31.2 6.5 550 0.25 1 9.1 125 1SMB5928 928B 12.35 13 13.65 28.8 7.0 550 0.25 1 9.9 115 1SMB5929 929B 14.25 15 15.75 25.0 9.0 600 0.25 1 11.4 100 1SMB5930 930B 15.20 16 16.80 23.4 10.0 600 0.25 1 12.2 94 1SMB5931 931B 17.10 18 18.90 20.8 12.0 650 0.25 1 13.7 83 1SMB5932 932B 19.00 20 21.00 18.7 14.0 650 0.25 1 15.2 75 1SMB5933 933B 20.90 22 23.10 17.0 17.5 650 0.25 1 16.7 68 1SMB5934 934B 22.80 24 25.20 15.6 19 700 0.25 1 18.2 63 1SMB5935 935B 25.65 27 28.35 13.9 23 700 0.25 1 20.6 56 1SMB5936 936B 28.50 30 31.50 12.5 26 750 0.25 1 22.8 50 1SMB5937 937B 31.35 33 34.65 11.4 33 800 0.25 1 25.1 45 1SMB5938 938B 34.20 36 37.80 10.4 38 850 0.25 1 27.4 42 1SMB5939 939B 37.05 39 40.95 9.6 45 900 0.25 1 29.7 38 1SMB5940 940B 40.85 43 45.15 8.7 53 950 0.25 1 32.7 35 1SMB5941 941B 44.65 47 49.35 8.0 67 1000 0.25 1 35.8 32 1SMB5942 942B 48.45 51 53.55 7.3 70 1100 0.25 1 38.8 29 1SMB5943 943B 53.20 56 58.80 6.7 86 1300 0.25 1 42.6 27 1SMB5944 944B 58.90 62 65.10 6.0 100 1500 0.25 1 47.1 24 1SMB5945 945B 64.60 68 71.40 5.5 120 1700 0.25 1 51.7 22 1SMB5946 946B 71.25 75 78.75 5.0 140 2000 0.25 1 56.0 20 1SMB5947 947B 77.90 82 86.10 4.6 160 2500 0.25 1 62.2 18 1SMB5948 948B 86.45 91 95.55 4.1 200 3000 0.25 1 69.2 16 1SMB5949 949B 95.00 100 105.00 3.7 250 3100 0.25 1 76.0 15 1SMB5950 950B 104.50 110 115.50 3.4 300 4000 0.25 1 83.6 13 1SMB5951 951B 114.00 120 126.00 3.1 360 4500 0.25 1 91.2 12 1SMB5952 952B 123.50 130 136.50 2.9 450 5000 0.25 1 98.8 11 1SMB5953 953B 142.50 150 157.50 2.5 600 6000 0.25 1 114.0 10 1SMB5954 954B 152.00 160 168.00 2.3 700 6500 0.25 1 121.6 9 1SMB5955 955B 171.00 180 189.00 2.1 900 7000 0.25 1 136.8 8 1SMB5956 956B 190.00 200 210.00 1.9 1200 8000 0.25 1 152.0 7 Notes: 1. Tolerance and type number designation the type numbers listed indicate a tolerance of 5% 2. Zener voltage (Vz) measurement Nominal Zener voltage is measured with the device junction in thermal equilibrium with ambient temperature 25°C 3. Zener impedance (Zz) derivation : ZZT and ZZK are measured by dividing the AC voltage drop across the device by the AC current applied. The specified limits are for Iz(AC) = 0.1 Iz(DC) with the AC frequency = 60 Hz 2 Version: L1903 1SMB5926 - 1SMB5956 Taiwan Semiconductor ORDERING INFORMATION ORDERING CODE (Note 1,2) PACKAGE PACKING STATUS 1SMBxxxxHR5G SMB 850 / 7" Plastic reel Active 1SMBxxxxHR4G SMB 3,000 / 13" Paper reel NRND 1SMBxxxxHM4G SMB 3,000 / 13" Plastic reel Active 1SMBxxxx R5G SMB 850 / 7" Plastic reel Active 1SMBxxxx R4G SMB 3,000 / 13" Paper reel NRND 1SMBxxxx M4G SMB 3,000 / 13" Plastic reel Active Note 1: "xxxx" defines voltage from 11V (1SMB5926) to 200V (1SMB5956) Note 2: "H" means AEC-Q101 qualified 3 Version: L1903 1SMB5926 - 1SMB5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) PD, MAXIMUM POWER DISSIPATION (WATTS) Fig1. Steady State Power Derating Fig2. Maximum Surge Power 4 PPK, PEAK SURGE POWER (W) 1000 3 TL 2 1 TA 0 0 25 50 75 100 125 100 10 150 0 T, TEMPERATURE(℃) 3 4 5 OVZ, TEMPERATURE COEFFICIENT (mV/℃) OVZ, TEMPERATURE COEFFICIENT (mV/℃) 6 7 8 9 100 Fig4. Zener Voltage 14 To Voltages Vz@IZT 2 10 PW, PULSE WIDTH(ms) Fig3. Zener Voltage – To 12 Voltages 10 9 8 7 6 5 4 3 2 1 0 -1 -2 -3 -4 1 10 11 100 Vz@IZT 10 10 12 100 Vz, ZENER VOLTAGE (V) VZ, ZENER VOLTAGE(V) 4 Version: L1903 1SMB5926 - 1SMB5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig5. Vz = 3.3 thru 10 V Fig6. Vz = 12 thru 82 V IZ, ZENER CURRENT (mA) 100 10 1 0.1 10 1 0.1 0 1 2 3 4 5 6 7 8 Vz, ZENER VOLTAGE (V) 9 10 0 10 9 8 7 6 5 4 3 2 1 0 -1 -2 -3 -4 Vz@IZT 2 3 4 5 6 7 8 9 10 10 20 30 40 50 60 70 80 Vz, ZENER VOLTAGE (V) 90 100 Fig8. Effect Of Zener Current OVZ, TEMPERATURE COEFFICIENT (mV/℃) Fig7. Effect Of Zener Voltage OVZ, TEMPERATURE COEFFICIENT (mV/℃) IZ, ZENER CURRENT (mA) 100 11 12 100 Vz@IZT 10 10 VZ, ZENER VOLTAGE(V) 100 Vz, ZENER VOLTAGE (V) 5 Version: L1903 1SMB5926 - 1SMB5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig9. Capacitance Curve Fig10. Typical Pulse Rating Curve 10 1000 PPK, PEAK POWER (KW) C, CAPACITANCE(pF) MEASURED@ ZERO BIAS MEASURED @ Vz/2 100 10 NONREPETITIVE, EXPONENTIAL PULSE WAVEFORM 1 0.1 0.01 1 10 100 0.01 0.1 BREAKDOWN VOLTAGE (V) 1 10 Tp. PULSE WIDTH (ms) Fig11. Pulse Waveform Fig12. Pulse Waveform 120 Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM 120 110 IPPM, PEAK PULSE CURRENT (%) IPPM, PEAK PULSE CURRENT (%) 140 Rise time tr=10μs to 100% 100 Peak value IPPM 80 Half value-IPPM/2 60 40 10/1000μs, waveform 20 td 8/20 μs WAVEFORM AS DEFINED BY ANSI C62.1 AND IEC 801.5 100 90 0.9 IPEAK 80 70 60 0.5 IPEAK 50 40 30 t = 8μs 20 10 0 0.1 IPEAK 0 0 0.5 1 1.5 2 2.5 3 0 t, TIME (ms) 0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.1 T, TIME(ms) 6 Version: L1903 1SMB5926 - 1SMB5956 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AA (SMB) DIM. Unit (mm) Unit (inch) Min Max Min Max A 1.95 2.20 0.077 0.087 B 4.05 4.60 0.159 0.181 C 3.30 3.95 0.130 0.156 D 1.95 2.65 0.077 0.104 E 0.75 1.60 0.030 0.063 F 5.10 5.60 0.201 0.220 G 0.05 0.20 0.002 0.008 H 0.15 0.31 0.006 0.012 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 2.3 0.091 B 2.5 0.098 C 4.3 0.169 D 1.8 0.071 E 6.8 0.268 MARKING DIAGRAM P/N G YW F 7 = Marking Code = Green Compound = Date Code = Factory Code Version: L1903 1SMB5926 - 1SMB5956 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 8 Version: L1903
1SMB5935HM4G
物料型号:1SMB5926 - 1SMB5956,是3W,11V - 200V的表面安装硅齐纳二极管。
器件简介:这些齐纳二极管适用于自动化放置,具有玻璃钝化结、低电感,符合J-STD-020标准的1级湿度敏感度,并且有符合AEC-Q101标准的版本,订购时使用后缀“H”。
引脚分配:封装形式为DO-214AA (SMB),具体引脚分配未在文档中明确说明,但常见为阳极和阴极。
参数特性:包括测试电流、总功耗、最大结温、封装类型等。例如,总功耗Ptot为3.0W。
功能详解:文档提供了详细的电气规格和热性能参数,如结到引脚的热阻、结到环境的热阻。
应用信息:适用于开关电源(SMPS)、适配器、照明应用和板载DC/DC转换器。
封装信息:封装为DO-214AA (SMB),详细尺寸和建议的焊盘布局也在文档中给出。
1SMB5935HM4G 价格&库存
很抱歉,暂时无法提供与“1SMB5935HM4G”相匹配的价格&库存,您可以联系我们找货
