SS16LWHRVG
SS16LWHRVG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOD-123W(CFP3)
SS16LWHRVG 数据手册
SS14LWH – SS115LWH Taiwan Semiconductor 1A, 40V - 150V Schottky Barrier Surface Mount Rectifier FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS AEC-Q101 qualified Low power loss, high efficiency Ideal for automated placement Guard ring for overvoltage protection High surge current capability Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT IF 1 A VRRM 40 - 150 V IFSM 30 A TJ MAX 125, 150 °C Package SOD-123W Configuration Single die APPLICATIONS ● ● ● ● ● Low voltage, high freq. inverter DC/DC converter Freewheeling diodes Reverse battery protection Car lighting MECHANICAL DATA ● ● ● ● ● ● Case: SOD-123W Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.016g (approximately) SOD-123W ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Marking code on the device SS14LWH SS16LWH SS110LWH SS115LWH UNIT 14LW 16LW 10LW A5LW Repetitive peak reverse voltage VRRM 40 60 100 150 V Reverse voltage, total rms value VR(RMS) 28 42 70 105 V Forward current Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load Junction temperature IF 1 A IFSM 30 A TJ - 55 to +125 - 55 to +150 °C Storage temperature TSTG - 55 to +125 - 55 to +150 °C 1 Version: A2103 SS14LWH – SS115LWH Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 25 °C/W Junction-to-ambient thermal resistance RӨJA 80 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL SS14LWH Forward voltage SS16LWH (1) Reverse current @ rated VR SS110LWH (2) SS115LWH SS14LWH SS16LWH SS110LWH SS115LWH IF = 1A, TJ = 25°C TJ = 25°C VF TYP MAX UNIT - 0.55 V - 0.70 V - 0.80 V - 0.95 V - 100 µA - 10 µA IR Notes: 1. Pulse test with PW = 0.3ms 2. Pulse test with PW = 30ms ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SS1xLWH SOD-123W 10,000 / Tape & Reel Notes: 1. “x” defines voltage from 40V(SS14LWH) to 150V(SS115LWH) 2 Version: A2103 SS14LWH – SS115LWH Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Forward Current Derating Curve Fig.2 Typical Junction Capacitance 100 CAPACITANCE (pF) SS16LWH - SS115LWH 1 SS14LWH 10 f=1.0MHz Vsig=50mVp-p 1 0 25 50 75 100 125 0.1 150 1 LEAD TEMPERATURE (°C) INSTANTANEOUS FORWARD CURRENT (A) SS110LWH - SS115LWH 100 TJ=125°C 10 1 TJ=25°C 0.1 30 40 50 60 70 80 90 100 10 10 UF1DLW 1 TJ=125°C 1 0.1 TJ=25°C SS110LWH 0.01 Pulse width 300μs 1% duty cycle Pulse width 0.1 0.001 0.4 0.6 0.8 1.0 1.2 1.4 1.6 0.3 0.4 0.5 0.6 0.7 0.8 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 1.8 0.9 2.0 1 1.1 FORWARD VOLTAGE (V) Fig.5 Maximum Non-Repetitive Forward Surge Current 40 PEAK FORWARD SURGE CURRENT (A) INSTANTANEOUS REVERSE CURRENT (µA) Fig.4 Typical Forward Characteristics 1000 20 100 REVERSE VOLTAGE (V) Fig.3 Typical Reverse Characteristics 10 10 (A) AVERAGE FORWARD CURRENT (A) 2 8.3ms single half sine wave 30 20 10 0 1 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: A2103 1.2 SS14LWH – SS115LWH Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS SOD-123W SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code YW = Date Code F = Factory Code Version: A2103 SS14LWH – SS115LWH Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: A2103
SS16LWHRVG 价格&库存
很抱歉,暂时无法提供与“SS16LWHRVG”相匹配的价格&库存,您可以联系我们找货
SS16LWHRVG
  • 1+4.937201+0.64060
  • 10+3.0156410+0.39128
  • 100+1.91623100+0.24863
  • 500+1.43949500+0.18678
  • 1000+1.285431000+0.16679
库存:5046
SS16LWHRVG
  • 3000+1.089383000+0.14135
  • 6000+0.990536000+0.12852
  • 9000+0.940139000+0.12198
  • 15000+0.8835015000+0.11464
  • 21000+0.8499521000+0.11028
  • 30000+0.8173530000+0.10605
库存:5046
