TST20U100C
Taiwan Semiconductor
Dual High-Voltage Trench Schottky Rectifier
FEATURES
- Patented Trench Schottky technology
- Excellent high temperature stability
- Low forward voltage
- Low power loss/ high efficiency
- High forward surge capability
- Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21 definition
TO-220AB
TYPICAL APPLICATIONS
Trench Schottky barrier rectifier are designed for high frequency
miniature switched mode power supplies such as adapters, lighting
and on-board DC/DC converters.
MECHANICAL DATA
Case: TO-220AB
Molding compound meets UL 94 V-0 flammability rating
Packing code with suffix "G" means green compound (halogen-free)
Terminal: Matte tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 1A whisker test
Polarity: As marked
Mounting torque: 0.56 Nm max.
Weight: 1.88 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
Maximum repetitive peak reverse voltage
per device
Maximum average forward rectified
current
per diode
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load per diode
IF = 5A
Instantaneous forward voltage per diode
( Note1 )
IF = 10A
IF = 5A
IF = 10A
Instantaneous reverse current per diode at 100V
TJ = 25°C
TJ = 125°C
TJ = 25°C
TJ = 125°C
SYMBOL
TST20U100C
UNIT
VRRM
100
V
IF(AV)
IFSM
VF
VF
IR
A
10
150
A
Min.
TYP.
MAX.
0.56
0.65
0.79
0.49
0.58
0.68
500
μA
4
25
mA
V
Typical thermal resistance per diode
RθJC
2.5
°C/W
Operating junction temperature range
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
Storage temperature range
Note 1: Pulse Test with Pulse Width=300μs, 1% Duty Cycle
Document Number: DS_D1411062
Version: B14
TST20U100C
ORDERING INFORMATION
PART NO.
PACKING CODE
TST20U100C
C0
PACKING CODE
SUFFIX
G
PACKAGE
PACKING
TO-220AB
50 / Tube
EXAMPLE
PREFERRED
PART NO.
PACKING CODE
TST20U100C
C0
PART NO.
TST20U100C C0G
PACKING CODE
DESCRIPTION
SUFFIX
Green compound
G
RATINGS AND CHARACTERISTICS CURVES
FIG. 1 FORWARD CURRENT DERATING CURVE
FIG. 2 TYPICAL FORWARD CHARACTERISTICS
100
INSTANTANEOUS FORWARD CURRENT (A)
AVERAGE FORWARD CURRENT (A)
25
10
5
WITH HEATSINK
3in x 5in x 0.25in
Al-Plate
TJ=150°C
1
TJ=125°C
TJ=100°C
0.1
TJ=25°C
0.01
50
75
100
125
0.2
0.4
0.6
0.8
1
FORWARD VOLTAGE (V)
CASE TEMPERATURE (oC)
FIG. 3 TYPICAL REVERSE CHARACTERISTICS
FIG. 4 TYPICAL JUNCTION CAPACITANCE
10000
10
TJ=125°C
1
TJ=100°C
1000
0.1
CAPACITANCE (pF)
INSTANTANEOUS REVERSE CURRENT (mA)
TJ=150°C
0.01
TJ=25°C
100
0.001
f=1.0MHz
Vslg=50mVp-p
0.0001
10
40
50
60
70
80
90
PERCENT OF RATED PEAK REVERSE VOLTAGE.(%)
100
10
0.1
1
10
100
REVERSE VOLTAGE (V)
Version: B14
TST20U100C
PACKAGE OUTLINE DIMENSIONS
TO-220AB
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
10.50
0.413
B
2.62
3.44
0.103
0.135
C
2.80
4.20
0.110
0.165
D
0.68
0.94
0.027
0.037
E
3.54
4.00
0.139
0.157
F
14.60
16.00
0.575
0.630
G
13.19
14.79
0.519
0.582
H
I
2.41
4.42
2.67
4.76
0.095
0.174
0.105
0.187
J
1.14
1.40
0.045
0.055
K
5.84
6.86
0.230
0.270
L
2.20
2.80
0.087
0.110
M
0.35
0.64
0.014
0.025
MARKING DIAGRAM
P/N
= Specific Device Code
G
=Green Compound
YWW
= Date Code
F
= Factory Code
Version: B14
TST20U100C
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
Version: B14
很抱歉,暂时无法提供与“TST20U100C C0G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.49920
- 10+2.79720
- 50+2.44080
