SS110HR3G
SS110HR3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
SS110HR3G 数据手册
SS12 - SS115 Taiwan Semiconductor CREAT BY ART 1A, 20V - 150V Surface Mount Schottky Barrier Rectifiers FEATURES - Low power loss, high efficiency - Ideal for automated placement - Guardring for overvoltage protection - High surge current capability - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 definition DO-214AC (SMA) MECHANICAL DATA Case: DO-214AC (SMA) Molding compound, UL flammability classification rating 94V-0 Moisture sensitivity level: level 1, per J-STD-020 Part No. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.066 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL SS SS SS SS SS SS SS SS 12 13 14 15 16 19 110 115 UNIT Maximum repetitive peak reverse voltage VRRM 20 30 40 50 60 90 100 150 V Maximum RMS voltage VRMS 14 21 28 35 42 63 70 105 V Maximum DC blocking voltage VDC 20 30 40 50 60 90 100 150 V Maximum average forward rectified current IF(AV) 1 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 40 A Maximum instantaneous forward voltage (Note 1) @ 1 A, TJ=25°C @ 1 A, TJ=100°C VF 0.5 0.4 TJ=25°C Maximum reverse current @ rated VR TJ=100°C 0.75 0.65 0.8 0.7 TJ=125°C V 0.1 0.2 IR 0.95 0.85 6 5 - - - 2 mA Voltage rate of change (Rated VR) dV/dt 10000 V/μs Typical thermal resistance RθJL RθJA 28 88 °C/W Operating junction temperature range Storage temperature range TJ TSTG - 55 to +125 - 55 to +150 - 55 to +150 °C °C Note 1: Pulse test with PW=300μs, 1% duty cycle Document Number: DS_D1411020 Version: P15 SS12 - SS115 Taiwan Semiconductor ORDERING INFORMATION PART NO. PART NO. PACKING CODE SUFFIX H SS1xx (Note 1) PACKING CODE PACKAGE PACKING R3 SMA 1,800 / 7" Plastic reel R2 SMA 7,500 / 13" Paper reel M2 SMA 7,500 / 13" Plastic reel Folded SMA 1,800 / 7" Plastic reel SUFFIX F3 G F2 N/A Folded SMA 7,500 / 13" Paper reel F4 Folded SMA 7,500 / 13" Plastic reel E3 Clip SMA 1,800 / 7" Plastic reel E2 Clip SMA 7,500 / 13" Plastic reel Note 1: "xx" defines voltage from 20V (SS12) to 150V (SS115) EXAMPLE PREFERRED PART NO. PART NO. SS16HR3G PART NO. SUFFIX SS16 PACKING CODE PACKING CODE H DESCRIPTION SUFFIX R3 AEC-Q101 qualified Green compound G RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) FIG. 2 MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT AVERAGE FORWARD CURRENT(A) 1.2 1 0.8 SS15-SS115 SS12-SS14 0.6 0.4 0.2 RESISTIVE OR INDUCTIVE LOAD 0 50 60 70 80 90 100 110 120 130 140 150 160 170 PEAK FORWARD SURGE CURRENT (A) FIG.1 FORWARD CURRENT DERATING CUURVE 40 8.3ms Single Half Sine-Wave 30 20 10 0 1 10 NUMBER OF CYCLES AT 60 Hz LEAD TEMPERATURE (°C) FIG. 4 TYPICAL REVERSE CHARACTERISTICS FIG. 3 TYPICAL FORWARD CHARACTERISTICS 100 INSTANTANEOUS REVERSE CURRENT (mA) INSTANTANEOUS FORWARD CURRENT(A) 100 10 SS15-SS16 1 SS12-SS14 SS115 0.1 SS19-SS110 0.01 0 0.2 0.4 0.6 0.8 1 FORWARD VOLTAGE (V) Document Number: DS_D1411020 1.2 100 1.4 1.6 SS12-SS14 SS15-SS115 10 TJ=125°C 1 0.1 TJ=75°C 0.01 TJ=25°C 0.001 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE.(%) Version: P15 SS12 - SS115 Taiwan Semiconductor FIG. 5 TYPICAL JUNCTION CAPACITANCE FIG. 6 TYPICAL TRANSIENT THERMAL IMPEDANCE 1000 100 TRANSIENT THERMAL IMPEDANCE (°C/W) CAPACITANCE (pF) SS12-SS14 SS15-SS16 SS19-SS115 100 f=1.0MHz Vslg=50mVp-p 10 0.1 1 10 10 1 0.1 100 0.01 REVERSE VOLTAGE (V) 0.1 1 10 100 T-PULSE DURATION(s) PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) Unit (mm) DIM. Unit (inch) Min Max Min Max A 1.27 1.58 0.050 0.062 B 4.06 4.60 0.160 0.181 C 2.29 2.83 0.090 0.111 D 1.99 2.50 0.078 0.098 E 0.90 1.41 0.035 0.056 F 4.95 5.33 0.195 0.210 G 0.10 0.20 0.004 0.008 H 0.15 0.31 0.006 0.012 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 1.68 0.066 B 1.52 0.060 C 3.93 0.155 D 2.41 0.095 E 5.45 0.215 MARKING DIAGRAM P/N = Specific Device Code G= Green Compound YW = Date Code F= Factory Code Document Number: DS_D1411020 Version: P15 SS12 - SS115 Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_D1411020 Version: P15
SS110HR3G 价格&库存
很抱歉,暂时无法提供与“SS110HR3G”相匹配的价格&库存,您可以联系我们找货
