SS12L - SS115L
Taiwan Semiconductor
CREAT BY ART
1A, 20 - 150V Surface Mount Schottky Barrier Rectifiers
FEATURES
- Low power loss, high efficiency
- Ideal for automated placement
- Guardring for overvoltage protection
- High surge current capability
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21 definition
MECHANICAL DATA
Case: Sub SMA
Sub SMA
Molding compound, UL flammability classification rating 94V-0
Moisture sensitivity level: level 1, per J-STD-020
Part no. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound (halogen-free)
Terminal: Matte tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.019 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
Marking code
SS
SS
SS
SS
SS
SS
12L
13L
14L
15L
16L
19L
SS
SS
110L 115L
UNIT
12L
13L
14L
15L
16L
19L
10L
A5L
Maximum repetitive peak reverse voltage
VRRM
40
50
60
90
100
150
V
Maximum RMS voltage
VRMS
14
21
28
35
42
63
70
105
V
Maximum DC blocking voltage
VDC
40
50
60
90
100
150
V
Maximum average forward rectified current
IF(AV)
1
A
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
IFSM
30
A
Maximum instantaneous forward voltage (Note 1)
@ 0.5A
@ 1.0A
VF
0.385
0.45
0.43
0.50
0.51
0.55
TJ=25°C
Maximum reverse current @ rated VR
TJ=100°C
0.58
0.70
0.70
0.80
0.4
IR
TJ=125°C
V
0.05
6.0
8.0
0.75
0.90
mA
0.5
Voltage rate of change (Rated VR)
dV/dt
10000
V/μs
Typical thermal resistance
RθJL
RθJA
45
100
°C/W
Operating junction temperature range
Storage temperature range
TJ
TSTG
- 55 to +125
- 55 to +150
- 55 to +150
°C
°C
Note 1: Pulse test with PW=300μs, 1% duty cycle
Document Number: DS_D1409052
Version: P15
SS12L - SS115L
ORDERING INFORMATION
PART NO.
PART NO.
PACKING
PACKING CODE
SUFFIX
CODE
RU
RV
RT
MT
RQ
MQ
R3
RF
R2
M2
SUFFIX
SS1XL
(Note 1)
H
PACKAGE
PACKING
Sub SMA
Sub SMA
Sub SMA
Sub SMA
Sub SMA
Sub SMA
Sub SMA
Sub SMA
Sub SMA
Sub SMA
1,800 / 7" Plastic reel (8mm tape)
3,000 / 7" Plastic reel (8mm tape)
7,500 / 13" Paper reel (8mm tape)
7,500 / 13" Plastic reel (8mm tape)
10,000 / 13" Paper reel (8mm tape)
10,000 / 13" Plastic reel (8mm tape)
1,800 / 7" Plastic reel (12mm tape)
3,000 / 7" Plastic reel (12mm tape)
7,500 / 13" Paper reel (12mm tape)
7,500 / 13" Plastic reel (12mm tape)
RH
Sub SMA
10,000 / 13" Paper reel (12mm tape)
MH
Sub SMA
10,000 / 13" Plastic reel (12mm tape)
G
Note 1: "x" defines voltage from 20V (SS12L) to 150V (SS115L)
EXAMPLE
PREFERRED
PART NO.
PART NO.
PART NO.
SS16LHRUG
SUFFIX
SS16L
PACKING CODE
PACKING CODE
H
DESCRIPTION
SUFFIX
RU
AEC-Q101 qualified
Green compound
G
RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted)
FIG.1 FORWARD CURRENT DERATING CURVE
SS15L-SS115L
1
0.8
0.6
SS12L-SS14L
0.4
0.2
50
75
100
LEAD TEMPERATURE
150
10
1
SS19L-SS110L
0.1
0.6
0.8
1
1.2
FORWARD VOLTAGE (V)
10
100
10000
SS115L
0.4
30
FIG. 4 TYPICAL REVERSE CHARACTERISTICS
SS12L
0.2
8.3ms Single Half
Sine-Wave
NUMBER OF CYCLES AT 60 Hz
SS15L-SS16L
SS13L-SS14L
40
(oC)
FIG. 3 TYPICAL FORWARD CHARACTERISTICS
100
INSTANTANEOUS FORWARD CURRENT
(A)
125
INTANTANEOUS REVERSE CURRENT. (uA)
AVERAGE FORWARD CURRENT (A)
1.2
PEAK FORWARD SURGE CURRENT (A)
FIG. 2 MAXUMUM FORWARD SURGE CURRENT
1.4
1.6
1.8
TJ=100oC
1000
100
TJ=75oC
10
1
TJ=25oC
0.1
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE.(%)
Version: P15
SS12L - SS115L
FIG. 5 TYPICAL JUNCTION CAPACITANCE
FIG. 6 TYPICAL TRANSIENT THERMAL IMPEDANCE
100
100
10
TRANSIENT THERMAL
IMPEDANCE (°C/W)
JUNCTION CAPACITANCE (pF)
1000
f=1.0MHz
Vslg=50mVp-p
1
10
1
0.1
0.1
1
10
100
0.01
0.1
1
10
100
T-PULSE DURATION(s)
REVERSE VOLTAGE (V)
PACKAGE OUTLINE DIMENSIONS
Sub SMA
Unit (mm)
DIM.
Unit (inch)
Min
Max
Min
Max
B
1.70
1.90
0.067
0.075
C
2.70
2.90
0.106
0.114
D
0.16
0.30
0.006
0.012
E
1.23
1.43
0.048
0.056
F
0.80
1.20
0.031
0.047
G
3.40
3.80
0.134
0.150
H
2.45
2.60
0.096
0.102
I
0.35
0.85
0.014
0.033
J
0.00
0.10
0.000
0.004
SUGGESTED PAD LAYOUT
Symbol
Unit (mm)
Unit (inch)
A
1.4
0.055
B
1.2
0.047
C
3.1
0.122
D
1.9
0.075
E
4.3
0.169
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: P15
SS12L - SS115L
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: P15
很抱歉,暂时无法提供与“SS14L RFG”相匹配的价格&库存,您可以联系我们找货
