SFAS801G - SFAS808G
Taiwan Semiconductor
CREAT BY ART
8A, 50V - 600V Surface Mount Super Fast Rectifiers
FEATURES
- Glass passivated junction chip
- Ideal for automated placement
- High efficiency, low VF
- High surge current capability
- Low power loss
- Compliant to RoHS Directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
- Halogen-free according to IEC 61249-2-21
2
TO-263AB (D PAK)
MECHANICAL DATA
Case: TO-263AB (D2PAK)
Molding compound, UL flammability classification rating 94V-0
Moisture sensitivity level: level 1, per J-STD-020
Part no. with suffix "H" means AEC-Q101 qualified
Packing code with suffix "G" means green compound (halogen-free)
Terminal: Matte tin plated leads, solderable per JESD22-B102
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 1.33 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted)
PARAMETER
SYMBOL
SFAS SFAS SFAS SFAS SFAS SFAS SFAS SFAS
801G 802G 803G 804G 805G 806G 807G 808G
UNIT
Maximum repetitive peak reverse voltage
VRRM
50
100
150
200
300
400
500
600
V
Maximum RMS voltage
VRMS
35
70
105
140
210
280
350
420
V
Maximum DC blocking voltage
VDC
50
100
150
200
300
400
500
600
V
Maximum average forward rectified current
IF(AV)
8
A
Peak forward surge current, 8.3 ms single half sine-wave
superimposed on rated load
IFSM
125
A
Maximum instantaneous forward voltage
IF= 8 A
Maximum reverse current @ rated VR
VF
TJ=25°C
TJ=100°C
trr
Typical junction capacitance (Note 2)
CJ
Operating junction temperature range
Storage temperature range
1.3
1.7
10
IR
Maximum reverse recovery time (Note 1)
Typical thermal resistance
0.95
μA
400
35
80
V
ns
60
pF
RθJC
2.2
°C/W
TJ
- 55 to +150
°C
TSTG
- 55 to +150
°C
Note 1: Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
Note 2: Measured at 1 MHz and Applied Reverse Voltage of 4.0V D.C.
Document Number: DS_D1405074
Version: M15
SFAS801G - SFAS808G
ORDERING INFORMATION
PART NO.
PART NO.
PACKING CODE
PACKING CODE
SUFFIX
SFAS80xG
(Note 1)
SUFFIX
RN
H
PACKAGE
800 / 13" Paper reel
D2PAK
G
MN
PACKING
800 / 13" Plastic reel
Note 1: "x" defines voltage from 50V (SFAS801G) to 600V (SFAS808G)
*: Optional available
EXAMPLE
PREFERRED P/N
PART NO.
SFAS801GHRNG
SFAS801G
PART NO.
PACKING CODE
PACKING CODE
SUFFIX
H
DESCRIPTION
SUFFIX
RN
AEC-Q101 qualified
Green compound
G
RATINGS AND CHARACTERISTICS CURVES
(TA=25℃ unless otherwise noted)
FIG. 2 TYPICAL REVERSE CHARACTERISTICS
FIG.1 FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD A
CURRENT (A)
8
6
4
RESISTIVE OR
INDUCTIVELOAD
WITH HEATSINK
2
50
75
100
125
150
INSTANTANEOUS REVERSE CURRENT
(μA)
1000
10
100
10
1
60
30
INSTANTANEOUS FORWARD CURRENT (A)
PEAK FORWARD SURGE CURRENT (A)
8.3ms Single Half Sine Wave
NUMBER OF CYCLES AT 60 Hz
40
60
80
100
120
140
FIG. 5 TYPICAL FORWARD CHARACTERISTICS
150
10
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FIG. 3 MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
1
TJ=25°C
0.1
CASE TEMPERATURE (oC)
120
TJ=100°C
100
SFAS801G-SFAS804G
10
SFAS805G-SFAS806G
1
SFAS807G-SFAS808G
Pulse Width=300μs
1% Duty Cycle
0.1
0.4
0.6
0.8
1
1.2
1.4
1.6
1.8
FORWARD VOLTAGE (V)
Version: M15
SFAS801G - SFAS808G
FIG. 5 TYPICAL JUNCTION CAPACITANCE
100
f=1.0MHz
Vsig=50mVp-p
CAPACITANCE (pF)
90
80
70
60
SFAS801G-SFAS804G
50
SFAS805G-SFAS808G
40
1
10
100
1000
REVERSE VOLTAGE (V)
PACKAGE OUTLINE DIMENSIONS
TO-263AB (D2PAK)
DIM.
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
10.5
0.413
B
14.60
15.88
0.575
0.625
C
2.41
2.67
0.095
0.105
D
0.68
0.94
0.027
0.037
E
2.29
2.79
0.090
0.110
F
4.44
4.70
0.175
0.185
G
1.14
1.40
0.045
0.055
H
1.14
1.40
0.045
0.055
I
8.25
9.25
0.325
0.364
J
0.36
0.53
0.014
0.021
K
2.03
2.79
0.080
0.110
SUGGESTED PAD LAYOUT
Symbol
Unit (mm)
Unit (inch)
A
10.8
0.425
B
8.3
0.327
C
1.1
0.043
D
3.5
0.138
E
16.9
0.665
F
9.5
0.374
G
2.5
0.098
MARKING DIAGRAM
P/N
= Specific Device Code
G
= Green Compound
YWW
= Date Code
F
= Factory Code
Version: M15
SFAS801G - SFAS808G
CREAT BY ART
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: M15
很抱歉,暂时无法提供与“SFAS805GHMNG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.08240
- 10+3.32640
- 30+2.93760
