MMBD4148/CA/CC/SE
Taiwan Semiconductor
200mA, SMD Switching Diode
FEATURES
KEY PARAMETERS
Designed for mounting on small surface
Low Capacitance
Low forward voltage drop
Moisture sensitivity level: level 1, per J-STD-020
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
IF
200
mA
VRRM
100
V
IFSM
2
A
VF at IF=10mA
1
V
TJ Max.
150
°C
Package
SOT-23
APPLICATIONS
Switching mode power supply (SMPS)
Adapters
Lighting application
On-board DC/DC converter
MECHANICAL DATA
Case: SOT-23
Molding compound meets UL 94 V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 1A whisker test
Weight: 8 mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Marking code on the device
SYMBOL
VALUE
MMBD4148
5D
MMBD4148CA
A1
MMBD4148CC
A4
MMBD4148SE
A7
Repetitive peak reverse voltage
VRRM
Forward current
Repetitive peak forward surge current
IF
IFRM
Non-repetitive peak forward surge current
at t=1μs
at t=1s
IFSM
UNIT
100
200
700
2
1
V
mA
mA
A
Junction temperature range
TJ
-55 to +150
°C
Storage temperature range
TSTG
-55 to +150
°C
1
Version: D1903
MMBD4148/CA/CC/SE
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
SYMBOL
TYP
UNIT
RӨJA
357
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage per diode
CONDITIONS
(1)
IF= 10mA, TJ = 25°C
Reverse current @ rated VR per
diode
(2)
SYMBOL
MIN
MAX
UNIT
VF
1.0
V
25.0
nA
5.0
50.0
75
100
CJ
4.0
pF
trr
4.0
ns
VR= 20V ,TJ = 25°C
VR= 75V ,TJ = 25°C
IR
VR= 20V ,TA = 150°C
IR= 5μA ,TJ = 25°C
Reverse breakdown voltage
V(BR)
IR= 100μA ,TJ = 25°C
1 MHz, VR=0V
Junction capacitance
IF=10mA,IR=1mA,
Reverse recovery time
RL=100ῼ, VR=6V
μA
V
Notes:
1. Pulse test with PW=0.3 ms
2. Pulse test with PW=30 ms
ORDERING INFORMATION
ORDERING CODE
(Note 1)
PACKAGE
PACKING
MMBD414xx RFG
SOT-23
3K / 7" Reel
MMBD414xx R5G
SOT-23
10K / 13" Reel
Note:
1. "xx" defines part no. from "8" to "8SE”
2
Version: D1903
MMBD4148/CA/CC/SE
CHARACTERISTICS CURVES
Fig. 1 Power Derating Curve
Fig.2 Forward Characteristics
1
IF, Instantaneous Forward Current (A)
PD, Power Dissipation (mW)
500
400
300
200
100
TA=150oC
TA=75oC
TA=25oC
TA=0oC
TA= -40oC
0.1
0.01
0.001
200
TA - Ambient Temperature (oC)
Fig.3 Typical Reverse Characteristics
1.5
Fig.4 Typical Capacitance vs. Reverse Voltage
2.0
10000
TA=125oC
1000
TA=150oC
CT, Total Capacitance (pF)
IR, Instantaneous Reverse Current (nA)
0.5
1
VF, Instantaneous Forward Voltage (V)
TA=75oC
100
TA=25oC
10
TA=0oC
1
1.6
f=1.0MHz
1.2
0.8
0.4
TA=-40oC
0.1
0.0
60
80
100
40
VR, Reverse Voltage (V)
VR, Instantaneous Reverse Voltage (V)
3
Version: D1903
MMBD4148/CA/CC/SE
PACKAGE OUTLINE DIMENSION
SOT-23
SUGGEST PAD LAYOUT
PIN CONFIGURATION
4
Version: D1903
MMBD4148/CA/CC/SE
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: D1903
很抱歉,暂时无法提供与“MMBD4148CC RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+0.123931+0.01554
- 15+0.1133015+0.01421
- 75+0.1071175+0.01344
- 300+0.10268300+0.01288
- 1500+0.095601500+0.01199
- 国内价格 香港价格
- 3000+0.304823000+0.03823
- 6000+0.271596000+0.03406
- 9000+0.254639000+0.03193
- 15000+0.2355315000+0.02954
- 21000+0.2242321000+0.02812
- 30000+0.2132230000+0.02674
- 75000+0.1890575000+0.02371
- 150000+0.17411150000+0.02184
- 300000+0.16154300000+0.02026
- 国内价格 香港价格
- 1+1.577761+0.19786
- 10+0.9371310+0.11752
- 100+0.58060100+0.07281
- 500+0.42206500+0.05293
- 1000+0.370581000+0.04647
- 国内价格 香港价格
- 3000+0.117733000+0.01477
- 12000+0.1141912000+0.01432
- 45000+0.1115345000+0.01399
- 75000+0.1106575000+0.01388
- 150000+0.10622150000+0.01332
- 国内价格
- 20+0.20920
- 200+0.16449
- 600+0.13954
