S9013
S9013
    YONGYUTAI(永裕泰)
    SOT-23
    SOT-23 25V 0.5A
S9013 数据手册
S9013 SOT-23 Plastic-Encapsulate Transistors S9013 TRANSISTOR (NPN) FEATURES Complimentary to S9012 Collector current:Ic=0.5A MARKING:J3 MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Parameter Value Units (符号) (参数名称) (额定值) (单位) VCBO Collector-Base Voltage (集电极-基极电压) 40 V VCEO Collector-Emitter Voltage (集电极-发射极电压) 25 V VEBO Emitter-Base Voltage (发射极-基极电压) 5 V IC Collector Current -Continuous (集电极电流) 0.5 A PC Collector Power Dissipation (耗散功率) 0.3 W Tj Junction Temperature (结温) 150 ℃ Tstg Storage Temperature (储存温度) -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃unless otherwise specified) Parameter (参数名称) Symbol (符号) Test conditions (测试条件) MIN TYP MAX (最小值) (典型值) (最大值) UNIT (单位) Collector-base breakdown voltage 集电极-基极击穿电压 V(BR)CBO IC= 100μA, IE=0 40 V Collector-emitter breakdown voltage 集电极-发射极击穿电压 V(BR)CEO IC= 1mA, IB=0 25 V Emitter-base breakdown voltage 发射极-基极击穿电压 V(BR)EBO IE=100μA, IC=0 5 V Collector cut-off current 集电极-基极截止电流 ICBO VCB=30 V , IE=0 1 μA Collector cut-off current 集电极-发射极截止电流 ICEO VCE=25V , 10 μA Emitter cut-off current 发射极-基极截止电流 IEBO VEB=5V , IC=0 1 μA DC current gain 直流电流增益 hFE VCE=1V, IC= 50mA Collector-emitter saturation voltage 集电极-发射极饱和压降 VCE(sat) IC=500mA, IB= 50mA 0.5 V Base-emitter saturation voltage 发射极-基极饱和压降 VBE(sat) IC=500mA, IB= 50mA 1.2 V CLASSIFICATION OF Range www.yongyutai.com 80-100 IB=0 80 400 hFE 100-200 200-400 400-600 PAGE 1 S9013 Typical Characteristics www.yongyutai.com PAGE 2
S9013 价格&库存
很抱歉,暂时无法提供与“S9013”相匹配的价格&库存,您可以联系我们找货
S9013
  • 1+0.17270
  • 200+0.05764
  • 1500+0.03608
  • 3000+0.02860
库存:20408
S9013
    • 5+0.05070
    • 50+0.04110
    • 150+0.03460
    • 500+0.03110
    • 3000+0.02830
    • 6000+0.02660
    库存:153661
    S9013
    • 50+0.06515
    • 500+0.05233
    • 3000+0.04278
    • 6000+0.03847
    • 24000+0.03478
    • 51000+0.03273
    库存:114552
    S9013
      • 10+0.04800
      • 50+0.04440
      • 200+0.04140
      • 600+0.03840
      • 1500+0.03600
      • 3000+0.03450
      库存:410
      S9013
        库存:153661
