Through-hole resistors
Metal Oxide Film Resistors
Flame-Proof Type
Normal & Miniature Style [ RSF Series ]
FEATURES
Power Rating
1/4W, 1/2W, 1W, 2W, 3W, 5W
Resistance Tolerance
±2%, ±5%
T.C.R.
±300ppm/°C
Flameproof Multi-layer Coating Meets
UL-94V-0
Flameproof Feature Meets Overload Test
UL-1412
INTRODUCTION
The RSF Series Metal Oxide Film Flame-Proof
Resistors offer excellent performance in
applications where stability and uniformity of
characteristics are desired. They provide lower
cost alternatives to Carbon Composition
Resistors and General Purpose Metal Films.
Metal Oxides also can replace many low power
General Purpose wirewound applications, saving
both money and time, with shorter delivery
cycles. The normal style & ‘RSF-WV’ style of
RSF series are coated with layers of gray flameproof lacquer, and the miniature style except
‘RSF-WV’ style are coated with layers of pink
colors flame-proof lacquer.
DERATING CURVE
For resistors operated in ambient temperatures above 70°C, power rating must be derated
in accordance with the curve below.
70
Rated Load (%)
155
235°C
100
80
60
40
100 150 200 250
Ambient Temperature (°C)
DIMENSIONS
Unit: mm
STYLE
ød
H
L
øD
Note: RSF1WS (for MB Type) ød = 0.8±0.05mm
RSF3WV, RSF4WV: Marking Printed
DIMENSION
Normal
Miniature
L
øD
H
ød
RSF-25
RSF50S / RSF1WV
6.3±0.5
2.4±0.2
28±2.0
0.55±0.05
RSF-50
RSF1WS
9.0±0.5
3.3±0.3
26±2.0
0.55±0.05
RSF100
RSF2WS / RSF2WV 11.5±1.0
4.5±0.5
35±2.0
0.8±0.05
RSF200
RSF3WS
15.5±1.0
5.0±0.5
33±2.0
0.8±0.05
RSF3WV
16.5+0/-1.5
6.0+0/-0.5
33±2.0
0.8±0.05
RSF3WM
RSF5SS
17.5±1.0
6.5±1.0
32±2.0
0.8±0.05
RSF4WV
20+0/-1
9.0+0/-0.5
31±2.0
0.8±0.05
RSF300
RSF5WS
24.5±1.0
8.5±1.0
38±2.0
0.8±0.05
RSF500
24.5±1.0
8.5±1.0
38±2.0
0.8±0.05
21
ELECTRICAL CHARACTERISTICS
Normal STYLE
STYLE
RSF-25
RSF-50
RSF100
RSF200
RSF3WM
RSF300
RSF500
Power Rating at 70°C
1/4W
1/2W
1W
2W
3W
Maximum Working Voltage
200V
250V
350V
450V
500V
750V
Maximum Overload Voltage
300V
400V
600V
700V
800V
1,000V
Voltage Proof on Insulation
250V
350V
500V
Resistance Range
1Ω - 1MΩ & 0Ω for E24 series value
Operating Temp. Range
-55°C to +235°C
Temperature Coefficient
±300ppm/°C
5W
MINIATURE STYLE
STYLE
RSF50S
RSF1WV RSF1WS RSF2WS RSF2WV RSF3WS RSF3WV RSF5SS
RSF4WV RSF5WS
1/2W
1W
5W
4W
5W
250V
500V
750V
500V
750V
700V
400V
500V
750V
800V
350V
500V
Resistance Range
-55°C to +235°C
±300ppm/°C
2W
300V
350V
3W
500V
350V
600V
400V
900V
500V
Note: Special value is available on request
ENVIRONMENTAL CHARACTERISTICS
PERFORMANCE TEST
TEST METHOD
APPRAISE
Short Time Overload
IEC 60115-1 4.13
2.5 times RCWV for 5 Sec.
±1.0%+0.05Ω for normal style
±2.0%+0.05Ω for miniature style
IEC 60115-1 4.7
in V-block for 60 Sec., test voltage by type
By type
IEC 60115-1 4.8
-55°C to +155°C
By type
Insulation Resistance
IEC 60115-1 4.6
>1,000MΩ
Solderability
IEC 60115-1 4.17
235±5°C for 3±0.5 Sec.
95% Min. coverage
Solvent Resistance of Marking
IEC 60115-1 4.30
IPA for 5±0.5 Min. with ultrasonic
No deterioration of coatings and
markings
Robustness of Terminations
IEC 60115-1 4.16
Direct load for 10 Sec. in the direction of the terminal leads
≥2.5kg (24.5N)
Periodic-pulse Overload
IEC 60115-1 4.39
4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off)
±2.0%+0.05Ω
Damp Heat Steady State
IEC 60115-1 4.24
40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV
±5.0%+0.05Ω
Endurance at 70°C
IEC 60115-1 4.25
70±2°C at RCWV for 1,000 Hr. (1.5 Hr. on, 0.5 Hr. off)
±5.0%+0.05Ω
Temperature Cycling
IEC 60115-1 4.19
-55°C Room Temp. +155°C Room Temp. (5 cycles)
±1.0%+0.05Ω
Resistance to Soldering Heat
IEC 60115-1 4.18
260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the
body
±1.0%+0.05Ω
Accidental Overload Test
IEC 60115-1 4.26
4 times RCWV for 1 Min.
No evidence of flaming or arcing
Note: Rated Continuous Working Voltage (RCWV) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less.
Revision: 201304
88
Explanations Of Ordering Code
MFR
-12
F
Code 7
Tolerance
T
F
Code 8
Packing Style
Code 9
Temperature Coefficient of Resistance
Code 1 - 3
Series Name
Code 4 - 6
Power Rating
See Index
-05 = ød0.5mm
P = ±0.02 %
T = Tape/Box
-06 = ød0.6mm
A = ±0.05 %
R = Tape/Reel
- = Base on Spec.
-07 = ød0.7mm
B = ±0.1 %
B = Bulk
52-
100R
Code 10 - 12
Forming Type
Code 13 - 17
Resistance Value
26- = 26mm
0R1 = 0.1
52- = 52.4mm
100R = 100
A = ±5 ppm/°C
73- = 73mm
10K = 10,000
81- = 81mm
10M = 10,000,000
-08 = ød0.8mm
C = ±0.25%
B = ±10 ppm/°C
-10 = ød1.0mm
D = ±0.5 %
C = ±15 ppm/°C
91- = 91mm
-14 = ød1.4mm
F = ±1 %
S = ± 20ppm/°C
F = F Type
-12 = 1/6W
G = ±2 %
D = ±25 ppm/°C
FK = FK Type
-25 = 1/4W
J = ±5 %
E = ±50 ppm/°C
FKK = FKK Type
25S = 1/4WS
K = ±10 %
F = ±100 ppm/°C
FFK = F-form Kink
-50 = 1/2W
- = Base on Spec.
G = ±200 ppm/°C
M = M-Type Forming
50S = 1/2WS
H = ±250 ppm/°C
MB = M-form W/flat
100 = 1W
I = ±300 ppm/°C
MT = MT Type Forming
1WS = 1WS
J = ±350 ppm/°C
MR = MR Type
200 = 2W
AV = AVIsert
2WS = 2WS
PN = PANAsert
204 = 0.4W
207 = 0.6W
300 = 3W
3WS = 3WS
3WM = 3WM
400 = 4W
500 = 5W
5WS = 5WS
5SS = 5WSS
700 = 7W
7WS = 7WS
10A = 10W
20A = 20W
30A = 30W
40A = 40W
50A = 50W
10S = 10WS
15A = 15W
25A = 25W
10B = 100W
25B = 250W
EXCEPTION:
• Cement series:
• JPW series:
: Special packing style code
B: B
ulk with wirewound or metal oxide sub-assembly for resistance value
W: Bulk with ceramic based wirewound sub-assembly for resistance value
M: Bulk with metal oxide sub-assembly for resistance value
F: Bulk with Fiberglass based wirewound sub-assembly for resistance value
: Without forming code
Example:
SQP500JB-10R
: without resistance value code
Example:
JPW-06-T-52-
很抱歉,暂时无法提供与“RSF2WSJT-73-15R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.34960
- 200+0.23310
- 1000+0.19420
- 国内价格 香港价格
- 1+1.762301+0.22613
- 10+1.1481710+0.14733
- 25+0.9646825+0.12378
- 50+0.8514650+0.10926
- 100+0.75427100+0.09678
- 250+0.64725250+0.08305
- 500+0.58030500+0.07446
- 国内价格
- 20+0.22173
- 200+0.17496
- 1000+0.14656
- 国内价格 香港价格
- 1000+0.513261000+0.06586
- 2000+0.465832000+0.05977
- 3000+0.441453000+0.05665
- 5000+0.413865000+0.05311
- 7000+0.397427000+0.05100
- 10000+0.3813510000+0.04894
- 国内价格
- 50+0.11943
- 500+0.10716
- 5000+0.09898
- 10000+0.09489
- 30000+0.09080
- 50000+0.08835
