B0520W THRU B0540W
Reverse Voltage 20-40 Volts
Forward Current - 0.5 Ampere
SCHOTTKY DIODES
Features
SOD-123
Low forward voltage drop
Guard ring construction for transient protection
High conductance
Also available in lead free version
0.028(0.70)
0.071(1.80)
0.018(0.45)
0.055(1.40)
0.008(0.20)max.
Cathode bar
0.110(2.80)
0.098(2.50)
0.154 (3.90)
Absolute Maximum Ratings at 25 °C
0.006 (0.15)
0.026 (0.65)
0.014 (0.35)
Dimensions in inches and (millimeters)
Symbols
B0520W
B0530W
B0540W
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
14
21
28
V
Parameter
Average rectified output current
Voltage rate of change
at 8.3ms
Non-reptitive Peak Forward Surge Current
Power dissipation
Typical Thermal Resistance
(1)
Operating and Storage Temperature Range
0.0019 (0.05)
0.0087 (0.22)
0.018 (0.45)
9°
0.008 (0.2 )
Case: JEDEC SOD-123 molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.00056 ounce, 0.016 grams
Marking: B0520W:SD, B0530W:SE, B0540W:SF
0° to
0.049 (1.25)
Mechanical Data
0.037(0.95)
0.138 (3.50)
I0
0.5
A
dv/dt
1000
v/us
I FSM
15
A
Pd
410
mW
RθJA
200
°C/W
T j , T stg
-55 ~ +150
°C
(1)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
Characteristics at Ta= 25 °C
Symbols
Parameter
Reverse BreakdownVoltage at IR
at 250uA
at 130uA
B0520W
B0530W
at 0.1A
at 0.5A
at 1A
VF
Peak Reverse Current at VR
at 20V
at 30V
0.330
0.390
75
at 10V
at 15V
Units
V
30
V(BR)R
at 20uA
Maximum Forward Voltage at If
B0540W
IR
250
at40V
0.375
0.430
0.510
0.620
130
V
uA
Typical Junction Capacitance
Cj
170
pF
Reverse recovery time IF=IR=10mAIrr=0.1XIR,RL=100Ω
trr
4
ns
http://www.microdiode.com
Rev:2025A4
Page :1
B0520W THRU B0540W
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
0.6
10
4
10
3
10
2
0.4
0.3
0.2
0.1
0.0
25
75
50
100
125
150
)A)
Instaneous Reverse Current (μA
Average Forward Current (A)
0.5
TJ=100°C
TJ=75°C
TJ=25°C
101
10
Case Temperature (°C)
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 TYPICAL FORWARD VOLTAGE
Fig.4 Typical Junction Capacitance
70
Junction Capacitance (pF)
INSTANTANEOUS FORWARD CURRENT AMPERS
100
1.0
TA=100℃
0.1
TA=25℃
0.01
0.2
0.3
0.4
30
0.5
1
0.1
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
100
10
Reverse Voltage (V)
Fig.6 Typical Transient Thermal Impedance
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
2000
15.0
12.5
10.0
7.5
5.0
2.5
00
1
10
Number of Cycles at 50Hz
100
Transient Thermal Impedance(°C/W)
8.3 ms Single Half Sine Wave (JEDEC
Method)
Peak Forward Surage Current (A)
40
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2025A4
Page :2
B0520W THRU B0540W
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-123
E
F
B
A
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123
7"
3,000
4.0
45,000
190*190*190
178
400*400*220
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
3.2
0.126
D
2.0
0.079
E
4.4
0.173
0.047
Important Notice and Disclaimer
Microdiode Semiconductor(Shenzhen) reserves the right to make changes to this document and its products and specifications at
any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,
purchase or use.
Microdiode Semiconductor(Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for
any particular purpose, not does Microdiode Semiconductor(Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Semiconductor(Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Semiconductor(Shenzhen).
Microdiode Semiconductor(Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Semiconductor(Shenzhen).
Rev:2025A4
Page :3
很抱歉,暂时无法提供与“B0530W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.10801
- 100+0.10081
- 300+0.09361
- 500+0.08640
- 2000+0.08280
- 5000+0.08064
- 国内价格
- 20+0.23858
- 200+0.19548
- 600+0.17151
- 3000+0.15304
- 9000+0.14062
- 21000+0.13382
