山东晶导微电子股份有限公司
SSL345F
Jingdao Microelectronics co.LTD
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 45V
Forward Current - 3.0A
PINNING
PIN
Features
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: S345F
Simplified outline SMAF and symbol
MECHANICAL DATA
• Case: SMAF
• Terminals: Solderable per MIL-STD-750, Method 2026
• Approx. Weight: 27mg / 0.00095oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
SSL345F
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
45
V
Maximum RMS voltage
V RMS
32
V
Maximum DC Blocking Voltage
V DC
45
V
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
80
A
Maximum Instantaneous Forward Voltage at 3 A
VF
0.45
V
IR
0.3
5
mA
Cj
300
pF
RθJA
60
°C/W
Operating Junction Temperature Range
Tj
-55 ~ +150
°C
Storage Temperature Range
T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =100 °C
Typical Junction Capacitance
(1)
Typical Thermal Resistance
(2)
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.04
SMAF-S-SSL345F-3A45V
Page 1 of 3
山东晶导微电子股份有限公司
SSL345F
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half wave resistive
or inductive
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Fig.2 Typical Reverse Characteristics
10 4
10 1
T J =25°C
10 0
80
T J =25°C
T J =25°C
Junction Capacitance ( pF)
1
0.1
1.0
1.5
1000
500
100
2.0
0.1
1
10
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
100
Fig.4 Typical Junction Capacitance
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
100
10
Number of Cycles at 60Hz
2016.04
T J =100°C
10 3
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
SSL345F
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMAF
∠ALL ROUND
C
A
∠ALL ROUND
HE
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.2
0.20
3.7
2.7
1.6
1.2
4.9
min
0.9
0.12
3.3
2.4
1.3
0.8
4.4
max
47
7.9
146
106
63
47
193
min
35
4.7
130
94
51
31
173
UNIT
mm
g
pad
e
E
A
pad
D
E
A
V M
7°
Marking
The recommended mounting pad size
Type number
2.2
(86)
1.6
(63)
SS L 345F
Marking code
S345F
1.8
(71)
1.6
(63)
mm
Unit :
(mil)
2016.04
MYW604207B0
Page 3 of 3
很抱歉,暂时无法提供与“SSL345F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.48039
- 100+0.38189
- 300+0.33264
- 国内价格
- 5+0.43590
- 50+0.42936
- 600+0.42507
- 1200+0.41657
