山东晶导微电子股份有限公司
US8AC THRU US8MC
Jingdao Microelectronics co.LTD
Surface Mount Ultrafast Recovery Rectifier
Reverse Voltage – 50~1000 V
PINNING
Forward Current – 8 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: US8A~US8M
Simplified outline SMC symbol
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 217mg / 0.0077oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
Parameter
US8AC
US8BC
US8DC
US8GC
US8JC
US8KC
US8MC Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
8
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
150
A
Maximum Instantaneous Forward Voltage @8 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
1.0
1.3
1.7
10
100
IR
V
μA
Cj
65
55
pF
t rr
50
80
ns
RθJA
35
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.04
SMC-U-US8AC~US8MC-8A1KV
Page 1 of 3
山东晶导微电子股份有限公司
US8AC THRU US8MC
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
20ns/div
Set time Base for 20ns/div
Fig.3 Typical Reverse Characteristics
11.2
300
9.6
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
8.0
6.4
4.8
3.2
1.6
50
75
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
T J =125°C
100
125
150
40
Case Temperature (°C)
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
80
100
Fig.5 Typical Junction Capacitance
Fig.4 Typical Forward Characteristics
T J =25°C
1.0
US8AC~US8DC
US8GC
0.1
60
% of PIV.VOLTS
US8JC~US8MC
0.01
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
US8AC~US8GC
US8JC~US8MC
1
0.001
1.0
1.5
0.1
Instaneous Forward Voltage (V)
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
210
180
150
120
90
60
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.04
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
US8AC THRU US8MC
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
Type number
Marking code
US8AC
US8A
US8BC
US8B
US8DC
US8D
US8GC
US8G
US8JC
US8J
US8KC
US8K
US8MC
US8M
mm
Unit :
(mil)
2017.04
JD707081B20
Page 3 of 3
很抱歉,暂时无法提供与“US8JC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.47775
- 50+0.37897
- 150+0.32957
- 国内价格
- 20+0.84820
- 100+0.50600
- 800+0.35420
- 3000+0.25300
- 6000+0.24030
- 30000+0.22260
- 国内价格
- 5+0.52650
- 50+0.41764
- 150+0.36321
- 500+0.32238
