山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
MBR2040 x CT THRU MBR20200 x CT
SCHOTTKY BARRIER RECTIFIERS
Reverse Voltage - 40 to 200 V
Forward Current - 20 A
FEATURES
• High current capability
• Low forward voltage drop
• Low power loss, high efficiency
• High surge capability
• High temperature soldering guaranteed
• Mounting position: any
A1
A1 K
A2
K A2
TO-220AB
Mechanical data
• Case: TO-220AB
• A pprox. Weight: 1.9g ( 0.067oz)
• Case: ITO-220AB
• A pprox. Weight: 2.1g ( 0.07oz)
• Terminals: Lead solderable per MIL-STD-202, Method 208
ITO-220AB
A1
K
A2
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25℃ ambient temperature unless otherwise specified
TO-220
MBR2040CT
MBR2045CT
ITO-220
MBR2040FCT
MBR2045FCT
Maximum Recurrent Peak Reverse Voltage
V RRM
40
45
60
100
150
200
V
Maximum RMS voltage
V RMS
28
31.5
42
70
105
140
V
Maximum DC Blocking Voltage
V DC
40
45
60
100
150
200
V
MBR2060CT
MBR20100CT
MBR20150CT
MBR20200CT
CHARACTERISTICS
Units
MBR2060FCT MBR20100FCT MBR20150FCT MBR20200FCT
per diode
per device
I F(AV)
10
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method) per diode
I FSM
150
A
Maximum Average Forward
Rectified Current
Max Instantaneous
Forward Voltage at 10 A(per diode)
Maximum DC Reverse Current T a = 25°C
at Rated DC Reverse Voltage
T a =125°C
Typical Junction Capacitance (1)
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
VF
0.70
0.85
0.90
0.1
IR
Cj
0.75
0.92
0.05
mA
pF
400
°C/W
45
RθJA
V
Tj
-55 ~ +150
-55 ~ +175
°C
T stg
-55 ~ +150
-55 ~ +175
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 10cmX10cmX1mm copper pad areas.
2019.05
TO-220AB-ITO-220AB-S-MBR2040XCT~MBR20200XCT-20A200V
Page 1 of 3
山东晶导微电子股份有限公司
Fig.2 Typical Reverse Characteristics
15
0~
0V
~1
00
10
V
5
0.0
60
80
100 120 140 160 180
Instaneous Reverse Current ( mA)
25
40
Average Forward Current (A)
Fig.1 TYPICAL FORWARD CURRENT DERATING CURVE
100
40~100V
150~200V
10
T J =100°C
1.0
0.1
T J =25°C
0.01
0.001
Case Temperature (°C)
40
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic(per leg)
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =25°C
10
1
40~45V
60V
100V
150V
200V
0.1
0.4
0.6
0.8
1.0
1000
500
100
40~45V
60~200V
10
1.2
0.1
160
140
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
100
Transient Thermal Impedance( °C /W)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
1
100
Fig.6- Typical Transient Thermal Impedance
100
10
Number of Cycles at 60Hz
2019.05
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
TO-220AB
10.45 ( 0.411 )
9.85 ( 0.388 )
TYP 3.7
4.2 ( 0.165 )
2.8 ( 0.110 )
1.77 ( 0.070 )
1.14 ( 0.045 )
0.94 ( 0.040 )
0.62 ( 0.024 )
4.76 (0.187)
4.42 (0.174)
16.0 (0.630)
14.6 (0.575)
6.6 ( 0.260 )
6.0 ( 0.236 )
1.40 (0.055)
1.14 (0.045)
14.79 (0.582)
13.19 (0.519)
2.94 ( 0.116 )
2.54 ( 0.100 )
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
2.80 (0.110)
2.20 (0.087)
0.64 (0.025)
0.35 (0.014)
Unit: inch (mm)
TYP 2.54
ITO-220AB
0.413 (10.5)
0.388 (9.85)
TYP 3.5
0.114 (2.9)
0.091 (2.3)
0.055 (1.4)
0.043 (1.1)
0.031 (0.8)
0.020 (0.5)
0.185 (4.7)
0.173 (4.4)
0.63 (16.0)
0.58 (14.7)
0.276 (7.0)
0.248 (6.3)
0.114 (2.9)
0.098 (2.5)
0.563 (14.3)
0.512 (13.0)
0.112 (2.85)
0.100 (2.54)
PACKAGE OUTLINE
0.110 (2.8)
0.098 (2.5)
0.027 (0.70)
0.016 (0.41)
TYP 2.54
1
2019.05
2
Unit: inch (mm)
3
JD90515
Page 3 of 3
很抱歉,暂时无法提供与“MBR20200CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.97500
- 50+0.91000
- 200+0.84500
- 1000+0.78000
- 2500+0.74750
- 5000+0.71500
- 国内价格
- 5+1.55672
- 50+1.22980
- 150+1.08972
- 500+0.91487
- 2500+0.83700
- 5000+0.79035
