S9014T
SOT-523 Plastic-Encapsulate Transistors
S9014T
TRANSISTOR (NPN)
SOT–523
FEATURES
Small Surface Mount Package
MAXIMUM RATINGS (Ta=25℃ unless otherwise noted)
Symbol
Parameter
Value
Unit
VCBO
Collector-Base Voltage
50
V
VCEO
Collector-Emitter Voltage
45
V
VEBO
Emitter-Base Voltage
5
V
1. BASE
2. EMITTER
3. COLLECTOR
IC
Collector Current
100
mA
PC
Collector Power Dissipation
200
mW
Thermal Resistance From Junction To Ambient
625
℃/W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55~+150
RΘJA
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test conditions
Min
Typ
Max
Unit
Collector-base breakdown voltage
V(BR)CBO
IC=100µA, IE=0
50
V
Collector-emitter breakdown voltage
V(BR)CEO
IC=100µA, IB=0
45
V
Emitter-base breakdown voltage
V(BR)EBO
IE=100µA, IC=0
5
V
Collector cut-off current
ICBO
VCB=50V, IE=0
100
nA
ICEO
VCE=35V, IB=0
100
nA
Emitter cut-off current
IEBO
VEB=4V, IC=0
100
nA
DC current gain
hFE
VCE=5V, IC=1mA
200
1000
Collector-emitter saturation voltage
VCE(sat)
IC=100mA, IB=5mA
0.3
V
Base-emitter saturation voltage
VBE(sat)
IC=100mA, IB=5mA
1
V
0.7
V
Base-emitter voltage
VBE
Transition frequency
fT
Collector output capacitance
Cob
VCE=5V, IC=2mA
0.58
VCE=5V,IC=10mA , f=30MHz
150
VCB=10V, IE=0, f=1MHz
3.5
CLASSIFICATION OF hFE
REV.08
RANK
L
H
RANGE
200–450
450–1000
MARKING
J6
J7
1 of 3
MHz
pF
S9014T
hFE
Static Characteristic
1000
COMMON
EMITTER
Ta=25℃
20uA
6
18uA
16uA
14uA
4
12uA
10uA
8uA
2
IC
Ta=100℃
DC CURRENT GAIN hFE
COLLECTOR CURRENT IC (mA)
8
6uA
Ta=25℃
100
4uA
COMMON EMITTER
VCE= 5V
IB=2uA
4
6
COLLECTOR-EMITTER VOLTAGE
VCEsat
8
1
(V)
10
COLLECTOR CURRENT
IC
VBEsat
IC
100
(mA)
IC
2
1
0.1
Ta=25℃
BASE-EMITTER SATURATION
VOLTAGE VBEsat (V)
COLLECTOR-EMITTER SATURATION
VOLTAGE VCEsat (V)
1
VCE
10
0.1
Ta=100℃
Ta=25℃
Ta=100℃
β=20
β=20
1
10
COLLECTOR CURRENT
IC
100
IC
—— VBE
fT
1000
1
COMMON EMITTER
VCE= 5V
0.3
0.6
Cob/ Cib
IC
100
(mA)
IC
100
10
COMMON EMITTER
VCE=5V
Ta=25℃
0.9
1
0.1
1.2
1
BASE-EMMITER VOLTAGE VBE (V)
100
10
COLLECTOR CURRENT
Ta=25℃
0.1
0.0
1
(mA)
Ta=100℃
10
0.1
0.1
100
TRANSITION FREQUENCY fT (MHz)
0.01
0.1
10
COLLECTOR CURRENT
VCB/ VEB
PC
250
IC
100
(mA)
Ta
f=1MHz
IE=0/IC=0
COLLECTOR POWER DISSIPATION
PC (mW)
CAPACITANCE C (pF)
Ta=25 ℃
Cib
10
Cob
1
0.1
0.1
1
REVERSE VOLTAGE
REV.08
10
VR
(V)
200
150
100
50
50
75
AMBIENT TEMPERATURE
2 of 3
100
T
125
150
S9014T
REV.08
3 of 3
很抱歉,暂时无法提供与“S9014T”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.09200
- 20+0.08388
- 100+0.07576
- 500+0.06764
- 1000+0.06386
- 2000+0.06115
