RS5MC
RS5MC
    MDD(辰达半导体)
    SMC(DO-214AB)
    VR=1000V IF=5A VF=1.3V IR=10uA trr=500nS
RS5MC 数据手册
RS5AC THRU RS5MC Reverse Voltage - 50 to 1000 Volts Forward Current - 5.0 Ampere SURFACE MOUNT FAST RECOVERY RECTIFIER Features DO-214AB/SMC  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  Idea for printed circuit board  Open Junction chip 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.114 (2.90)  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed: 0.280(7.11) 0.260(6.60) 0.012(0.305) 0.006(0.152) 250℃/ 10 seconds at terminals  Glass passivated chip junction 0.103(2.62) 0.079(2.06) 0.060(1.52) 0.030(0.76) Mechanical Data 0.008(0.203)MAX. 0.320(8.13) 0.305(7.75) Case : JEDEC DO-214AB/SMC Molded plastic body Terminals : Solder plated, solderable per MIL-STD-750,Method 2026 Polarity : Polarity symbol marking on body Mounting Position : Any Weight : 0.0077 ounce, 0.22grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code MDD MDD MDD MDD MDD MDD MDD RS5AC RS5BC RS5DC RS5GC RS5JC RS5KC RS5MC 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 UNITS V V V Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage VRRM Maximum average forward rectified current I(AV) 5.0 A Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) IFSM 120 A Maximum instantaneous forward voltage at 5.0A VF 1.30 V IR 5 100 μA Maximum DC reverse current at rated DCblocking voltage Maximum reverse recovery time TA=25℃ TA=125℃ (NOTE 1) Typical junction capacitance (NOTE 2) Typical thermal resistance (NOTE 3) VRMS VDC trr 150 CJ RJA 50.0 RθJC 13.0 Operating junction and storage temperature range TJ,TSTG 250 35.0 -55 to +150 500 ns pF ℃/W ℃ Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A 2.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 3.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 RS5AC THRU RS5MC Reverse Voltage - 50 to 1000 Volts Forward Current - 5.0 Ampere Ratings And Characteristic Curves Fig.2 Typical Reverse Characteristics Fig.1 Forward Current Derating Curve 7.0 Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) 100 TJ=125°C 10 1.0 TJ=25°C 0.1 00 Case Temperature (°C) 20 40 60 80 100 120 140 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Instaneous Forward Fig.4 Typical Junction Capacitance Characteristics TJ=25°C 10 TJ=25°C Junction Capacitance (pF) Instaneous Forward Current (A) 100 1.0 0.1 pulse with 300μ s 0.0 0.5 1.0 1.5 2.0 TJ=25°C f = 1.0MHz Vsig = 50mVp-p 1% duty cycle 0.01 10 1 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 140 Peak Forward Surage Current (A) 120 100 80 60 40 20 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 RS5AC THRU RS5MC Reverse Voltage - 50 to 1000 Volts Forward Current - 5.0 Ampere Packing information P0 unit:mm P1 d Item Symbol Tolerance SMC Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 6.15 8.41 2.42 1.50 330.00 50.00 13.00 1.75 7.50 8.00 4.00 2.00 0.25 16.00 16.50 E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) SMC 13" 3,000 4.0 INNER BOX (mm) REEL DIA, (mm) 190*190*41 330 BOX (pcs) 6000 CARTON SIZE (mm) 365*365*340 CARTON (pcs) 42000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 4.3 0.170 B 0.160 C 4.1 7.9 0.311 D 3.8 0.150 E 12 0.472 Unit (inch) Rev:2024A2 Page :3
RS5MC 价格&库存
很抱歉,暂时无法提供与“RS5MC”相匹配的价格&库存,您可以联系我们找货
RS5MC
  • 10+0.51818
  • 100+0.42090
  • 600+0.33572
  • 1200+0.33068
  • 3000+0.28425
库存:4853
RS5MC
  • 5+0.56250
  • 50+0.45520
  • 150+0.40200
  • 500+0.36260
  • 3000+0.30700
  • 6000+0.29130
库存:5819
