ST34F THRU ST310F
Reverse Voltage - 40 to 100 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT TRENCH SCHOTTKY RECTIFIER
Features
SMAF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
0.106(2.70)
0.094(2.40)
0.063 (1.60)
0.051 (1.30)
0.146(3.70)
0.130(3.30)
High forward surge current capability
High temperature soldering guaranteed:
260°C/10 seconds at terminals
0.047(1.20)
0.035(0.90)
0.008(0.20)
0.005(0.12)
0.047(1.20)
0.031(0.80)
Mechanical Data
0.193(4.90)
0.173(4.40)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002ounce, 0.07 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unlss otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25℃
TA=100℃
at rated DCblocking voltage
Typical junction capacitance (NOTE1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Operating storage temperaturerange
VRRM
VRMS
VDC
ST34F
ST36F
ST310F
MDD
ST34F
MDD
ST36F
MDD
ST310F
40
28
40
60
42
60
100
70
100
I(AV)
UNITS
V
V
V
A
3.0
IFSM
80
60
100
A
VF
0.45
0.30
0.50
0.50
0.60
0.10
V
450
5
400
180
pF
65.0
℃/W
IR
CJ
RJA
TJ
TSTG
60.0
-55 to +125
-55 to +150
-55 to +150
mA
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.Thermal resistance from junction to ambient at 0.375”(9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2024A1
Page :1
ST34F THRU ST310F
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Ratings And Characteristic Curves
3
P.C.B mounted on
0.2*0.2"(5.0*5.0cm)
copper pad areas
2.4
1.8
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.2
ST34F
ST36F-ST310F
0.6
50
75
100
125
150
175
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
90
75
ST34F
ST36F-ST310F
60
45
30
15
8.3ms SINGLE HALF SINE-WAVE
1
10
LEAD TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
TJ=25 C
PULSE WIDTH=300 µs
2%DUTY CYCLE
0.1
ST34F
ST36F
ST310F
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
100
10
TJ=100 C
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
60
80
100
2000
1000
100
TJ=25 C
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
100
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
10
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
The curve above is for reference only.
Rev:2024A1
Page :2
ST34F THRU ST310F
Packing information
P0
P1
unit:mm
d
E
Item
F
B
A
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SMAF
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
2.80
4.75
1.42
1.50
178.00
54.40
13.00
1.75
5.05
4.00
4.00
2.00
0.30
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMAF
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
3,000
4.0
6,000
210*208*203
178
400*265*400
120,000
10.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.8
0.071
B
1.6
3.8
0.150
D
2.2
0.087
E
5.4
0.213
C
0.063
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“ST36F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.62798
- 50+0.44316
- 600+0.35995
- 1200+0.35635
- 3000+0.34922
- 国内价格
- 1+0.69207
- 10+0.55620
- 30+0.48838
- 100+0.43740
- 500+0.39669
- 1000+0.37628
- 国内价格
- 20+1.29170
- 100+0.77050
- 800+0.53930
- 3000+0.38520
- 6000+0.36600
- 30000+0.33900
