山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
SU R GE SUPPRESSOR BRIDGE SERIES
PINNING
FEATURES
• Lead Free Finish/RoHS Compliant
• Green Molding Compound
(No Halogen and Antimony)
• Lower clamping voltage and excellent
performance on ringing waves testing.
• Glass Passivated Chip Junction
• High Surge Current Capability
• Designed for Surface Mount Application
PIN
DESCRIPTION
1
Input Pin(~)
2
Input Pin(~)
3
Output Anode(+)
4
Output Cathode(-)
4
1
MECHANICAL DATA
• Case: MBF-T
• Terminals: Solderable per
MIL-STD-750, Method 2026
• A pprox. Weight: 75mg / 0.0026oz
3
2
MBF-T Package
Maximum Ratings and Thermal Characteristics(TA = 25°C unless otherwise specified)
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Parameter of Bridge Rectifier
Symbols
Average Rectified Output Current
at T C = 125 °C
TB110F
TB110FA
TB120F
TB120FA
TB240F
TB240FA
Units
IO
1.0
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
I FSM
A
Maximum Forward Voltage at 1.0 A
VF
1.1
V
IR
5
100
μA
Cj
8
pF
RθJA
130
°C/W
T j , T stg
-55 ~ +150
°C
Maximum DC Reverse Current
at Rated DC Blocking Voltage
(@VR=1000V)
@ T A =25 °C
@ T A =125 °C
Typical Junction Capacitance(f=1MHz,4V DC)
Typical Thermal Resistance(Note1)
Operating and Storage Temperature Range
Note: 1. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
Parameter of TVS
Symbol
TB110F
TB120F
Maximum allowable continuous AC voltage at 50-60Hz
V RMS
135
155
Breakdown voltage @ 1mA
V BR
Maximum allowable continuous DC voltage
V DC
Maximum peak current(8/20us@12Ω)(Note2)
I peak
TB240F TB110FA TB120FA TB240FA
310
135
155
310
209~231 237~263 492~543 209~231 237~263 492~543
190
220
440
190
35
T j , T stg
220
40
-55 ~ +150
440
Unit
V
V
V
A
°C
Note: 2.The internal resistance of lightning surge generator is 2 Ω, and the series resistance of test circuit is 10 Ω.
2020.12
MBF-T-TB110F-FA~TB240F/FA
Page 1 of 4
山东晶导微电子股份有限公司
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
1.0
1.5
100
120
140
T J =25°C
10
2.0
0.1
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
1.0
10
100
Reverse Voltage (V)
100
Transient Thermal Impedance( °C /W)
Peak Forward Surage Current (A)
80
1
0.5
Fig.5 Maximum Non-Repetitive Peak
Fig.6- Typical Transient Thermal Impedance
1000
100
10
Number of Cycles
2020.12
60
100
Instaneous Forward Voltage (V)
1
40
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 4
山东晶导微电子股份有限公司
• Recommended condition of flow soldering
Preliminary Heating
300
Soldering
Cooling (in air)
265°C
Temperature of Soldering (°C)
250
245°C
200
150
120°C
100
100°C
50
2 to 5 min
more than 1 min
less than 10s
• Recommended condition of reflow soldering
300
Peak Temperature
245 to 260°C, 10s max.
250
Reflow Heating Rate
1 to 5°C / s
200
150
100
50
Pre Heating Rate
1 to 5°C / s
Preliminary Heating
130 to 170°C,
50 to 120s
Soldering
230°C
20 to 30s
Cooling
more than 60s
2 times max.
Recommended peak temperature is over 245 °C. If peak temperature is below 245 °C, you may adjust
the following parameters; time length of peak temperature (longer), time length of soldering (longer),
thickness of solder paste (thicker)
• Condition of hand soldering
Temperature: 370°C
Time: 3s max.
Times: one time
• Remark:
Lead free solder paste (96.5Sn/3.0Ag/0.5Cu)
2020.12
www.sdjingdao.com
Page 3 of 4
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 5 leads
MBF-T
∠ALL ROUND
a
A
C
L1
L
d
HE
E
b
e
D
e
MBF-T mechanical data
A
C
D
E
HE
d
e
L
L1
max
1.6
0.22
5.0
4.1
7.0
2.7
0.8
1.7
1.1
min
1.2
0.15
4.5
3.6
6.4
2.3
0.5
1.3
0.5
max
63
8.7
197
161
276
106
31
67
43
min
47
5.9
177
142
252
91
UNIT
mm
a
b
0.2
0.9
7°
mil
8
35
Marking
Type number
6.0
236
0.9
35
1.1
43
2.4
94
2.5
100
Marking code
TB110F
TB110F
TB120F
TB120F
TB240F
TB240F
TB110FA
TB110FA
TB120FA
TB120FA
TB240FA
TB240FA
mm
Unit :
(mil)
TBXXXFA
2020.12
JD201205
Page 4 of 4
很抱歉,暂时无法提供与“TB120FA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08176
- 500+0.06426
- 1500+0.05454
