RCT0210RJLF
RCT0210RJLF
    HKR(香港电阻)
    贴片电阻 0402 10Ω ±5% 62.5mW
RCT0210RJLF 数据手册
www.hkresistors.com 南 充 溢 辉 电 子 科 技 有 限 公 司 Nanchong Yat Fai Electronics Technology Co., Ltd. 地址: 四川省南充市高坪区青莲街道金辉路8号 No.8 Jinhui Road,Qinglian Street, Gao Ping District Nanchong City, Sichuan Province, China Tel.: 0817-3315388 Fax.: 0817-3381813 E-mail:resistor@hkresistors.com http:// www.hkresistors.com AN ISO 9001: 2015 CERTIFIED MANUFACTURER AN ISO 45001 : 2018 MANUFACTURER AN ISO 14001 : 2015 MANUFACTURER AN IATF 16949 : 2016 MANUFACTURER SPECIFICATIONS FOR APPROVAL Customer: Name of Product: 相关业务 Sales Executive Chip Resistors - General Purpose - RCT Series 工程部 Engineering 品质部 Quality Control 核准 Approval 客戶确认 客戶确认 客戶确认 客戶确认 Customer Approval Customer Approval Customer Approval Customer Approval * A member of the Hong Kong Resistors Manufactory Group of Companies * Date:16 - Dec - 2024 Revision:R11 HKR Page 1/7 Chip Resistors - General Purpose 本公司产品遵循 SONY SS-00259 环境要求,不含 10 大环境相关有害禁用物质。 Our products are to comply with environmental requirements in accordance with SONY code no. SS-00259 with restrictions of 10 harmful materials. 特性 (Features) ‧ 轻薄短小 : 小型轻量,大幅缩小 PC 板面积及重量。 Small size and light weight with size range per international standard ‧ 装配性佳 : 外观尺寸均匀精确,易于装配。 Highly stable in auto-placement surface mounting application ‧ 可使用于波峰焊及回流焊。 Compatible with both wave soldering and reflow soldering 料号编码 (Part Number) RCT 05 27K J LF Type Size Value Tolerance Lead Free 型号 尺寸 阻值 精度 不含铅 01 : 0201 02 : 0402 03 : 0603 05 : 0805 06 : 1206 10 : 1210 20 : 2010 25 : 2512 F : ±1% J : ±5% 1/7 HKR Page 2/7 构造图 (Configuration) 尺寸 (Dimensions) Size 0201 0402 0603 0805 1206 1210 2010 2512 (unit: mm) L 0.60 ±0.03 1.00 ±0.10 1.60 ±0.10 2.00 ±0.10 3.10 ±0.10 3.10 ±0.10 5.00 ±0.20 6.35 ±0.20 W 0.30 ±0.03 0.50 ±0.05 0.80 ±0.10 1.25 ±0.10 1.55 ±0.10 2.50 ±0.10 2.50 ±0.15 3.10 ±0.15 T 0.23 ±0.03 0.35 ±0.05 0.45 ±0.10 0.50 ±0.10 0.55 ±0.10 0.55 ±0.10 0.55 ±0.10 0.55 ±0.10 C 0.15 ±0.05 0.20 ±0.10 0.25 ±0.15 0.35 ±0.20 0.45 ±0.20 0.45 ±0.25 0.60 ±0.25 0.60 ±0.25 D 0.15 ±0.05 0.25 ±0.10 0.30 ±0.15 0.40 ±0.20 0.40 ±0.20 0.45 ±0.25 0.50 ±0.25 0.60 ±0.25 Rated Load (%) 功率衰减曲线 (Power Derating Curve) 100 80 60 40 20 0 -60 -55 -40 -20 0 20 40 60 70 80 100 120 140 155 160 Temperature (℃) 当使用于环境温度 70℃ 以上时,额定功率将如上图之曲线衰减。 For resistors operated in ambient temperatures above 70℃, power rating must be derated in accordance with the curve as above. 2/7 HKR Page 3/7 额定 (Rating) 型号 Type 尺寸 Size RCT01 RCT02 RCT03 RCT05 RCT06 RCT10 RCT20 RCT25 0201 0402 0603 0805 1206 1210 2010 2512 额定功率 Power Rating at 70℃ 1/20W 1/16W 1/10W 1/8W 1/4W 1/3W 3/4W 1W 最高使用电压 Max RCWV 25V 50V 75V 150V 200V 200V 200V 200V 最高过负荷电压 Max Overload Voltage 50V 100V 150V 300V 400V 500V 500V 500V 最高使用电流 Jumper3.3M:±400ppm/℃ 10Ω(excluding 10Ω)~3.3M: ±200ppm/℃ 0603以上规格(0603 or above): 1Ω~10Ω;>1M:±200ppm/℃ 10Ω(excluding10Ω)~1M: ±100ppm/℃ JIS C 5201 4.8 / MIL-STD-202G METHOD 304 / IEC 60115-1 4.8 The temperature characteristic or temperature coefficient of resistance is not specified for resistance values of less than 5R owing to difficulty of accurate measurement 短时间过负荷 J : △ R ≦ ±(2% + 0.05Ω) Short Time F: △ R ≦ ±(1% + 0.05Ω) Overload JIS C 5201 4.13/IEC 60115-1 4.13 2.5×Rated voltage or Max. Overload Voltage for 5 sec. measure resistance after 30 minutes 恒温恒湿寿命 J : △ R ≦ ±(3% + 0.05Ω) 试验 Load Life F: △ R ≦ ±(1% + 0.05Ω) Humidity JIS C 5201 4.24/MIL-STD-202G Method 106G / IEC 60115-1 4.24 Maintain the temperature of the resistor at 40±2℃ and 90~95% RH with the rated voltage applied.Cycle ON for 1.5 hours and OFF for 0.5 hour for1000+48/-0 hours. After 1~4 hour, measure the resistance value. 耐久性 Load Life J : △ R ≦ ±(3% + 0.05Ω) F: △ R ≦ ±(1% + 0.05Ω) JIS C 5201 4.25/MIL-STD-202G Method 108A / IEC 60115-1 4.25 70 ±2℃,Max. working voltage for 1000 hrs with 1.5 hrs “ON” and 0.5 hrs “OFF”. 高低温试验 Temperature Cycle J : △ R ≦ ±(1% + 0.05Ω) F: △R≦±(0.5% + 0.05Ω) No mechanical damage JIS C 5201 4.19/MIL-STD-202G Method 107G / IEC 60115-1 4.19 Repeat 5 cycles as follows -65℃(30 min.)+25℃(2~3 min.) +125℃ (30 min.)+25℃(2~3 min.) 绝缘阻抗 Insulation Resistance Between termination and coating must be over 1000MΩ 弯曲强度 Bending Strength J : △ R ≦ ±(1% + 0.05Ω) F: △R≦±(0.5% + 0.05Ω) No mechanical damage JIS C 5201 4.6 / MIL-STD-202G Method 302 / IEC 60115-1 4.6 Test voltage: 100±15V JIS C 5201 4.33 / MIL-STD-202G Method 211A / IEC 60115-1 4.33 Resistance change after bended on the 90mm PCB. Bend: 3mm for 0201、0402、0603、0805 、1206、1210 2mm for 2010、2512 * 客户对VCR 电压系数、高电压、高脉冲、抗硫化、高功率等特殊参数有任何要求时,请选用我们对应系列的电阻产品。 4/7 HKR Page 5/7 字码编码说明 (Markings ) 472 2212 02D 1.1. ±5% (IEC E–24系列 Series )0603、0805、1206及以上规格(0201、0402无字码)均用三字码表示。 No markings on 0201 and 0402. Markings on the other sizes are expressed by a 3-digit code in its exact value. E. G. : 6R8=6.8Ω;100=10×100=10Ω;472=47×102=4700Ω=4.7KΩ。 1.2. ±1% 阻值表示规则 (+/-1% Resistance value markings) a. 0805、1206及以上规格 ±1% 阻值均用四字码表示。 Markings on sizes 0805, 1206 and above are expressed by a 4-digit code. E. G. :82R5=82.5Ω;1000=100×100=100Ω;2212=221×102=22100Ω=22.1KΩ。 b. 0603 ±1%( IECE–96系列)阻值均采用三代码表示。前两位为阻值的数字代码;后一位为英文大写 n 字母,表示倍率(10 次幂)。 Markings on 0603 ±1%( IECE–96 Series ) are expressed by a 3-digit code; the first two digits represent the value code and the last capital letter represents the multiplier. E-96系列阻值的数字代码如下表: The coding system of the E-96 series is as follows : 阻值 代码 阻值 代码 阻值 代码 阻值 代码 阻值 代码 阻值 代码 阻值 代码 阻值 代码 100 133 178 237 316 422 562 750 01 13 25 37 49 61 73 85 102 137 182 243 324 432 576 768 02 14 26 38 50 62 74 86 105 140 187 249 332 442 590 787 03 15 27 39 51 63 75 87 107 143 191 255 340 453 604 806 04 16 28 40 52 64 76 88 110 147 196 261 348 464 619 825 05 17 29 41 53 65 77 89 113 150 200 267 357 475 634 845 06 18 30 42 54 66 78 90 115 154 205 274 365 487 649 866 07 19 31 43 55 67 79 91 118 158 210 280 374 499 665 887 08 20 32 44 56 68 80 92 121 162 215 287 383 511 681 909 09 21 33 45 57 69 81 93 124 165 221 294 392 523 698 931 10 22 34 46 58 70 82 94 127 169 226 301 402 536 715 953 11 23 35 47 59 71 83 95 130 174 232 309 412 549 732 976 12 24 36 48 60 72 84 96 倍率字母代码如下表:(Multiplier code) Code A B C D E F G X Y Z 0 1 2 3 4 5 6 -1 -2 Multiplier 10 10 10 10 10 10 10 10 10 10-3 E. G. :01Y=100× 10-2=1Ω;68A=499×100=499Ω;02D=102×103=102KΩ c. 任何 1%电阻其阻值不在 E-96 范围系列中,则其字码表示与E-24系列+/-5%字码相同。仅用标签 注明误差。 Any resistance values of 1% tolerance but not included in the E-96 series, the value markings are the same as +/-5% tolerance with labelling identification. E. G.:120=12×100=12Ω;475=47×105=4.7MΩ。 1.3 零欧姆晶片电阻字码均用一个 “0”表示,其阻值在0~50mΩ 范围内,并无误差之分,所以我司标 签上无注明误差值。 Marking of the 0 Ohm resistor is a '0' with its value range from 0-50mΩ. No tolerance shown on the product label. 5/7 HKR Page 6/7 包装及卷包规格 (Tape and Reel Package) Taping is in accordance with EIA RS-481 P2 E W P0 D F B P1 A Accumulated dimensional tolerance 40±0.2mm Size A B W F E P1 P2 P0 D 0201 0.40 ±0.10 0.75 ±0.10 8.00 ±0.30 3.50 ±0.05 1.75 ±0.10 2.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 0402 0.65 ±0.10 1.15 ±0.10 8.00 ±0.30 3.50 ±0.05 1.75 ±0.10 2.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 0603 1.10 ±0.20 1.90 ±0.20 8.00 ±0.30 3.50 ±0.05 1.75 ±0.10 4.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 0805 1.65 ±0.20 2.40 ±0.20 8.00 ±0.30 3.50 ±0.05 1.75 ±0.10 4.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 1206 2.00 ±0.20 3.50 ±0.20 8.00 ±0.30 3.50 ±0.05 1.75 ±0.10 4.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 1210 2.85 ±0.20 3.50 ±0.20 8.00 ±0.30 3.50 ±0.05 1.75 ±0.10 4.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 2010 2.80 ±0.20 5.50 ±0.20 12.0 ±0.30 5.50 ±0.05 1.75 ±0.10 4.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 2512 3.50 ±0.20 6.70 ±0.20 12.0 ±0.30 5.50 ±0.05 1.75 ±0.10 4.00 ±0.10 2.00 ±0.05 4.00 ±0.10 1.50 ±0.10 Size Packaging Q'ty 0201 10Kpcs/Reel 0402 10Kpcs/Reel unit: mm 0603 0805 1206 5Kpcs/Reel 1210 2010 2512 Symbol Dimensions 4Kpcs/Reel A N C D B G T 178 ±3.0 60.0 ±2.0 13.0 ±1.0 19.5 ±1.0 2.30 ±0.5 10.0 ±1.5 14.9 max. 178 ±3.0 60.0 ±2.0 13.0 ±1.0 19.5 ±1.0 2.30 ±0.5 13.8 ±1.5 16.7 max. 贮存环境 Storage Condition 温度 Temp 湿度 Humidity 5~35℃ 20%-70% 6/7 储存期 Storage Time 1年 1 year HKR Page 7/7 外包裝 (Outer Packaging) 第一次包装:1~10卷 第二次包装:最多80卷 First inner box packing:1~10 reels Second carton packing :80 reels max. ■当包装数量不能达到最大时,剩余空隙部位采用辅助材料填满。 When carton quantity does not meet up the standard packing pieces, the remaining empty space will be filled up with buffer materials. ■当包装数量为最小时,使用其它方法包装,确保运输过程中无问题是至关重要的。 When the quantity is less, alternative packing method may be used. It is important to ensure safety of products during transportation. 7/7
RCT0210RJLF
物料型号:RCT系列,包括RCT01、RCT02、RCT03、RCT05、RCT06、RCT10、RCT20、RCT25等。
器件简介:厚膜晶片电阻器,采用RuO2作为电阻元件,Alumina作为基板,Ni+Sn作为电极镀层,表面有覆层。
引脚分配:文档中未明确提供引脚分配信息,但提供了推荐焊盘图案尺寸。
参数特性: - 阻值范围:1欧姆至100兆欧姆 - 包装方式:卷带装 - 公差:±1%,+5%
功能详解:文档中未提供具体的功能详解,但根据器件简介,可以推断其主要用于电子电路中的电阻功能。
应用信息:适用于需要精确电阻值的电子电路。
封装信息:提供了多种尺寸,包括0201、0402、0603、0805、1206、1210、1218、1812、2010、2512等,每种尺寸都有对应的尺寸参数和额定功率。
RCT0210RJLF 价格&库存
很抱歉,暂时无法提供与“RCT0210RJLF”相匹配的价格&库存,您可以联系我们找货
RCT0210RJLF
