山东晶导微电子股份有限公司
S3AC THRU S3MC
Jingdao Microelectronics co.LTD
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 3 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
• Case: SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.22g / 0.0077oz
Top View
Marking Code: S3A~S3M
Simplified outline SMC and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
S3AC
S3BC
S3DC
S3GC
S3JC
S3KC
S3MC
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
90
A
Maximum Instantaneous Forward Voltage at 3 A
VF
1.0
V
IR
5
100
μA
Cj
40
pF
RθJA
RθJC
40
16
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.01
SMC-A-S3AC~S3MC-3A1KV
Page 1 of 3
山东晶导微电子股份有限公司
S3AC THRU S3MC
Fig.2 Typical Reverse Characteristics
3.0
2.0
1.0
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
percent of Rated Peak Reverse Voltage (%)
1.0
T J =25°C
100
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
144
126
108
90
72
54
36
18
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
S3AC THRU S3MC
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
Type number
3.8
(150)
S3AC
4.1
(160)
4.3
(170)
4.1
(160)
Marking code
S3A
S3BC
S3B
S3DC
S3D
S3GC
S3G
S3JC
S3J
S3KC
S3K
S3MC
S3M
mm
Unit :
(mil)
2017.01
JD702219B0
Page 3 of 3
很抱歉,暂时无法提供与“S3JC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.25640
- 100+0.20142
- 300+0.17388
- 国内价格
- 20+0.23503
- 300+0.15939
- 1200+0.15780
- 3000+0.15464
- 国内价格
- 20+0.42410
- 100+0.25300
- 800+0.17710
- 3000+0.12650
- 6000+0.12020
- 30000+0.11130
