16
15
14
13
12
11
10
9
8
7
6
5
4
SYMBOL DEFINITION
A DIMENSION WITHOUT AN INSPECTION REPORT SYMBOL
DOES NOT REQUIRE INSPECTION. IT MAY BE
CONTROLLED ON THE INDIVIDUAL COMPONENT DRAWING.
M
MISSING SYMBOLS
TOTAL NO OF
INSPECTIONS
REQUIRED
LAST NO.
USED
4 6 9
2
DWG STATUS
DATE
STG REV N/P CHG
ZONE
1
REVISION HISTORY
DR APVD APVD
1
2
AUTH
14JA00 R 001 -
CLEARED REV COLUMN; ALL ACTIVE PARTSUPDATED PDM ATTRIBUTES
196648 CRW GGI LLD
17JL00 R 002
REINSTATE 12077412
000010 JIB JIB JA
10
M
15OC04 R
03
ALL ACTIVE PARTS - ADDED TERMINAL ID
NOTE
260003 RTV JVM MKM
24FE05 R
04
ALL ACTIVE PARTS - REVISED MAT'L SPEC &
DRAWING NAME
265136 JS JS TM
18MY05 R
05
12176389 - UPDATED PDM ATTRIBUTES
268280 JBD FKV WTM
30SE05 R
06
12077411, 12077413, 12084201,
12129493 & 12176389 - UPDATED
PDM ATTRIBUTES; 12077411 - ADDED 1.0 MM2
CABLE; ALL ACTIVE PARTS - ADDED NOTE# 6
272905 JTV AUG WTM
11JA08 R
07
ALL PARTS - 2X 5 +-0.15 TYP WAS
2X 5 +-0.01 TYP
403419 WHC WHC WTM L
18FE15 R
08
33231919 - RELEASED AND 12176387-90 ADDED TARNISH NOTE
428904 NRM JVM DS
18SE15 R
09
33231919 - DIM 19.95 0.4 WAS
19.95 +0.15 / -0.4 AND UPDATED PART
AVAILABILITY
430685 LES LES MJD
22MY19 R
10
12176387 - 3 WAS 5 ON SIZE (MM2) COLUMN
443374 LVD JIE JIE
10
L
K
3
K
103
102
TYPE
SAME AS TYPE 101
EXCEPT AS SHOWN
TYPE
SAME AS TYPE 101
EXCEPT AS SHOWN
J
J
2X 5
H
H
2X U
X
10
1
3.725
E
0.175
G
2
X
7
3.95
CABLE "ID"
"PED" OPTIONAL FOR EXISTING TOOLS
2X 3
G
SEE CHART
2X 4.58
F
VIEW TO
STAMP DIE ID "PXX" IN THIS AREA (0.6)
CHARACTERS XX DESIGNATES DIE NUMBER
LOCATION IS APPROXIMATE
X-X
VIEW TO
F
X-X
INSULATION WINGS FOR
(SEE CHART) MAX INSULATION DIA
E
E
CORE WINGS FOR
(SEE CHART) MM2 CABLE
NOTES
2X 8
2X 5
1. UNLESS OTHERWISE SPECIFIED AND/OR INDICATED:
0.15
TYP
DIMENSIONS ARE TO FACE OF VIEW SHOWN AND
AUTOMATICALLY ROUNDED BY COMPUTER FOR INSPECTION
(SEE MATH MODEL FOR PRECISE DIMENSIONS). FOR ALL
OTHER DIMENSIONS NOT SHOWN BUT REQUIRED FOR TOOL
BUILD, SEE MATH MODEL FOR PRECISE TOOL PATH DATA.
D
D
2. R 0.4 PERMISSIBLE ON ALL "SHARP" CORNERS.
TYPE
101
3. RECOMMENDED MATING BLADE 2.8 X 0.81.
4. TERMINALS TO CRIMP AROUND AND RETAIN CAVITY
SEAL 12015323 OR EQUIVALENT.
5. "PXX" INDICATES "P" PLUS LAST TWO DIGITS OF MAKE
SERIES NUMBER P01, P02, P03, ETC. .
C
6. DO NOT PROBE, TEST OR OTHERWISE CONTACT THE INTERIOR REGION (THE
SPRING OR ANY MOVING PART) OF THIS TERMINAL. SEVERE DAMAGE CAN
OCCUR, COMPROMISING THE PERFORMANCE OF THE ELECTRICAL INTERFACE.
A
LINE DRAWN THROUGH A PART NUMBER
INDICATES THAT PHYSICAL PARTS ARE NOT AVAILABLE
FOR ORDERING.
CONNECTION SYSTEMS
PART NUMBERS THAT DO NOT HAVE A LINE PRESENT INDICATE
THAT PHYSICAL PARTS ARE AVAILABLE FOR ORDERING.
CONTACT APTIV SALES TO ASSURE AVAILABILITY
OF PARTS.
DWG TYPE
PART DRAWING
WARREN, OH
COPYRIGHT 1998 APTIV. ALL RIGHTS RESERVED.
THIS DRAWING IS THE PROPERTY OF APTIV AND CONTAINS APTIV
CONFIDENTIAL INFORMATION. THE REPRODUCTION, DISTRIBUTION AND
UTILIZATION OF THIS DOCUMENT OR ITS RELATED CAD MATH DATA, AS WELL
AS COMMUNICATION OF ANY CONTENT TO OTHERS, WITHOUT EXPRESS
AUTHORIZATION, IS PROHIBITED.
STYLE
DATE
DR
DISTR CODE
VOLUME (CM3)
B
PART NO
A
16
15
14
REV
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 30.56
0.406 X 32.54
0.406 X 32.54
0.406 X 32.54
MAT'L SIZE
UNPLATED
SPEC
13
12176390
12176389
33231919
12176388
12176387
12129493
12084201
12077413
12077412
12077411
12045639
12034454
12020648
PART NO
12
A8
A9
01
AA
A8
A9
C8
E11
E11
E9
E11
D8
F8
H8
REV N/P
AG PLATED COPPER ALLOY
TIN PLATED COPPER ALLOY
P1519027 425 TIN BRS EX HD SN PLTD
MAT'L SPEC
PLATED
11
10
0.35-0.5
0.8-1
1-2
2-3
3
2-3
0.35-0.5
3
1-2
0.5-0.8-1.0
3
1-2
0.5-0.8
SIZE (MM2)
0.35-0.5
2.03-3.12
2.48-3.05
2.45-3.80
3.49-3.65
2.45-3.80
1.84-2.51
3.49-3.65
2.48-3.05
2.03-3.12
3.49-3.65
2.48-3.05
2.03-3.12
DIA
21
19
15
13
12
13
21
12
15
19
12
15
19
ID
103
101
103
103
103
103
101
103
103
101
102
102
101
TYPE
2.4 0.2
3.2 0.4
3.7 0.4
4 0.4
4.6 0.4
4 0.4
2.4 0.2
4.6 0.4
3.7 0.4
3.2 0.4
4.6 0.4
3.7 0.4
3.2 0.4
E
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
19.95 +0.15-0.4
U
THIS DOCUMENT IS IN ACCORDANCE WITH ASME Y14.5M-1994
AS AMENDED BY THE GM GLOBAL DIMENSIONING AND
TOLERANCING ADDENDUM-2001. SEPARATE PATTERNS OF
FEATURES MAY BE GAGED SEPARATELY REGARDLESS OF DATUM
REFERENCES.
8
7
APVD2
APVD3
B
29MY98
02JN98
16JL98
APVD4
APVD5
SUBSTANCES OF CONCERN AND RECYCLED
CONTENT PER APTIV 10949001
MATERIAL
SEE CHART
ALL DIMENSIONS ARE IN MILLIMETERS
1
PROCESS SENSITIVE DIMENSION
DRAWING NAME
REFERENCE
TAXI TERM F M/P 280 SEALED
DIMENSIONS ENCLOSED IN
INDICATE
REFERENCE DIMENSIONS AND NO TOLERANCE
LIMITS ARE ESTABLISHED
CABLE
9
D
JORGE IBARRA
OSCAR OCHOA
O. GALLEGOS
APVD1
6
5
DIMENSIONAL RANGE (MM)
CHART D
FROM
12
TO
12
TOLERANCE UNLESS OTHERWISE SPECIFIED
0.1
0.2
ANGULAR TOLERANCE 2
4
A
DRAWING NUMBER
THIRD ANGLE
PROJECTION
12089195
DO NOT
SCALE
USE MATH
DATA
3
SIZE
SCALE
FRAME NO
SHEET NO
STG
A0
10:1
1 OF 1
1 OF 1
R
2
1
REV
N/P
10 -
Time: 10:53:52
7. FOR TERMINALS PACKAGED & STORED IN THE APPROVED MANNER, TARNISH
ON SILVER PLATED SURFACES WILL NOT AFFECT THE PERFORMANCE OF THE PART.
User: zj8qmm
Part: 12089195-CUS01-S01/10
Date: 24-May-19
zj8qmm,05242019,10:53,672pass,nor
C
很抱歉,暂时无法提供与“12129493”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 2300+0.56443
- 23000+0.53632
- 57500+0.51445
- 国内价格
- 1+0.64680
- 1150+0.48510
- 2300+0.32340
- 国内价格
- 200+0.41689
- 400+0.40322
- 800+0.39639
- 1600+0.37589
