LC1206CB3TR12
LC1206CB3TR12
    LEADCHIP(岭芯)
    SOT-23
    1.2V 300MA 8V
LC1206CB3TR12 数据手册
LC1206 300mA Low Consumption Linear Regulator GENERAL DESCRIPTION FEATURES LC1206 series are a group of positive voltage output, high precise, and high PSRR and low power consumption voltage regulator. Voltages are selectable in 100mV steps within a range of 1.2V to 3.6V. It also can be customized on command.        LC1206 series have excellent load and line transient response and good temperature characteristics, which can assure the stability of chip and power system. And it uses trimming technique to guarantee output voltage accuracy within ±2%. Low Quiescent Current: 2uA at 5V 60dB PSRR at 100Hz Low Output Noise: 44uVRMS Low Dropout: 280mV at 150mA load Low Temperature Coefficient: ±100ppm/C Excellent Line Regulation: 0.05%/V Highly Accurate: ±2% APPLICATIONS      LC1206 series are available in SOT-23-3, SOT-23-5 and SOT-89-3 packages, which are lead (Pb)- free. Reference Voltage Source Battery Powered Equipment Hand-Hold Equipment Wireless LAN GPS Receivers TYPICAL APPLICATION LC1206 BLOCK DIAGRAM Supply Current vs. Input Voltage 2.5 Is(uA) 2.0 1.5 1.0 0.5 Vout=3.0V 0.0 2 4 6 8 Vin(V) www.leadchip.com 1 Your final power solution LC1206 ORDERING INFORMATION MARKING INFORMATION LC1206 □ 1□ 2□ 3□ 4 Code Product Classification Marking Description Temperature & Rohs: C: -40~85C, Pb Free Rohs Std. Package type: B3: SOT-23-3 B5: SOT-23-5 C3: SOT-89-3 Packing type: TR:Tape&Reel (Standard) Output voltage: e.g. 12=1.2V 25=2.5V 36=3.6V □ 1 □ 2 □ 3 □ 4 E: Product Code X: Output Voltage EXYW YW: Date Code Product Classification Marking EXYW YW: Date Code Product Classification Marking E: Product Code X: Output Voltage Code Code 1.2V 2 1.3V 3 1.4V 4 1.5V 5 1.6V 6 1.7V 7 1.8V 8 1.9V 9 2.0V 0 XX: Output voltage: LC1206CB5TR□□ E: Product Code X: Output Voltage MARKING DESCRIPTON VOUT LC1206CB3TR□□ VOUT Code VOUT Code 2.1V 2.2V 2.3V 2.4V 2.5V 2.6V 2.7V 2.8V 2.9V 1 2 3 4 5 6 7 8 9 3.0V 3.1V 3.2V 3.3V 3.4V 3.5V 3.6V 0 1 2 3 4 5 6 AFXX LLBYW GND VOUT VDD LC1206CC3TR□□ AF: Product Code XX: Output Voltage LL: LOT NO. B: FAB Code YW: Date Code Ground Output Voltage Supply Voltage Input e.g. 12=1.2V, 25=2.5V, 36=3.6V. Y: The Year of manufacturing,”1” stands for year 2011, ”2” stands for year 2012, and “8” stands for year 2018. W: The week of manufacturing. ”A” stands for week 1,”Z” stands for week 26,” A ” stands for week 27,” Z ” stands for week 52. www.leadchip.com 2 Your final power solution LC1206 ABSOLUTE MAXIMUM RATING Parameter Value Max Input Voltage Operating Junction Temperature (TJ) Ambient Temperature (TA) SOT-23-3, SOT-23-5 Power Dissipation SOT-89-3 Storage Temperature (TS) Lead Temperature & Time 10V 125C -40C~85C 250mW 500mW -40C~150C 260C, 10 Sec Note: Exceed these limits to damage to the device. Exposure to absolute maximum rating conditions may affect device reliability. RECOMMENDED WORK CONDITIONS Parameter Value Input Voltage Range Ambient Temperature Max. 8V -40C~85C ELECTRICAL CHARACTERISTICS Test Conditions: CIN=1uF,COUT=1uF,TA=25C, unless otherwise specified. Symbol Parameter VDD Input Voltage VOUT Output Voltage Conditions VOUT >1.5V VOUT
