PM101M016E058PTR
PM101M016E058PTR
    CAPXON(台湾丰宾)
    SMD,D6.3xL5.8mm
    贴片铝电解电容 SMD,D6.3xL5.8mm 100µF ±20% 16V 2000Hrs@105℃
PM101M016E058PTR 数据手册
SOLID CONDUCTIVE POLYMER ▪ PM SERIES PM SERIES ▪ LOW HEIGHT TYPE KEY FEATURES ▪ ▪ ▪ ▪ ▪ SOLID CONDUCTIVE POLYMER ▪ SMD type Low height for space critical applications Endurance: 105°C ▪ 2 000 hours Large permissible ripple current No dry-out effect guarantees extremely long life SPECIFICATIONS Items Operating Temperature Range Rated Voltage Range VR Surge Voltage VS Capacitance Range CR Cap. Tolerance ΔC Leakage Current ILEAK (20°C ▪ VR applied) Dissipation Factor % tanδ (20°C ▪ 120Hz) Equivalent Series Resistance ESR (20°C ▪ 100kHz) Performance Characteristics -55 ~ +105°C 2.5 ~ 100V DC (VR ≤ 20V): VS = 1.15∙VR (VR ≥ 25V): VS = 1.10∙VR 4.7 ~ 560µF ±20% (120Hz ▪ 20°C) Not to exceed the values shown in standard ratings After 2 minutes Not to exceed the values shown in standard ratings Not to exceed the values shown in standard ratings ~ Lifetime Test Endurance 105°C (VR applied) Moisture Resistance stored at 60°C (RH 90 ~ 95%) Test △C/CR tanδ ESR ILeak Test △C/CR tanδ ESR ILeak 2 000 hours Within ±20% of the initial value Not to exceed 150% of the value specified Not to exceed 150% of the value specified Less than the specified value 1 000 hours Within ±20% of the initial value Not to exceed 150% of the value specified Not to exceed 150% of the value specified Less than the specified value DIMENSIONS STANDARD PACKAGE ▪ All dimensions in mm øD 4 5 5 6.3 6.3 CapXon_Ver. 003 – 09/01/2021 L 5.5 5.5 5.8 5.8 7.7 a 0.3 0.3 0.3 0.3 0.3 A 4.3 5.3 5.3 6.6 6.6 1 For further information please contact sales@capxon.org B 4.3 5.3 5.3 6.6 6.6 C 4.9 5.9 5.9 7.2 7.2 W 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 0.5 to 0.8 P±0.2 1 1.4 1.4 2.2 2.2 Document Number: PM series SOLID CONDUCTIVE POLYMER ▪ PM SERIES STANDARD RATINGS VR (V) 2.5 4 6.3 Part number shows blister tape on paper reel CR (µF) øD (mm) L (mm) ILEAK (µA, 2min) 82 100 150 180 180 220 220 270 270 330 390 390 470 470 560 560 47 56 68 100 100 120 120 150 150 150 180 220 220 220 270 270 330 330 330 390 390 470 47 56 68 68 5 6.3 6.3 5 6.3 5 6.3 5 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 5 5 5 5 6.3 5 6.3 5 6.3 6.3 6.3 5 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 5 5 5 6.3 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 7.7 5.8 7.7 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 5.8 7.7 5.8 5.8 5.8 7.7 5.8 7.7 5.8 5.8 7.7 5.8 7.7 7.7 5.5 5.5 5.5 5.8 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 CapXon_Ver. 003 – 09/01/2021 Max. ESR +20°C ▪ 100kHz (mΩ) 30 22 22 25 22 25 22 22 22 15 25 15 20 15 15 15 25 25 25 25 22 22 22 22 22 20 22 22 22 20 22 20 20 15 15 20 15 15 30 30 30 22 tanδ +20°C ▪ 120Hz (%) 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 IR ▪ Max. Ripple Current +105°C ▪ 100kHz (mA rms) 2100 2500 2500 2310 2500 2310 2800 2610 2800 3100 2610 3100 2800 3600 3100 3600 2310 2310 2310 2310 2500 2500 2500 2500 2500 3100 2500 2610 2800 3100 2800 3100 2800 3100 3600 2800 3600 3600 2000 2000 2000 2690 2 For further information please contact sales@capxon.org CapXon Part Number PM820M2R5C058PTR PM101M2R5E058PTR PM151M2R5E058PTR PM181M2R5C058PTR PM181M2R5E058PTR PM221M2R5C058PTR PM221M2R5E058PTR PM271M2R5C058PTR PM271M2R5E058PTR PM331M2R5E058PTRZ PM391M2R5E058PTR PM391M2R5E058PTRZ PM471M2R5E058PTR PM471M2R5E077PTR PM561M2R5E058PTRZ PM561M2R5E077PTR PM470M004C058PTR PM560M004C058PTR PM680M004C058PTR PM101M004C058PTR PM101M004E058PTR PM121M004C058PTR PM121M004E058PTR PM151M004C058PTR PM151M004E058PTR PM151M004E077PTR PM181M004E058PTR PM221M004C058PTR PM221M004E058PTR PM221M004E077PTR PM271M004E058PTR PM271M004E077PTR PM331M004E058PTR PM331M004E058PTRZ PM331M004E077PTR PM391M004E058PTR PM391M004E077PTR PM471M004E077PTR PM470M6R3C055PTR PM560M6R3C055PTR PM680M6R3C055PTR PM680M6R3E058PTR Document Number: PM series SOLID CONDUCTIVE POLYMER ▪ PM SERIES STANDARD RATINGS VR (V) 6.3 10 Part number shows blister tape on paper reel CR (µF) øD (mm) L (mm) ILEAK (µA, 2min) 82 82 100 100 100 120 120 150 150 150 180 180 180 220 220 220 270 270 330 330 330 390 4.7 6.8 10 15 22 33 33 39 39 47 47 47 56 56 56 68 68 68 82 82 5 6.3 5 5 6.3 5 6.3 5 6.3 6.3 5 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 4 4 4 4 4 5 6.3 5 6.3 5 6.3 6.3 5 6.3 6.3 5 6.3 6.3 5 6.3 5.5 5.8 5.5 5.8 5.8 5.8 5.8 5.8 5.8 7.7 5.8 5.8 7.7 5.8 5.8 7.7 5.8 7.7 5.8 7.7 7.7 7.7 5.5 5.5 5.5 5.5 5.5 5.5 5.8 5.5 5.8 5.5 5.8 7.7 5.5 5.8 7.7 5.5 5.8 7.7 5.5 5.8 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 300 CapXon_Ver. 003 – 09/01/2021 Max. ESR +20°C ▪ 100kHz (mΩ) 30 22 30 25 22 25 22 22 22 20 22 22 20 20 15 15 20 15 20 15 10 15 120 120 80 80 80 30 30 30 30 30 30 20 30 30 20 30 30 20 30 30 tanδ +20°C ▪ 120Hz (%) 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 IR ▪ Max. Ripple Current +105°C ▪ 100kHz (mA rms) 2000 2690 2000 2310 2800 2310 2800 2610 2800 3100 2610 2800 3100 3000 3100 3600 3000 3600 3100 3600 4200 3600 980 980 1200 1200 1200 2000 2200 2000 2200 2000 2200 2800 2000 2200 2800 2000 2200 2800 2000 2200 3 For further information please contact sales@capxon.org CapXon Part Number PM820M6R3C055PTR PM820M6R3E058PTR PM101M6R3C055PTR PM101M6R3C058PTR PM101M6R3E058PTR PM121M6R3C058PTR PM121M6R3E058PTR PM151M6R3C058PTR PM151M6R3E058PTR PM151M6R3E077PTR PM181M6R3C058PTR PM181M6R3E058PTR PM181M6R3E077PTR PM221M6R3E058PTR PM221M6R3E058PTRZ PM221M6R3E077PTR PM271M6R3E058PTR PM271M6R3E077PTR PM331M6R3E058PTR PM331M6R3E077PTR PM331M6R3E077PTRZ PM391M6R3E077PTR PM4R7M010B055PTR PM6R8M010B055PTR PM100M010B055PTR PM150M010B055PTR PM220M010B055PTR PM330M010C055PTR PM330M010E058PTR PM390M010C055PTR PM390M010E058PTR PM470M010C055PTR PM470M010E058PTR PM470M010E077PTR PM560M010C055PTR PM560M010E058PTR PM560M010E077PTR PM680M010C055PTR PM680M010E058PTR PM680M010E077PTR PM820M010C055PTR PM820M010E058PTR Document Number: PM series SOLID CONDUCTIVE POLYMER ▪ PM SERIES STANDARD RATINGS VR (V) 10 16 Part number shows blister tape on paper reel CR (µF) øD (mm) L (mm) ILEAK (µA, 2min) 82 100 100 100 120 150 150 180 180 220 220 270 330 10 10 10 15 15 15 22 22 22 33 33 33 39 39 39 47 47 47 56 56 56 68 68 82 82 100 100 150 180 6.3 5 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 5 6.3 6.3 5 6.3 6.3 5 6.3 6.3 5 6.3 6.3 5 6.3 6.3 5 6.3 6.3 5 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 7.7 5.5 5.8 7.7 5.8 5.8 7.7 5.8 7.7 5.8 7.7 7.7 7.7 5.8 5.8 7.7 5.8 5.8 7.7 5.8 5.8 7.7 5.8 5.8 7.7 5.8 5.8 7.7 5.8 5.8 7.7 5.8 5.8 7.7 5.8 7.7 5.8 7.7 5.8 7.7 7.7 5.8 300 300 300 300 300 300 300 300 300 300 300 300 300 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 400 CapXon_Ver. 003 – 09/01/2021 Max. ESR +20°C ▪ 100kHz (mΩ) 20 30 30 20 25 25 20 25 20 25 20 20 20 40 35 30 40 35 30 40 35 30 40 35 30 40 35 30 40 35 30 40 35 30 35 25 35 25 30 25 25 25 tanδ +20°C ▪ 120Hz (%) 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 12 IR ▪ Max. Ripple Current +105°C ▪ 100kHz (mA rms) 2800 2000 2200 2800 2610 2610 3100 2610 3100 2610 3100 3100 3100 2000 2200 2610 2000 2200 2610 2000 2200 2610 2000 2200 2610 2000 2200 2610 2000 2200 2610 2000 2200 2610 2200 2690 2200 2690 2490 2690 2690 3200 4 For further information please contact sales@capxon.org CapXon Part Number PM820M010E077PTR PM101M010C055PTR PM101M010E058PTR PM101M010E077PTR PM121M010E058PTR PM151M010E058PTR PM151M010E077PTR PM181M010E058PTR PM181M010E077PTR PM221M010E058PTR PM221M010E077PTR PM271M010E077PTR PM331M010E077PTR PM100M016C058PTR PM100M016E058PTR PM100M016E077PTR PM150M016C058PTR PM150M016E058PTR PM150M016E077PTR PM220M016C058PTR PM220M016E058PTR PM220M016E077PTR PM330M016C058PTR PM330M016E058PTR PM330M016E077PTR PM390M016C058PTR PM390M016E058PTR PM390M016E077PTR PM470M016C058PTR PM470M016E058PTR PM470M016E077PTR PM560M016C058PTR PM560M016E058PTR PM560M016E077PTR PM680M016E058PTR PM680M016E077PTR PM820M016E058PTR PM820M016E077PTR PM101M016E058PTR PM101M016E077PTR PM151M016E077PTR PM181M016E058PTR Document Number: PM series SOLID CONDUCTIVE POLYMER ▪ PM SERIES STANDARD RATINGS VR (V) 20 25 35 50 63 100 Part number shows blister tape on paper reel CR (µF) øD (mm) L (mm) ILEAK (µA, 2min) 10 10 15 22 22 27 33 33 39 47 47 56 56 120 6.8 10 10 15 15 22 22 33 33 39 47 18 22 27 47 56 8,2 12 15 5.6 8.2 4.7 5 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 6.3 5.8 5.8 5.8 5.8 7.7 5.8 5.8 7.7 7.7 5.8 7.7 5.8 7.7 5.8 5.8 5.8 7.7 5.8 7.7 5.8 7.7 5.8 7.7 7.7 5.8 5.8 5.8 5.8 7.7 7.7 5.8 5.8 5.8 5.8 5.8 7.7 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 600 CapXon_Ver. 003 – 09/01/2021 Max. ESR +20°C ▪ 100kHz (mΩ) 40 40 35 35 30 35 35 30 30 35 30 35 30 25 40 35 35 35 30 35 30 35 30 30 35 64 50 50 50 35 80 80 80 100 100 100 tanδ +20°C ▪ 120Hz (%) 8 8 8 8 8 8 8 8 8 8 8 8 8 12 8 8 8 8 8 8 8 8 8 8 8 12 12 12 12 12 12 12 12 12 12 12 IR ▪ Max. Ripple Current +105°C ▪ 100kHz (mA rms) 2000 2200 2200 2200 2670 2200 2200 2670 2670 2200 2670 2200 2670 3200 2000 2200 2670 2200 2670 2200 2670 2200 2670 2670 2200 900 1300 1530 1600 2100 800 800 800 700 700 1060 5 For further information please contact sales@capxon.org CapXon Part Number PM100M020C058PTR PM100M020E058PTR PM150M020E058PTR PM220M020E058PTR PM220M020E077PTR PM270M020E058PTR PM330M020E058PTR PM330M020E077PTR PM390M020E077PTR PM470M020E058PTR PM470M020E077PTR PM560M020E058PTR PM560M020E077PTR PM121M020E058PTR PM6R8M025E058PTR PM100M025E058PTR PM100M025E077PTR PM150M025E058PTR PM150M025E077PTR PM220M025E058PTR PM220M025E077PTR PM330M025E058PTR PM330M025E077PTR PM390M025E077PTR PM470M025E058PTR PM180M035E058PTR PM220M035E058PTR PM270M035E058PTR PM470M035E077PTR PM560M035E077PTR PM8R2M050E058PTR PM120M050E058PTR PM150M050E058PTR PM5R6M063E058PTR PM8R2M063E058PTR PM4R7M100E077PTR Document Number: PM series SOLID CONDUCTIVE POLYMER ▪ PM SERIES MULTIPLIER Kf for RIPPLE CURRENT vs. FREQUENCY Frequency (Hz) Coefficient Kf 120 ≤ Freq. < 1k 0.05 1k ≤ Freq. < 10k 0.3 10k ≤ Freq. < 100k 0.7 100k ≤ Freq. < 300k 1 PRECAUTIONS, GUIDELINES AND PACKAGING INFORMATION Unless otherwise agreed in individual specifications, all products are subject to our “General Precautions and Guidelines” as well as our “Packaging Information”. Please refer to the following links in the table. General Precautions & Guidelines Packaging Information 3D Models Reliability Tests DISCLAIMER All product related data (e.g. specification, statements and general information) are subject to change without any notice. It is necessary that the customer observes all product related technical / application information and handling instructions. CapXon products are designed and manufactured according to severe quality and safety standards. Under no circumstance, CapXon warrants that any CapXon product is suitable for the purposes intended for your application, even CapXon knows the application. It is customer's duty and obligation to check and make sure that CapXon products are suitable for the purposes intended and select the correct and proper CapXon product. Customers are requested to perform a sufficient validation and reliability evaluation to assure needed safety level and reliability performance by suitable designs and to apply proper safeguards (e.g. redundancies, protective circuits). Particular operating conditions (ambient temperature, ripple current, voltage, thermal resistance, etc.) as well as storage, production or assembly may affect the performance and the lifetime of the capacitor. Please consult CapXon for lifetime estimation, failure mode considerations or worst-case scenarios according to the product technology, product tolerances / deviations or change of the characteristics of the capacitor due to shipment, storage, handling, production and usage. For aerospace or military application, life‐saving, life‐sustaining, safety critical applications or any application where failure may cause severe personal injury or death, please consult us before design‐in the capacitor in your application. Except for the written expressed warranties, CapXon does not impliedly, by assumption or whatever else, warrant, undertake, promise any other warranty or guaranty for any CapXon product. For further information, please visit our website www.capxongroup.com or contact CapXon directly. CapXon_Ver. 003 – 09/01/2021 6 For further information please contact sales@capxon.org Document Number: PM series
PM101M016E058PTR 价格&库存
很抱歉,暂时无法提供与“PM101M016E058PTR”相匹配的价格&库存,您可以联系我们找货
PM101M016E058PTR
  • 10+1.75920
  • 100+1.04950
  • 500+0.73460
  • 1000+0.52470
  • 2000+0.49850
  • 10000+0.46170
库存:785
PM101M016E058PTR
  • 1+1.43000
  • 50+1.10000
  • 1000+1.01640
PM101M016E058PTR
  • 5+0.92385
  • 50+0.73931
  • 150+0.64709
库存:249
